Speaker Shootout!! - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #451 of 1153 Old 10-05-2011, 12:24 PM
Smigro's Avatar
Quoted: 226 Post(s)
Liked: 221
You'll pick it up in no time at all. there is always more to learn, naturally, but just to get the grand jist of things, read up all you can, ask questions when you hit road blocks. Most importantly, experiment and try new things out!! It hasnt even been a full year since I joined and the information ive learned just over this past year has put me WAY ahead of the knowledge I had coming into it
I don't want to derail the thread, was just curious is all. Sometimes reading through all of these graphs makes me feel like a complete noob sometimes. Guess it is time to get some of the software people use on here and see what I can learn in my own time.
Ed
Panasonic VIERA TC-P60ST60 Plasma, Onkyo TX-NR1008 receiver, OPPO BDP-83 region free, Xbox One, PS4, eD[c]12 LCR, Klipsch R-14M surrounds, Rythmik FV15HP sub
Xbox GT / PSN ID - Smigro
BD collection http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is online now
post #452 of 1153 Old 10-05-2011, 01:01 PM - Thread Starter
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
I am still learning and ask questions all the time. I am just having fun. Some say you need flat to 3 hz and others say no as bAss is concerned. I can tell you that the bass with both is just crazy. I just happen to like to play what is on the disc and damn it, 3hz is there. Oh well and it keeps me trying new gear
Marantz 7702 Atmos
MKtheater is online now
post #453 of 1153 Old 10-05-2011, 01:47 PM
BiGBADDABOOM's Avatar
By the way, MK I think what you want is the 2ohm IB318's. 4 in series on each channel of the FP14000?
Probably need a second opinion from someone who knows what they're talking about. I'm not sure I've got the math right there, or haven't missed another obvious alternative.
BiGBADDABOOM is offline
post #454 of 1153 Old 10-05-2011, 02:22 PM - Thread Starter
MKtheater's Avatar
Liked: 1123
Thanks this is info I need very soon though so I can get the ball rolling.
Marantz 7702 Atmos
post #455 of 1153 Old 10-05-2011, 02:51 PM
Point Source
beastaudio's Avatar
Quoted: 3546 Post(s)
Liked: 2852
Check that! four 2 ohm drivers wired is series will yield an 8 ohm load per channel. parallel is not doable as it will show a .5 ohm load.
beastaudio is offline
post #456 of 1153 Old 10-05-2011, 03:17 PM - Thread Starter
MKtheater's Avatar
Liked: 1123
How do I wire this up from driver to driver to amp channels?
Marantz 7702 Atmos
post #457 of 1153 Old 10-05-2011, 03:53 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Do you want to wire them up for 4 or 8 ohm? If you want a 4 ohm load then get 4 4ohm subs and use the calculator below to wire them up:
http://www.the12volt.com/caraudio/wo...4&I=41#results
4ohm subs would probably be better for re-sale as well.
mjaudio is offline
post #458 of 1153 Old 10-05-2011, 04:41 PM - Thread Starter
MKtheater's Avatar
Liked: 1123
I guess I would want a 4 ohm load so the amp is running 2 4 ohm loads per channel. The amp can handle that than I am fine. I still don't understand the wiring.
Marantz 7702 Atmos
post #459 of 1153 Old 10-05-2011, 05:12 PM
The only problem with that is you're now feeding 1100w per driver instead of 587.5w:
post #460 of 1153 Old 10-05-2011, 07:23 PM
Point Source
beastaudio's Avatar
Liked: 2852
the amp wont be running 2 four ohm load perchannel, you wire the speakers up together and into the amp so with doing 8 speakers, your impedance for four four ohm speakers per channel will be a choice between 1 ohm and 16 ohm, neither will work. the two ohm setup you had decided on is perfect and running the amp at 8 ohms, youll never have any problems.
post #461 of 1153 Old 10-06-2011, 05:17 AM - Thread Starter
MKtheater's Avatar
Liked: 1123
I am sorry but I still don't remember how to wire the drivers together. I did this once for buttkickers. Will all 4 drivers be wired in series or from + to - ?
Marantz 7702 Atmos
post #462 of 1153 Old 10-06-2011, 05:48 AM
Smigro's Avatar
Quoted: 226 Post(s)
Liked: 221
From my days in car audio, I used to have a Chevy S10 low rider with 6 12" JLW6, and I think that is how I had them wired.
Ed
post #463 of 1153 Old 10-06-2011, 07:17 AM
Point Source
beastaudio's Avatar
Liked: 2852
go to the link that mjaudio linked, and put them in a series (really series/parallel wiring), basically think of the drivers in pairs. You will have TWO pairs of drivers PER channel of the amp. You will only have ONE +/- wire going back to the amp PER CHANNEL. for each pair of subs, you wire one driver's positive to the other driver's negative, do this for both pairs, no wire should be going to the amp yet, just a wire from the + of one driver to the - of the second driver in the pair.
now lets look at a single channel of the amp. You now have 4 drivers, each with only ONE of the + or -'s free, that means you have two positives and two negatives free if you are doing it right so far. wire the two negative wires together with a single lead heading back to the amp and the two positives together with a single wire back to the amp. Now you have one channel done, did I lose you anywhere? haha now do it all over again for the other four drivers on the second channel DONE
this will yield the same impedance as the drivers you are wiring to correct my previous statement. true series wiring for 2 ohm drivers will get you 8 ohm, the above on 2 ohm will get you 2 ohm.
post #464 of 1153 Old 10-08-2011, 10:17 AM - Thread Starter
MKtheater's Avatar
Liked: 1123
It looks like the JTRs will get here first. They ship on monday.
Hey guys, can the FI IB3 fit into a 10 cubic foot box? I mean 2 of them. Just checking all options.
Marantz 7702 Atmos
post #465 of 1153 Old 10-08-2011, 10:33 AM
penngray's Avatar
Liked: 43
That means 5 cuft worth of volume to each driver. They are not meant for small sealed enclosures, I do not think they model all that well either.
penngray is offline
post #466 of 1153 Old 10-08-2011, 10:35 AM
penngray's Avatar
Liked: 43
2 drivers 2 ohms each wired in series (+ wired to - ) will yield 4 ohms. If you want to see wiring, just google "series wiring", lots of pics out there.
penngray is offline
post #467 of 1153 Old 10-08-2011, 11:32 AM - Thread Starter
MKtheater's Avatar
Liked: 1123
Thanks Penn I will stick with IB then. I am just wondering how or what I should be using for the wall(construction). I will then have to seal the speakers very well too.
Marantz 7702 Atmos
post #468 of 1153 Old 10-08-2011, 11:45 AM
smbsocal's Avatar
Liked: 25
Looking forward to the review. . .
smbsocal is offline
post #469 of 1153 Old 10-12-2011, 06:54 AM
smbsocal's Avatar
Liked: 25
Did the JTRs arrive?
smbsocal is offline
post #470 of 1153 Old 10-12-2011, 07:27 AM - Thread Starter
MKtheater's Avatar
Liked: 1123
Thursday.
Marantz 7702 Atmos
post #471 of 1153 Old 10-14-2011, 08:07 AM
mojomike's Avatar
Liked: 30
Updates???
mojomike is offline
post #472 of 1153 Old 10-14-2011, 12:04 PM
Dbuudo07's Avatar
Quoted: 218 Post(s)
Liked: 194
Originally Posted by mojomike View Post
updates???
+1
David Budo
Dbuudo07 is offline
post #473 of 1153 Old 10-15-2011, 08:11 PM
jmalto's Avatar
Hmm.. I feel a disturbance in the force.
jmalto is offline
post #474 of 1153 Old 10-15-2011, 08:21 PM - Thread Starter
MKtheater's Avatar
Liked: 1123
Delivery guy had the wrong number so I have to wait until Monday now. We are getting really close. I am also building an IB to replace the F-20's just because.
Marantz 7702 Atmos
post #475 of 1153 Old 10-15-2011, 08:34 PM
dbldare's Avatar
Now I guess we know what the great disturbance in the force was
Sorry James....
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #476 of 1153 Old 10-18-2011, 11:40 AM
Delivery guy... success?!
post #477 of 1153 Old 10-18-2011, 11:46 AM - Thread Starter
MKtheater's Avatar
Liked: 1123
Tomorrow from 1-5 is delivery time.
Marantz 7702 Atmos
post #478 of 1153 Old 10-18-2011, 01:50 PM
Bunga99's Avatar
Liked: 39
Thats great but how's your recovery going for the knee surgery? Please remember to take it easy. I have a good friend that had the knee replacement surgery just a month ago and he went overboard with trying to walk to quick and doing to much at all at once and now he's back in the hospital having that same knee worked on again.
Thx,
Claude
Bunga99 is online now
post #479 of 1153 Old 10-18-2011, 01:55 PM - Thread Starter
MKtheater's Avatar
Liked: 1123
Thx,
Claude
Thanks. My younger friends want me to be better already but have no idea how long a double TKR really takes. Walking is easy but bending and getting to a certain degree is much more important. I can tell you guys that the pain is worse than anything I have felt before. It is crazy!! I try to get my friends to carry and move everything as I can not an should not.
Marantz 7702 Atmos
post #480 of 1153 Old 10-18-2011, 02:27 PM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Best luck on your recovery, MK!
Maybe you better NOT have the delivery guy knocking at your door by now, as you might be tempted to do some extra effort carrying your new babies inside, though
Wish you all the best
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is offline
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl Professional 4645c Cinema Thx Subwoofer
