Philharmonic Audio - Dennis Murphy - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 453Likes
Old 02-04-2012, 10:56 PM
Solid-State's Avatar
I can't imagine what this rig is going to sound like with all those fantastic best of bread...
"BEST BANG FOR THE BUCK"
the gear is going to have...
SYNERGY!
Solid-State is offline
Old 02-04-2012, 11:07 PM
Eternal Velocity's Avatar
Quoted: 30 Post(s)
Liked: 61
Originally Posted by Dennis Murphy View Post
I think he's talking about basic voicing, not dynamic limitations. But perhaps he can elaborate further.
I mostly just meant that open back or open baffle or panel type speakers give a bit more reflected sound off the wall behind them.
Eternal Velocity is offline
Old 02-04-2012, 11:09 PM
Quoted: 30 Post(s)
Liked: 61
Originally Posted by Solid-State View Post
PS Now I just need to find a deal on an ATI AT2007 and wait for MDS/Emo to finish the XMC
Why not get a 3003 and 1805
Old 02-05-2012, 12:11 AM
hmm... that's good advice. I was thinking I'd use the extra two AT2007 channels for two Bill Fitzmaurice Tuba HT DIY subs! There is a rather large jump to the AT300x modules and I dunno if I really need that kinda power across the front.
I might just have to rethink that if the numbers are right.
Perhaps the AT3003 and an AT1803 or 5 might be smarter. And you're right in saying I should get the AT1805 as the five channel would be easier to resell down the road.
OR
I could just buy the lifer AT3007 but I'd have to have a separate breaker ran for it!
LOL
PS might be a good opportunity to give the circuit an isolated ground... hmm...
Old 02-05-2012, 01:20 AM
pragmatic001's Avatar
I want to ask a bunch of questions, but I think hearing them is the only answer that will satisfy me.
rossandwendy likes this.
pragmatic001 is offline
Old 02-05-2012, 01:26 AM
Okay, I thought of one question worth asking. I'm a classical junkie. How much power would you recommend to get realistic dynamics?
Now, I'm not talking about Loud, I don't care much about that. I think you know what I mean Dennis. That moment when the mallet meets the tympani, a raging brass section.
Do you have an amp you particularly enjoy with your speakers?
Old 02-05-2012, 08:25 AM
Dennis Murphy's Avatar
Quoted: 401 Post(s)
Liked: 582
Hi I'm not really an amp guy. Their basic voicing sounds pretty much the same to me. What I'm concerned about is the ability to drive 4-ohm loads to realistic levels when all the orchestral stops are pulled out. I'm currently using a Van Alstine Inight amp and preamp. It think the amp is rated at 120 watts/channel--higher into 4 ohms--and it takes everything I can throw at it, including the Salk SounScapes. In comparison, my Marsh amp rated at 200 watts shuts down on the Salks just when I'm starting to enjoy things. And I know you're not talking about shere volume. But Wagner should sound like Wagner, and that takes a really well-engineered amplifier.
Dennis Murphy is online now
Old 02-05-2012, 08:51 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Are you using a sub, Dennis?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
Old 02-05-2012, 08:52 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
This reminds me of back in the school days with those multiple choice questions. You know what they say, the first answer is usually the right one.
I would get either AT2007 or AT3007. All depends on your budget. Both will be great.
AcuDefTechGuy is offline
Old 02-05-2012, 09:32 AM
Quoted: 401 Post(s)
Liked: 582
Hi No--neither the 3's nor SoundScapes require one. The 2 doesn't either for 99% of the music I listen to.
Old 02-06-2012, 07:55 AM
woodsart's Avatar
Agreed, Dennis, no sub for me the servo just sits quietly. In fact many times when I was listening in the "pure audio" mode, I could have sworn the sub was on, still......VeRy HaPpY!!!
woodsart is offline
Old 02-06-2012, 08:21 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Am I the only one skeptical about a certain person's claim to (future) purchase? Just curious...
ADTG, what's the ETA buddy?
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
Old 02-06-2012, 09:06 AM
Quoted: 175 Post(s)
Liked: 262
I think Dennis can answer that question better than I.
I believe Del has completed the cabinets, which look very sexy high gloss.
Dennis might be waiting for some packing materials to arrive. We want to reduce the risk of scratching those sexy high gloss cabinets.
Old 02-06-2012, 09:34 AM
Quoted: 401 Post(s)
Liked: 582
Hi I've got all kind of wrapping. But Del also has a boatload of cabinets for me to pick up, and I want to do it all at once with a van(he's about 70 miles away). So I'll have to wait until everything this ready, tentatively scheduled for Friday.
Old 02-06-2012, 09:54 AM
bfreedma's Avatar
Liked: 51
No, you aren't...
bfreedma is offline
Old 02-06-2012, 12:06 PM
Quoted: 175 Post(s)
Liked: 262
No rush on my part, Dennis.
Old 02-06-2012, 04:24 PM
Is the top and bottom boxed separately? Also did you get formed foam made-up when you had the cabs from Asia for the 2s manufactured? I didn't think you'd be using bubble wrap if that's what you mean Dennis. I'd thought the Phil 2 cabs would come from Asia boxed like a loudspeaker manufactured there less drivers and xover.
No double boxed with formed foam inserts?
Also because the XMC1 release will affect my ATI purchase, I was wondering about experience driving these speakers with Emotiva XPA modules. I have a stack of UPA1 monoblocks that are basically XPA modules with their own PSU and more capacitance. I probably will be using those amps until late spring early summer.
Here is an Audio Precision report with a 4ohm load.
http://emotiva.com/upa1/upa1_4ohm.pdf
Old 02-06-2012, 05:50 PM
Quoted: 401 Post(s)
Liked: 582
Not to worry. All of the Philharmonics have custom foam endcaps and double boxing. The lower and upper cabinets are boxed separately, each with the endcaps and double boxes. The wrap I'm talking about is just to provide protection when I pick them up from the cabinet shop and work with them during assembly. I've never had the Emotiva in my house, but any decent amplifer with at least 100 watts/channel into 4 ohms would work fine with the 2's.
Old 02-06-2012, 07:02 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
What are you waiting for Solid-State? You've asked more questions than they do in a presidential debate. Place the order already!
Nuance is offline
Old 02-06-2012, 07:41 PM
Quoted: 175 Post(s)
Liked: 262
I'll be placing an order soon Dennis!
Here is the place to buy ATI. Authorized ATI dealer. Full 7 yr warranty.
The AT1807 is only $2K. Spec very conservatively says 180wpc 8ohms, but will probably do 200wpc 8ohms.
http://www.classicaudioparts.com/ind...fiers.html?p=1
Old 02-08-2012, 01:09 AM
On Dennis's site there is a huge section with all kinds of test on the MLTL bass section of the loudspeaker.
I can imagine it's bass performance is fantastic looking at those measurements.
With 30 watts into the SB driver Dennis is outputting 100 dB plus from 40Hz up. It starts it's dive at about 36 Hz. With the Revelator it starts it's dive at 28 Hz.
These speakers are serious business in the bass department!
Is it possible to see full gate 6ms quasi-anechoic at 90 dB ?
(farfield with short gate, farfield with a long gate, and splice of nearfield/farfield)
I'm learning here... at 1m + would that help to create a decent reading below 200 ?
Old 02-08-2012, 06:48 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
^ And the questions begin...AGAIN. I predict he never buys a pair...
Nuance is offline
Old 02-08-2012, 07:59 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Awwww, I'm sure he wouldn't let an opportunity slip through his hands like this guy.
Chu Gai is offline
Old 02-08-2012, 08:08 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
LOL! I have more faith in Wes than SS.
Nuance is offline
Old 02-08-2012, 09:52 AM
Quoted: 175 Post(s)
Liked: 262
That wasn't the only opportunity that slipped through the Patriot's hands. How can a linebacker beat out 6'6" Gronkowski for that jump ball? Don't even start.
I'm telling you. It was destiny. Again. Deja vu.
Old 02-08-2012, 09:58 AM
Quoted: 175 Post(s)
Liked: 262
I think he wants to score the ATI amps first. Maybe undecided on speakers. Or trying to fit his budget. Or still negotiating with the boss, I mean wife.
Old 02-08-2012, 10:03 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Follow his posts...that's all I'm sayin'.
Nuance is offline
Old 02-08-2012, 10:33 AM
grubadub's Avatar
Quoted: 92 Post(s)
Liked: 97
too bad gisele wasn't on that route. she would've wrestled it away from the linebacker for sure
but i digress. what would be the minimum size room needed for these phil2's?
'...have an A1 day!'
grubadub is offline
Old 02-08-2012, 10:44 AM
Quoted: 30 Post(s)
Liked: 61
In general, it's best to give your head 4+ feet from the wall behind you, speakers 3+ feet from the side wall, and the phils will need a few feet from front wall as they are a deep speaker.
It's generally preferable to give speakers 6+ feet distancefrom each other (mine are over 10feet apart) and i'd probably sit 6+ feet away from most multi way. The taller the ceiling the better. A carpet or rug on the floor is normally a good idea.
What is your room like??
Old 02-08-2012, 10:53 AM
grubadub's Avatar
Quoted: 92 Post(s)
Liked: 97
actually, i'm house hunting so i don't know yet. thanks for the response.
grubadub is offline
