Speaker Shootout!! - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 1163 Old 08-25-2011, 12:31 PM
brandonnash's Avatar
Liked: 33
Or just buy a pair of used la scalas. I've seen them on craigslist as low as $250 each. If you're really wanting to build some just take the drivers from it and build an enclosure and crossover.
brandonnash is offline
post #182 of 1163 Old 08-25-2011, 12:51 PM
penngray's Avatar
Liked: 47
Its a big tweeter upgrade
penngray is offline
post #183 of 1163 Old 08-25-2011, 02:35 PM
fatsow's Avatar
Quoted: 136 Post(s)
Liked: 63
Originally Posted by BiGBADDABOOM View Post
You should check out the JBL PRX635, MK. Active three-way; should come in under your limit for speakers in this shootout.
I to am interested in this speaker. I have been researching it, and would love to hear some. I wonder how it would sound in the home.
fatsow is offline
post #184 of 1163 Old 08-27-2011, 02:20 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
It's Saturday, MK.....
Did you get everything?
JSS
maxmercy is offline
post #185 of 1163 Old 08-27-2011, 02:53 PM - Thread Starter
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1305
JSS
Yes I did, the T-39 30 inch are massive!! My plan is to run my Left and right mains with a DR-200 top and a T-39 20 inch bottom. The center is going to be dual DR-200's stacked with a T-39 30 inch bottom. I need to convert my binding posts to speakons and rearrange everything to fit and look cool!!! I will get some pics up ASAP!
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is offline
post #186 of 1163 Old 08-27-2011, 03:21 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Nice......looking forward to it!!!
JSS
maxmercy is offline
post #187 of 1163 Old 08-27-2011, 03:33 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
I am now looking for new surrounds. Besides the jbl cinemas any ideas? I want to avoid the x- curve in cinema speakers.
Marantz 7702 Atmos
post #188 of 1163 Old 08-27-2011, 04:17 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
What do you guys think? jbl 8320 or eD e6? Surround duties only.
Marantz 7702 Atmos
post #189 of 1163 Old 08-27-2011, 05:44 PM
Brad Horstkotte's Avatar
Liked: 72
How much depth do you have to work with for the surrounds? I seem to recall that you had considered the SHOs for surrounds at one point?
I have the PRO-10s for surrounds and am very happy with them - but I built my column depth deep enough to bury them in there.
Brad Horstkotte is offline
post #190 of 1163 Old 08-27-2011, 05:46 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
They might be too big for surrounds.
Marantz 7702 Atmos
post #191 of 1163 Old 08-27-2011, 06:39 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Cant wait to hear what you think about the DR/T39 combo vs your old JBL setup.
I cant decide on what design I want to build but hearing your opinion will help.
Stuck between a JBL style pro cinema speaker or something like this or E wave.
chrapladm is online now
post #192 of 1163 Old 08-27-2011, 07:05 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
They have the hf of the m&k so adding the bottoms I was hoping to gain Midbass of the jbls.
Marantz 7702 Atmos
post #193 of 1163 Old 08-27-2011, 08:27 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
I am hoping this combo achieves similar results. All my ideas are to big for my space. But I am still trying to think of way to fit them anyways.
post #194 of 1163 Old 08-27-2011, 08:31 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
My DRS are sealed and the new ones are ported so they will extend deeper alone. They won't need the bottoms but I just want crazy again.
Marantz 7702 Atmos
post #195 of 1163 Old 08-28-2011, 02:48 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
How much extension does the port allow the speaker to play down to? 60...50hz?
post #196 of 1163 Old 08-28-2011, 06:12 AM - Thread Starter
MKtheater's Avatar
Liked: 1305
I would say it allows it to crossover at 80 with lots of output. The subs provide output at 80 as well and why I did not have a drop off with them on. The sealed DRS dropped off at 100.
Marantz 7702 Atmos
post #197 of 1163 Old 08-28-2011, 06:24 AM
mjg100's Avatar
That is one of the reasons that I like the older 8340's. They have a switch for selecting the X-curve. I do not use the X-curve.
mjg100 is offline
post #198 of 1163 Old 08-28-2011, 07:09 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Pics of this mountain of mayhem?
JSS
maxmercy is offline
post #199 of 1163 Old 08-28-2011, 07:37 AM - Thread Starter
MKtheater's Avatar
Liked: 1305
JSS
As soon as my friend comes over I will move everything in place. I will take a picture of just the new front stage. All DIY based and all horn loaded.
Marantz 7702 Atmos
post #200 of 1163 Old 08-28-2011, 08:18 AM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
MK,
Based on all your previous experiences and info you've read here on AVS and online, do you have any personal expectations on which will eventually win?
I'm just curious and think it might be interesting to see what your current expectations are vs how things play out after the measurements/tests/listening sessions.
Thx,
Claude
Bunga99 is offline
post #201 of 1163 Old 08-28-2011, 08:32 AM - Thread Starter
MKtheater's Avatar
Liked: 1305
I believe the DRS will win. Why? Very high sensitivity and big sounding speakers. They can be made with ribbons if you want. They are cheap and big enough for proper placement. Like the DTS-10's they need lots of tweaking. I still have JTRs coming. I played the DRS with no center and they were very clear even with compression. We will see. I have high hopes for them.
Marantz 7702 Atmos
post #202 of 1163 Old 08-28-2011, 09:36 AM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
Awesome, good stuff!!
Thanks and looking forward to your tests and listening impressions.
Bunga99 is offline
post #203 of 1163 Old 08-28-2011, 11:10 AM - Thread Starter
MKtheater's Avatar
Liked: 1305
I am selling everything except my bfm's and S-5000's. Oh yeah and my F-20's.
Marantz 7702 Atmos
post #204 of 1163 Old 08-28-2011, 12:20 PM
Gooddoc's Avatar
Quoted: 3106 Post(s)
Liked: 2405
You have CHT stuff you're going to sell? I'll take a couple SHO-10s off your hands. I wouldn't want to see your room get all cluttered up .
Gooddoc is offline
post #205 of 1163 Old 08-28-2011, 12:26 PM
carp's Avatar
Quoted: 2827 Post(s)
Liked: 2133
I wish you still had your Maggies to compare with the rest. However like you've said before they just can't keep up output wise so it wouldn't be a fair fight for the MMG's. It would be interesting to hear your impressions of how they compare at lower spl levels though especially for music.
I wonder if the larger Maggies can go louder before sounding stressed, if I remember right they have the same if not lower sensitivity so I'm guessing not?
Great thread MK, glad I checked the speaker section since I rarely do. I'm looking forward to reading how the JTR speakers do.
carp is offline
post #206 of 1163 Old 08-28-2011, 01:21 PM - Thread Starter
MKtheater's Avatar
Liked: 1305
I don't have any yet. Waiting for the new designed stuff. I am selling Triads in room LCR golds, M&K s-90's and SS-500's. The shootout has become DR-200 vs M&K s-5000's. Waiting for eD e12's and triple 8's sealed. Sho-10's will be last to come.
Marantz 7702 Atmos
post #207 of 1163 Old 08-28-2011, 04:21 PM
Gooddoc's Avatar
Liked: 2405
OK, cool. Just wanted to be first on the list if CHT's go on the market
Gooddoc is offline
post #208 of 1163 Old 08-28-2011, 08:38 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Cant believe your getting rid of the F-20's.........but coming from the past I can believe it.
Will the T39's be coming later or are they already there? I am getting confused.
Still wondering about a DR200 and T18 combo or maybe just a DR250 alone. Could then use the DR250 for bass guitar playing also all in one cab. DR200/T39 would be awesome but then budget comes into play and not sure how I could afford that option.
Either way great thread!!!!!
post #209 of 1163 Old 08-28-2011, 09:52 PM
Liked: 72
Cant believe your getting rid of the F20s
I think you misunderstood, those are on the "keep" list
post #210 of 1163 Old 08-29-2011, 02:10 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Thanks.......I thought he wasn't getting rid of the F20's but you never know with MK.
Reply Speakers
Jbl Professional , Jbl Harman Kardon , Jbl Professional 4645c Cinema Thx Subwoofer
