rear surround sound speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-04-2011, 05:41 PM - Thread Starter
ishak's Avatar
what are the best rear speakers under 500 dolars
ishak is offline
post #2 of 10 Old 08-04-2011, 06:36 PM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
That is kind of vague. What type are you looking for? Monopole, bi-pole, di-pole. Horn loaded or dome. What does the rest of your system consist of? I may not be able to give you the best answer, but with this info I think the rest of the members may be able to help you better.
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #3 of 10 Old 08-04-2011, 06:49 PM
schan1269's Avatar
There is no such thing as "best", there is "what fits your system best"...
schan1269 is offline
post #4 of 10 Old 08-04-2011, 06:51 PM - Thread Starter
ishak's Avatar
i just bought a bower and wilkins center channel speaker and i have sony floorstanding speakers with sony rear speakers
ishak is offline
post #5 of 10 Old 08-04-2011, 07:06 PM - Thread Starter
ishak's Avatar
im going to upgrade to bowers and wilkins floorstanding speakers in the future if that helps
ishak is offline
post #6 of 10 Old 08-04-2011, 08:15 PM - Thread Starter
ishak's Avatar
So what fits my system best
ishak is offline
post #7 of 10 Old 08-04-2011, 08:52 PM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
Sorry but I know nothing about B&W speakers. All I can tell you is your surrounds are not a important your mains, so if you are OK with the way the Sony speakers sound put that money towards getting your towers.
Smigro is offline
post #8 of 10 Old 08-05-2011, 08:51 AM
toofarzong's Avatar
I agree with Mr. Smigro 100%. You will notice a much bigger difference if you get a pair of quality towers.
toofarzong is offline
post #9 of 10 Old 08-05-2011, 10:15 AM
al2fast's Avatar
get the new b&w front speakers you want to match the center you have. then use the sony's you have upfront now as your rear/surround speakers and replace them when you have the money or get the itch.
al2fast is offline
post #10 of 10 Old 08-05-2011, 10:28 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Klipsch make some good surrounds IMO. Surrounds typically only need to handle higher frequencies and Klipsch horns are great at that. You may be better off buying a 5 speaker system and use the non-center for your 4 surrounds. It's frequently less expensive to buy 5 as a set than to buy 4 individually. You can almost certainly get a decent set for under $500.
KidHorn is offline
Reply Speakers
