Speaker Shootout!! - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #811 of 1153 Old 01-10-2012, 09:52 AM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Originally Posted by AV Science Sales 5 View Post
... After having this kind of mid-bass, I don't know that I can ever go back to an 80hz crossover.
Mind to elaborate??
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is offline
post #812 of 1153 Old 01-10-2012, 10:26 AM
Bill Fitzmaurice's Avatar
Liked: 4629
Originally Posted by Avliner View Post
Mind to elaborate??
Probably it's his reaction to the totally enveloping midbass. The problem achieving that is the directional information you start getting above 80Hz. If you must place the subs well away from the mains that gets to be a problem. If you can keep the subs closer to the mains, or if you have so many subs that you can't easily directionally locate them, it's not a problem. My David tower speakers run the sub up to 200Hz, no problem, but that's because the sub and MTM are in the same vertical footprint.
Bill Fitzmaurice is online now
post #813 of 1153 Old 01-10-2012, 10:49 AM - Thread Starter
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
Agreed, I was worried that my surrounds would sound weird with the Midbass coming from the front and the highs from the back but with subs all the way across the front room you can't tell. Now this is with movies.
Btw guys, I tried an 80hz crossover and it still sound great! Why? Because the DR-200 is still at 98+ dB's with 1 watt and the 280's are 3-4 dB's higher. So they still can do it they will just have a slight decrease in output that will hardly be missed during movies. The reason I notice it is because I have 8 18's doing Midbass!
Marantz 7702 Atmos
MKtheater is online now
post #814 of 1153 Old 01-10-2012, 12:25 PM
Avliner's Avatar
Quoted: 28 Post(s)
Liked: 34
Thanks a bunch Bill & MK
Regards, Chuck
Avliner is offline
post #815 of 1153 Old 01-11-2012, 09:00 AM - Thread Starter
MKtheater's Avatar
Liked: 1116
Hey guys, $100 each for the T-39's, the DR-200 is spoken for. If you want midbass these are the ticket!
Marantz 7702 Atmos
post #816 of 1153 Old 01-11-2012, 11:19 AM
carp's Avatar
Quoted: 2486 Post(s)
Liked: 1741
You don't plan on selling the custom eD's do you?
carp is offline
post #817 of 1153 Old 01-11-2012, 12:03 PM - Thread Starter
MKtheater's Avatar
Liked: 1116
Yes I am. Not a fire sale but cheaper than I paid. I could just return them too.
Marantz 7702 Atmos
post #818 of 1153 Old 01-12-2012, 06:25 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
I am going to cool it for a couple months and start more measuring and tweaking. I have not measured since the change yet. An AVS member came over this weekend and I sent him home with a F-20, Ashly 2002 amp, and 2 60 inch high super chunk bass traps. He also got 3-4 2 inch insulation for acoustic panels. Oh ya, all for $100!
Please do some measurements, before and after EQ. For people with AT screens and a lower budget that want big sound, DRs may be the ticket, as long as they are aimed properly.
Very interested to see what you think of the WH. I think that they will work well once EQ'ed.
Also, PICS?
JSS
maxmercy is offline
post #819 of 1153 Old 01-12-2012, 08:48 AM - Thread Starter
MKtheater's Avatar
Liked: 1116
Also, PICS?
JSS
Once everything is in place I will do everything, measurements, pics, no EQ, with EQ, etc.. The DR's absolutely need aiming because they act like a line array. However, they were made for stacking so if I ever wanted to I could stack 4 of them and then aiming would not be needed at all. Right now I have them firing downward with the top of the cabinet about 60 inches high. I am not sure of the angle but they are about 30 degrees or so. If I stand up(75 inches) I lose lots of spl and feel since I am out of the line array. They also don't have crossovers, just LP and HP filters. I just let MCCAC do its thing and listen to it afterwards. They sound great and good enough to return the eD's and everything else. They are my favorite speaker right now.
Marantz 7702 Atmos
post #820 of 1153 Old 01-12-2012, 04:37 PM
Crockettnj's Avatar
Originally Posted by mktheater View Post
hey guys, $100 each for the t-39's, the dr-200 is spoken for. If you want midbass these are the ticket!
pm
Crockettnj is offline
post #821 of 1153 Old 01-12-2012, 04:44 PM
Brad Horstkotte's Avatar
Liked: 68
So by aiming you mean in the vertical plane? I assume since they're supposed to have wide horizontal dispersion, that they woudn't necessarily need aiming in the horizontal plane (toe in)?
Brad Horstkotte is offline
post #822 of 1153 Old 01-12-2012, 06:31 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Good question, Brad. The DRs absolutely need to be aimed carefully in the vertical direction, the best sound will be orthogonal to the midpoint of the tweeter array. I have never seen a horizontal off axis graph for a DR200 save for this one:
I would imagine that some horizontal aiming of L/R could be of benefit, but without more off-axis measurements (5 to 10deg increments), one cannot be sure.
DR280, being wider, would probably begin to have the drop in off axis spl at a lower freq, but it is designed as a 'longer throw' cab.
You up for off-axis measurements of a DR, MK?
JSS
PS - I have my L/R crossover at 200Hz, and my THT mouths are just below and to the right of my L/R speakers. All other speakers cross in at 110Hz.
maxmercy is offline
post #823 of 1153 Old 01-12-2012, 07:09 PM - Thread Starter
MKtheater's Avatar
Liked: 1116
JSS
I will once I escape. I have not had time to measure with the new baby. The only time I have been in the theater lately is when a member picks up some subs or speakers and then I ran a demo. I did toe in the left and right speakers a bit but not much. I will measure when I can. I know the dialog is crystal clear off axis just from demos. The member you just bought the F-20 comments on 4 things, the projector and screen, the clarity of vocals, and the bass.
Marantz 7702 Atmos
post #824 of 1153 Old 01-19-2012, 04:43 AM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
I read your entire thread in one setting. Incredible! Btw, what pj and screen do you have?
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #825 of 1153 Old 01-24-2012, 06:23 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Bump. Anything new MK?
MANCHESTER UNITED!!
Reddig is offline
post #826 of 1153 Old 01-25-2012, 06:37 AM
BBDrums's Avatar
He should be getting his BFM Wedgehorn 6's today. I'll bet he'll comment after he's heard them.
BBDrums is offline
post #827 of 1153 Old 01-25-2012, 07:39 AM - Thread Starter
MKtheater's Avatar
Liked: 1116
I am using a seymourAV XD screen(139 inches) with a pioneer elite projector. It is a JVC Rs2 clone.
Nothing new, I will receive my surrounds today and recalibrate and EQ everything and then take pics of the setup. It might happen this weekend.
Marantz 7702 Atmos
post #828 of 1153 Old 01-25-2012, 12:57 PM - Thread Starter
MKtheater's Avatar
Liked: 1116
Update coming soon! The 4 wedges have arrived!
Marantz 7702 Atmos
post #829 of 1153 Old 01-25-2012, 06:56 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Good deal, await your review!
JSS
maxmercy is offline
post #830 of 1153 Old 01-25-2012, 07:06 PM
Mike Garrett's Avatar
Quoted: 5556 Post(s)
Liked: 3541
Mind to elaborate??
I have a sub in each corner of the room.
mjgarrett100@gmail.com
Mike Garrett is offline
post #831 of 1153 Old 01-26-2012, 10:25 PM - Thread Starter
MKtheater's Avatar
Liked: 1116
Ok guys I just installed the wedge 6's as my 4 surrounds and let my AVR EQ them and listened to 2 movies, Tron legacy and LOTR:ROTK and these surrounds kick major butt! They perfectly match the DR's as the theater now sounds more coherent than ever, like when I had 7 identical speakers. They are dynamic and clear, I am impressed! I need more testing but so far love them. I have not heard any system sound this detailed and clear with this much dynamics. Once I clean up a bit I will take pics and then start measuring. For some reason my reference level is now about -10 dB on the MV because above that it is louder than my processor amp combo at 0 dB MV. I am not sure why as they both are THX ULTRA 2 products. I will measure with my meter making sure the levels are the same when I used them before.
Marantz 7702 Atmos
post #832 of 1153 Old 01-26-2012, 10:33 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
What are the wedge sixes? Link?
beastaudio is offline
post #833 of 1153 Old 01-26-2012, 10:49 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
Great news! Can't wait to see measurements...
JSS
maxmercy is offline
post #834 of 1153 Old 01-26-2012, 11:04 PM
Liked: 68
http://billfitzmaurice.info/Wedgehorn.html
post #835 of 1153 Old 01-26-2012, 11:19 PM
Point Source
beastaudio's Avatar
Liked: 2826
Thanks b. I assumed they were bfm designs after i posted an looked them up. Whats the f3 on those guys? I assume you loaded them with the upgraded 6's MK?
post #836 of 1153 Old 01-27-2012, 06:31 AM - Thread Starter
MKtheater's Avatar
Liked: 1116
I let my AVR pick the crossover point and it is 150hz for all the speakers. I am using all stock BFM speakers. If I needed more spl I would upgrade.
Marantz 7702 Atmos
post #837 of 1153 Old 01-27-2012, 09:32 AM
Point Source
beastaudio's Avatar
Liked: 2826
IIRC you now cross from there straight to the subs right? You dont have any MBM or the 280s?
post #838 of 1153 Old 01-27-2012, 09:38 AM - Thread Starter
MKtheater's Avatar
Liked: 1116
Correct, I use DR-200's up front and 4 wedge 6's for the surrounds crossing over at 150hz to my 4 SS18.2's and it sounds awesome! I have to take measurements and Pics.
Marantz 7702 Atmos
post #839 of 1153 Old 01-27-2012, 04:55 PM
dbldare's Avatar
Hey MK what are the dimensions of the DR-200's?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #840 of 1153 Old 01-27-2012, 05:31 PM - Thread Starter
MKtheater's Avatar
Liked: 1116
dbl
Around 19 inches cubed
Marantz 7702 Atmos
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl Professional 4645c Cinema Thx Subwoofer
