What speakers to get for a small bedroom. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-30-2011, 09:13 PM - Thread Starter
Bcfoy's Avatar
I currently just use the stock speakers on my vizio 37 inch tv (http://www.walmart.com/ip/Vizio-E370VL/13904833). It's okay but I would like to improve. I have a small to medium size bedroom and it is a bit cramped (Full Sized Bed in Left corner, a two person couch to the right of that, a computer desk in front of my bed, and my tv set in the front of my room in the wall space between my closet and door). The TV sits on a 3 shelf glass stand (http://www.walmart.com/ip/Accsense-W...Glass/10752189). The top shelf holds my tv, the second shelf holds my PS3 (Hooked up via HDMI), and the third is currently empty. I have been using this set up for over a year now and can tell that I'm missing something when I am watch a Blu-Ray movie or playing a game. I would appreciate any suggestions. I'm in no way an audiophile, but I do know the difference between good sound and mediocre sound.
Bcfoy is offline
post #2 of 11 Old 07-30-2011, 09:30 PM
bdbrown's Avatar
Budget?
bdbrown is offline
post #3 of 11 Old 07-30-2011, 10:01 PM - Thread Starter
Bcfoy's Avatar
Originally Posted by bdbrown View Post
Budget?
I'd like to keep it below 400 if possible.
Bcfoy is offline
post #4 of 11 Old 07-30-2011, 10:23 PM
afrogt's Avatar
Quoted: 1369 Post(s)
Liked: 948
So are you just looking for speakers or a receiver and speakers?
Afro GT
afrogt is offline
post #5 of 11 Old 07-30-2011, 11:09 PM - Thread Starter
Bcfoy's Avatar
If a receiver won't take up a lot of room or over complicate it, sure. I could go either way though.
Bcfoy is offline
post #6 of 11 Old 07-31-2011, 05:50 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
How about these?
Kidding! Some guys have really liked these:
http://shop.avid.com/store/product.d...24141988261072
They are self powered so you can hook them up to the variable out and still control the volume via your TV remote.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #7 of 11 Old 07-31-2011, 07:48 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
A Polk system for around $200 and a basic receiver might be your ticket.
bladerunner6 is offline
post #8 of 11 Old 07-31-2011, 08:08 AM
bdbrown's Avatar
YAMAHA RX-V371 5.1-Channel AV Receiver - $229 with a $50 gift card (ends today)
http://www.newegg.com/Product/Produc...82E16882115313
You'll get the gift card via email 4-5 days after you order the receiver.
Polk Audio RM6750 Black 5.1CH Home Theater Speaker System - $199 less gift card = $149
http://www.newegg.com/Product/Produc...82E16882290066
Net total $378.
bdbrown is offline
post #9 of 11 Old 07-31-2011, 08:51 AM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
This sound like you may need to check into what a surround sound system consist of.
With what little space you have, you might want to get some satellite speakers and mount them up high, and have them aimed toward the listen area.
That would be pretty much what bdbrown has shown.
HAMP568 is offline
post #10 of 11 Old 07-31-2011, 09:47 AM
zieglj01's Avatar
Quoted: 1565 Post(s)
Liked: 1417
Take a look at some JBL active speakers, you will not need a receiver
with them
http://www.fullcompass.com/product/365496.html
__________________________________________
Who AM I
Speakers -- Snell K7 > Q Acoustics 3020 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is offline
post #11 of 11 Old 07-31-2011, 02:59 PM - Thread Starter
Bcfoy's Avatar
Thank you for all of the reply's. I have been considering a 5.1 system, but considering my room size and the cramped nature of it, how would that work out? And is installation going to be difficult? We are moving next year and my dad has said I can put a surround system in my room of the new house so I was just going to wait till then for a 5.1. Right now I am more looking for something to hold me over till then.
Bcfoy is offline
Reply Speakers
