5.1 Centre speaker above screen or under ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-15-2011, 04:03 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
What do you guys prefer when placing the centre speaker in a 5.1 system , the centre speaker above the screen or under ?
dazkyl is offline
post #2 of 7 Old 07-15-2011, 04:10 PM
skally's Avatar
Most likley under so its ear level or close.
skally is offline
post #3 of 7 Old 07-15-2011, 04:14 PM
schan1269's Avatar
You need to mount your Bose on the back of the TV and face it towards the wall for the "reflected sound"...
Page 1234 of your manual illustration 5.
schan1269 is offline
post #4 of 7 Old 07-15-2011, 05:05 PM
repomambo's Avatar
^^^^^^^^^...wow
repomambo is offline
post #5 of 7 Old 07-15-2011, 05:25 PM
schan1269's Avatar
Is that "wow" in appreciation of my wit or cause you haven't been following the OP's deluge of moronic threads cause he can't read his owners manuals???
post #6 of 7 Old 07-16-2011, 12:25 AM
Arrec Barrwin's Avatar
I place mine above because a) it makes much more sense aesthetically and b) I like the sound better. It makes for a more seamless sound stage as it will then be on the same vertical level as your rears.
Arrec Barrwin is offline
post #7 of 7 Old 07-16-2011, 05:03 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
It wont tell you to place the centre speaker towards the wall for sound reflex.It tell you to do so for the surround rear speakers but.
dazkyl is offline
Reply Speakers
