Speaker Impedance? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-07-2011, 01:49 PM - Thread Starter
Paul102691's Avatar
Hi, I can't figure out what the impedance of the Cerwin vega ve-5m's is.
(http://www.amazon.com/Cerwin-Vega-VE...7479660&sr=8-4)
I just purchased a Sony STR-DE598 receiver for real cheap, and I wanted to make sure that it would be okay to hook the ve-5m's up to this receiver.
Here's the receiver:
http://www.amazon.com/Sony-STR-DE598.../dp/B0007Y6AN0
Sorry if this is a dumb question.
Paul102691 is offline
post #2 of 4 Old 06-07-2011, 02:02 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Yeah you arent going to damage speaker or receiver by hooking the up impedance probably 8 ohms so no worries
http://www.cerwinvega.com/home-audio...ers/ve-5m.html
crazyrob425 is offline
post #3 of 4 Old 06-07-2011, 02:06 PM
dbx123's Avatar
No such thing as a dumb question if you don't know the answer.
They are reportedly 8 Ohm; http://bookshelf-speakers-review.toptenreviews.com/ (look at the "check list")
dbx123 is offline
post #4 of 4 Old 06-07-2011, 02:06 PM - Thread Starter
Paul102691's Avatar
thanks, really appreciate it
Reply Speakers
