Philharmonic Audio - Dennis Murphy - Page 189 - AVS Forum | Home Theater Discussions And Reviews
 413Likes
post #5641 of 5645 Old Yesterday, 09:05 PM
Elihawk's Avatar
Quoted: 927 Post(s)
Liked: 788
I think the RAAL 64-10 is OEM, but yes the RAAL70-10 runs about 300/pair!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #5642 of 5645 Old Yesterday, 10:06 PM
Dennis Murphy's Avatar
Quoted: 374 Post(s)
Liked: 567
Right--there's no way I could use the 70-10 in any speaker that was even close to being affordable. The 64-10 is not nearly as heavy-duty as the 70-10. If crossed within its optimal operating range, and then very carefully, it can provide sound nearly equal to the 70-10. But in a 2-way, it takes very careful design work and a woofer with exceptionally smooth, broadly dispersed sound up to 3 kHz. I haven't found any 6.5" woofers that qualify, so some sacrifice in bass reach is inevitable. Still, the 5" I'm using can provide useful response to 50 Hz in the ported version.
Dennis Murphy is online now
post #5643 of 5645 Old Yesterday, 11:34 PM
Quoted: 681 Post(s)
Liked: 416
Is there a minimum listening distance recommended for either the Philharmonitor or the BMR Philharmonitor? Specifically, would one work better (or would both or neither) in a 'sitting on top of a computer desk about 1.5 - 2 feet' from the listener type situation?
TuteTibiImperes is online now
post #5644 of 5645 Old Today, 09:26 AM
Quoted: 374 Post(s)
Liked: 567
A number of people have used the BMR nearfield on computer desks, but it wasn't designed for that. The 3 drivers won't integrate optimally up close, and the bass could get boomy with a flat surface below the big woofers. The Philharmonitor would be a better choice, or the forthcoming smaller Philharmonitor referenced above.
post #5645 of 5645 Old Today, 12:35 PM
Liked: 4
Originally Posted by Dennis Murphy View Post
'Cause then they wouldn't be affordable. Also, the RAAL can't make it down nearly low enough to mate with the woofer. The woofer's response drops like a cliff at 2 kHz, and the RAAL is only good to 3 kHz at best. I am working on a Quasi-Affordable monitor using a custom version of the RAAL and hope to have that out soon. It will use a very high quality but not super-expensive 5" driver that is very smooth up to 3 kHz and works in either a .38 cut foot ported cabinet or a .25 cu ft sealed cabinet.
Looking forward to seeing/hearing these in the future.
ad5wb is online now
Reply Speakers
