Subwoofer to pair with Denon 2112Ci and Energy speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-15-2011, 06:51 AM - Thread Starter
dumdedum's Avatar
Hello,
I am beginning to put together my ht system and wanted some help in deciding on a subwoofer, and what else to consider in completing my home setup.
I will be using the HT 90% for videos (80% cable, 10% movies,) 10% for music. My room specs are: Living Room 16x11, which has a dining room 10x8 and a kitchen.
I have purchased a Dennon 2112ci and have 2 Energy CF-70 speakers which I want to use as front. Energy CC10 as my center speaker and 2 Energy CB10 speakers as well.
I'm looking for a sub that will support these speakers and my budget is around 250-300 dollars.
I will be connecting 46" Samsing 3dLED 240Hz TV, and an Xbox and a blu-ray player. All connections would be via HDMI.
Also should I be looking at 16 or 18 gauge cables? I eventually would like to add 2 rear surround speakers to make my system 7.1.
Also with the subwoofer, should I purchase any other cables?
Thanks in advance.
dumdedum is offline
post #2 of 5 Old 06-15-2011, 09:04 AM
smudge981's Avatar
Quoted: 51 Post(s)
Liked: 207
You might get a few bites here but it's probably better if you post this in the subwoofer section.
"I am NOT suffering from insanity... I happen to be enjoying myself!"
smudge981 is offline
post #3 of 5 Old 06-15-2011, 10:38 AM - Thread Starter
dumdedum's Avatar
Thanks. Have posted there.
dumdedum is offline
post #4 of 5 Old 06-15-2011, 10:52 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
You can get the Bic F12, Bic PL200 in your price range. Lots of people are recommending the PL200 and I think it is around $270.
Purchase all your cables from monoprice.com. Very good quality for cheap. This would include subwoofer cable, speaker cables (I like 14ga), HDMI cables, etc.
Subwoofer
Speaker
HDMI
http://www.monoprice.com/products/su...02&cp_id=10240
Afro GT
afrogt is offline
post #5 of 5 Old 06-15-2011, 07:16 PM - Thread Starter
dumdedum's Avatar
Thank you, went with the Bic F12, and surprisingly, Amazon beat Monoprice's total pricing on the banana plugs, subwoofer cable and speaker wires.
Was aware of Monoprice, will use it to purchase HDMI cables soon.
dumdedum is offline
Reply Speakers
Denon Avr 2112ci Receiver
