Help with wiring needs for Jamo 606, Denon 1611 and Bic America F12 subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-13-2011, 05:08 AM - Thread Starter
MTyson's Avatar
What type of wiring do I need for the Jamo 606? I assume it comes with none? Should I get 12 gauge, 14 gauge or 16 gauge? Do I need to add the gold banana connectors or what?
Also, for the Bic America F12 do I just get something like this: http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
And does the F12 do LFE with the Denon receiver? If so, how do I do that? I don't understand this audio stuff too much yet. lol.
MTyson is offline
post #2 of 10 Old 07-13-2011, 05:20 AM
kushum's Avatar
Quoted: 14 Post(s)
? you been on here since 02 and you have over 4k post.
kushum is offline
post #3 of 10 Old 07-13-2011, 06:52 AM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
The Jamo s606 has none. How long are your runs going to be to your speakers? I generally recommend 14gauge. You don't need gold plated banana plugs at all I use just bare wire but if you are frequently connecting and disconnecting your speakers which most people don't do I would recommend them
Yes the denon avr-1611 and Bic f12 does do LFE.
For your cabling needs I suggest
For speaker wire
And for a subwoofer cable
crazyrob425 is offline
post #4 of 10 Old 07-14-2011, 04:29 AM - Thread Starter
MTyson's Avatar
Are you asking me because that is shocking that I've been on her since 2002 and have 4,000 posts or because I've been here since 2002 and have 4,000 posts, but am not 100% sure which wires to use for a non HTIB surround sound system? For never having owned a non HTIB sound system I feel I was pretty close to the ball park. lol. I just felt the need to be totally sure that I was making a good choice.
I've always been more of a videophile and the best sound system I have owned was a Philips HTIB from Wal-Mart. I've never been interested in audio. I thought my Philips sounded great. Now I'm wanting to replace it. So that is why I'm not an expert on hooking up a non HTIB surround sound. I have the general idea, but am cautious not to make silly mistakes thinking I know everything already.
MTyson is offline
post #5 of 10 Old 07-14-2011, 04:46 AM - Thread Starter
MTyson's Avatar
Alright, thanks man. I'm not quite sure yet about the distance. I'm guessing I'll need 25' for each rear speaker and under 10' for the fronts. Unless I put the woofer under my projector. Then it'll be reversed. Long wires for fronts and short for the rears.
Ok great. Does the cabling you recommended for the subwoofer for LFE? I never fully understood the LFE. I thought it was a separate connection or something to get LFE. It always had me a bit confused. lol.
For speaker wire
Thanks very much for all of the help. I'm seriously considering this setup for the near future. It seems like it'll really blow me away compared to my Philips HTIB.
MTyson is offline
post #6 of 10 Old 07-14-2011, 06:57 AM
Quoted: 445 Post(s)
Liked: 339
The wire I suggested works for your setup
Do yourself a favor and read the manual to the receiver cover to cover it's available on denon's site and that might answer your questions
post #7 of 10 Old 07-14-2011, 07:18 AM
afrogt's Avatar
Quoted: 1437 Post(s)
Liked: 982
Or batpigs Denon guide...
http://batpigworld.com/
Afro GT
afrogt is offline
post #8 of 10 Old 07-14-2011, 09:50 AM
schan1269's Avatar
Yeah, the relation of the F12 to the Denon will have ABSOLUTELY NOTHING to do with the speaker wires to the other 5.
Yes, read the Denon/BIC manuals...
schan1269 is offline
post #9 of 10 Old 07-14-2011, 10:19 AM
Gibbsman's Avatar
The cable that you use for LFE is just a standard RCA cable like the Digital Coax/Component, etc cable that crazyrob suggested. On the back of the Denon there is a single LFE jack and on the F12 there will be an LFE Input jack. Just plug one end of each able into the jacks and you're good to go. You don't need to mess with the speaker jacks on the back.
Just a extra bit of info too, when using the LFE jack it disables the crossover and lets the receiver control the crossover.
The batpig site that afrogt recommended has some great materials on setting up Audyssey as well. Well worth a read.
Gibbsman is offline
post #10 of 10 Old 07-15-2011, 12:41 AM
kushum's Avatar
Quoted: 14 Post(s)
I see, just thought its was funny that someone that is familiar with this forum would have these kinds of question, was thinking that you where messing around. That's why you are a wise man my friend. Ask questions and do it right the first time so you don't have to spend more money later.
kushum is offline
Reply Speakers
