recommendations/suggestions please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-12-2011, 12:03 AM - Thread Starter
Bestboy07's Avatar
Dear Friends:
I am a newbie to this forum with limited/no knowledge on surround sound speaker systems and AV receivers.
I did some research and short listed my options but I am not sure which one may be a best suitable for a open floor plan family room size 166' X 299'. So I would like to hear your recommendations/suggestions please. Recommendations doesn't have to be from my list.
AV Receivers:
ONKYO NR609
YAMAHA RX-A700
DENON AVR-1912
PIONEER VSX-1021-K
SPEAKERS:
POLK Blackstone
BOSE Acoustimass 6 series III
EPISODE ES-500.
Thank you.
Bestboy07 is offline
post #2 of 12 Old 06-12-2011, 12:15 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It would be good to know the budget for the speakers. You
need bigger speakers for that room.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 12 Old 06-12-2011, 02:18 PM - Thread Starter
Bestboy07's Avatar
Hi Jim!
I am not sure if it matters or not but I am planning to install rear speakers in ceiling somewhere in the middle of the room. The reason is we use 1/3 of the room for breakfast area. Coming to the price I am not sure how much I should spend but I am thinking to go for speakers in three more rooms also with zoning option and current budget is around 5K including everything. I can stretch my self little bit if I am compromising on quality.
Hope that this information is useful to recommend me something.
post #4 of 12 Old 06-12-2011, 03:39 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Even though you have a seperate area for breakfast - I would look
at Focal, except for their sub
http://www.spearitsound.com/focal/focal_700_series.htm
I would look at Snell, for in-ceiling speakers
http://www.accessories4less.com/make...er-Each/1.html
For the Subwoofers:
Look over at HSU
http://www.hsuresearch.com/products/vtf-2-mk3.html
Look over at Epik
http://www.epiksubwoofers.com/legend.html
I would make sure that you get a receiver whose rated specs,
are based from 20 hz to 20 khz, and not 1000 khz, to begin
with. If you use 1000 khz specs - then make sure that they are
rated high. The more expensive ones, seem to do better. You
should try to get a receiver with pre-outs, for amps in the future.
For different room zones - check into this
http://www.htd.com/Products/multi-channel-amplifiers
Focal also, has some smaller speakers
http://www.dedicatedaudio.com/inc/se...focal&n=507535
Who AM I
zieglj01 is offline
post #5 of 12 Old 06-14-2011, 05:02 PM - Thread Starter
Bestboy07's Avatar
Thank you, Jim. I know it may be a difficult but could you please tell me how much I should expect for installation?
Any other recommendations/suggestions please.
Thank you
post #6 of 12 Old 06-14-2011, 05:13 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I can not answer, the installation part. Good Luck.
Who AM I
zieglj01 is offline
post #7 of 12 Old 06-15-2011, 08:16 PM - Thread Starter
Bestboy07's Avatar
Jim-
Couple more questions, what do you recommend for outdoor covered patio? And can I use the same in-ceiling speakers in different rooms(zone two)?
Thank you
post #8 of 12 Old 06-15-2011, 08:49 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Jim-
Thank you
Outdoor speaker
Boston
http://www.google.com/products/catal...d=0CEMQ8wIwAw#
Atlantic Tech
http://store.audioholics.com/product...s--white-pair-
You can use the same in-ceiling around the house.
Who AM I
zieglj01 is offline
post #9 of 12 Old 06-15-2011, 09:01 PM - Thread Starter
Bestboy07's Avatar
Thanks a lot, Jim.
post #10 of 12 Old 06-15-2011, 09:18 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Thanks a lot, Jim.
Good Luck!
Who AM I
zieglj01 is offline
post #11 of 12 Old 06-18-2011, 10:53 PM - Thread Starter
Bestboy07's Avatar
Hi Jim-
could you please also recommend me a Volume Control with Impedance Matching unit for my zoned speakers? And also I was thinking about Universal MX880 remote control with MRF-350 RF Base Station. What do you say?
post #12 of 12 Old 06-18-2011, 11:22 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Hi Jim-
http://www.htd.com/Products/Volume-Controls
http://www.htd.com/Products/Whole-House-Audio
As far as universal remote control - your choice!
"And also I was thinking about Universal MX880 remote control
with MRF-350 RF Base Station. What do you say?"
Who AM I
zieglj01 is offline
Reply Speakers
