Help me find some speakers/surround sound! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 07-18-2011, 10:52 AM - Thread Starter
sncgolf's Avatar
We just moved into a new house and the great room had a Bose Acoustimass 6 in it, but the previous owners took the bass module and left us with just the speakers. So I think we're going to sell the speakers and replace it with something else (from what I hear on this site Bose is not highly regarded!) So we have never had surround sound before and probably won't use it a whole lot so we definitely don't need top of the line and don't want to spend that much on it. We just bought a 52" sharp aquos and don't have a Receiver that goes with 5.1 speakers so we'll have to get that as well. We really don't want to spend over $700 for everything, so what would you suggest to get? Our great room specs are 22x19 with about a 30 foot ceiling. THANKS!!!
sncgolf is offline
post #2 of 23 Old 07-18-2011, 10:56 AM
Arrec Barrwin's Avatar
That's a huge room! I don't think a $700 budget will be enough, honestly. $700 for just a sub, maybe, but for a sub, speakers, and receiver, you are left with very little options, most of which being a HTIB system (which would likely be worse than the Bose). So, I would recommend getting a 5.1 receiver for about $200 (look at Onkyo) and spend the rest on a good sub to fill that huge room. Probably a Hsu VTF-2 Mk3. Then, just upgrade the speakers later on if you want to.
Arrec Barrwin is offline
post #3 of 23 Old 07-18-2011, 10:58 AM
NuSoardGraphite's Avatar
Quoted: 401 Post(s)
Liked: 367
$700?
Check out Denon recievers (recommend the 1611). Some polk or pioneer speakers. Check the subwoofer forums for advice on which sub to get. Just make sure your main speaker package matches (esp front L/R and center. Make sure theyare the same brand and series).
A system like that should be more than good enough for your purposes. For specific model numbers, browse amazon. It'll give you a good idea of the price ranges as well.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #4 of 23 Old 07-18-2011, 11:01 AM
Quoted: 401 Post(s)
Liked: 367
Not even. A cheaper denon, onkyo or sony receiver, inexpensive polk or sony speakers and a $200 subwoofer is still going to be far better than anything from Bose he can get for $700.
post #5 of 23 Old 07-18-2011, 11:16 AM
I disagree. I think allocating more money to the subwoofer, as he has a very large room, would yield a bigger improvement in sound. I've owned cheap Polk speakers, they really aren't that great.
post #6 of 23 Old 07-18-2011, 11:19 AM
Elihawk's Avatar
Quoted: 1336 Post(s)
Liked: 1166
Wow, this seems to be contagious (people leaving the cubes behind)!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #7 of 23 Old 07-18-2011, 12:08 PM - Thread Starter
sncgolf's Avatar
How bad are the bundle sets at like Best Buy, where you get the receivers + the 5.1 system...
And I'm not opposed to buying slightly used speakers
sncgolf is offline
post #8 of 23 Old 07-18-2011, 12:40 PM - Thread Starter
sncgolf's Avatar
What do you think of this set-up for the room and the pricing
http://appleton.craigslist.org/ele/2477295429.html
sncgolf is offline
post #9 of 23 Old 07-18-2011, 12:46 PM
schan1269's Avatar
That is a decent deal. The same Quintets are $340 3rd party on Amazon. $376 directly from Amazon.
From Amazon that stuff is $700 plus the stands. So, $100 less and free stands...and you don't have to wait for UPS.
It looks like he is asking $250 for just the Quintets...or $600 if you take it all.
schan1269 is offline
post #10 of 23 Old 07-18-2011, 01:23 PM - Thread Starter
sncgolf's Avatar
Yeah I didn't know if I should get that Sub too or get a different one to go with the speakers
sncgolf is offline
post #11 of 23 Old 07-18-2011, 01:28 PM
schan1269's Avatar
First...does he still have this stuff?
And, yes that sub is "over priced" if you were buying new...but you aren't. I think(considering what you are getting it for) it compares very nicely to a BIC H100/F12.
$600 is just about right.
Besides, it would be very simple for you to get that sub home, purchase a BIC H100 or F12 from Amazon, try them both out...then either return the F12/H100...or sell the Klipsch to recover what you spent on the BIC.
Lava(being the only other one in the same price class) has a 30 day home trial. If you return the sub, all you are out is shipping back to them...
post #12 of 23 Old 07-18-2011, 01:40 PM - Thread Starter
sncgolf's Avatar
Yeah i'm not 100% if its still available, i emailed him this morning, but no reply yet. Would I be better off going with this Energy System...CNET seems to think highly of it for the price.
sncgolf is offline
post #13 of 23 Old 07-18-2011, 01:46 PM
schan1269's Avatar
Personally, I think these Quintet are too small...but your budget won't allow bigger speakers...
Regardless...with your budget, buy THE BIGGEST speakers from any brand you can find.
Even these would be an improvement over the Quintet...and would cost less...
http://www.amazon.com/Sony-SS-B1000-...1022038&sr=1-1 (two pairs and a center would set you back roughly $180...and I would take these over the Energy or Quintet)
http://www.amazon.com/Sony-SS-B3000-.../ref=pd_cp_e_1 (even better if you got a pair of these instead of one of the 1000)
post #14 of 23 Old 07-18-2011, 01:46 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 338
With a room as big as your I strongly suggest you steer very very clear of these satelite based system. They will struggle to fill your room with sound
Something like the Pioneer speakers or Polk Monitor Series ii would be the best bet with a Bic pl200 subwoofer
crazyrob425 is offline
post #15 of 23 Old 07-18-2011, 02:22 PM - Thread Starter
sncgolf's Avatar
Yeah I guess I was hoping to stay with smaller speakers (and I know my mom won't want big speakers). She got an entertainment center with some smallish cubbies (around 8"x 6") where we could put two in the top corners then maybe a longer middle one, and the opposite room wall has the holes and wires already in the wall from the Bose speakers.
sncgolf is offline
post #16 of 23 Old 07-18-2011, 03:21 PM - Thread Starter
sncgolf's Avatar
sncgolf is offline
post #17 of 23 Old 07-18-2011, 04:12 PM
Quoted: 445 Post(s)
Liked: 338
2 pair of Energy CB-5's, CC-5 center, Bic PL200 subwoofer
That will be better than the Take classic at least
post #18 of 23 Old 07-18-2011, 05:39 PM - Thread Starter
sncgolf's Avatar
So having those 3 speakers in the front of the room, and none in the back are going to be better then the 3 satellites in the front and 2 satellites in the back? Sorry but I really know nothing about speakers/surround sound!
sncgolf is offline
post #19 of 23 Old 07-18-2011, 05:55 PM
Quoted: 445 Post(s)
Liked: 338
Yes with the Bic PL200 but your budget allows for a 5.1 with 4x cb-5's and cc-5 and subwoofer
post #20 of 23 Old 07-18-2011, 07:30 PM - Thread Starter
sncgolf's Avatar
Oh I gotcha, I didn't see the 2 pair of cb-5's. Thanks! I'll check those out...but if i wanted to stay under 700 including the receiver what would u recommend?
sncgolf is offline
post #21 of 23 Old 07-18-2011, 09:45 PM
Quoted: 401 Post(s)
Liked: 367
I'd be on your page if the OP had more than $700 total to spend. I feel his pain as I'm on a limited budget myself and had to take months to put my HT components together and I'm still not done (need a sub still). Some people just want the components all right now and when that is the case, options are limited.
post #22 of 23 Old 07-18-2011, 10:19 PM
Quoted: 445 Post(s)
Liked: 338
I suggest you save up your money for about $300-400.
Honestly with a room your size you need a larger speaker set in general and $700 for receiver and speakers I'd have toy with floorstanders up front with a decent 5.0 speaker set
post #23 of 23 Old 07-22-2011, 06:15 AM - Thread Starter
sncgolf's Avatar
JBL Studio Series s38 (2 pair)
JBL Studio Series s-Center
JBL PB10
i found these on Craigslist and was wondering if you guys had any thoughts on how these are or how they would work in my room...and what price should I ask. He also had an old Sony receiver, but i don't want that one...he is asking $400 for everything, but said he'd sell the speakers without the receiver and said make an offer...
sncgolf is offline
Reply Speakers
