Mounting Martin Logan MLT-2 speakers - AVS Forum | Home Theater Discussions And Reviews
Old 07-20-2011, 03:16 PM - Thread Starter
tanww888's Avatar
Hi,
I want to mount the speakers using mounting brackets. The manual said using #10 screw, but no matter what type of screw I've tried none of them will fit into the two holes in the back. For the center speaker, I want able to mount using the dry wall screws and insert. Thanks for any help!
- Johnny
tanww888 is offline
