Replacing capacitors in speaker crossovers for better sound? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Bill Fitzmaurice
  • 1 Post By Shadowed
post #1 of 27 Old 08-22-2011, 09:25 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
Hey,
I was just looking at some different websites and came across this page, a user review for polk monitor 40's. The user changed out a simple capacitor, and claims much better sound all around - bass, mids, treble....is this possible? I mean I'm sure it is, but it can't be that easy, can it?
He used these caps and said this in his review:
http://www.parts-express.com/pe/show...number=027-288
Just got them a week ago.They sounded okay but was lacking some bass.Naturally,I opened them up,pulled out the crossover and said "DAMMIT". Again, K-Mart cheap Chinese electrolytic capacitors..no wonder ! Well,out they went and immediately in went Jantzen Z-Standard poly caps. Much better,definitely more bass,solid midrange where vocals excell,and the tweeter is much cleaner sounding.
I'm starting to really like these speakers a lot since I swapped out the capacitors.Thats all i did on this set and it made a good 40% improvement thats not placebo.My 45 year old ears still work. Now I have $900.00 sound for $150.00(speakers) + 35.00(Jantzen Z-Standard caps). for $175.00 investment.
If so, the 35$ he spent on the caps looks like a worthwhile upgrade, but will obviously void a warranty. I'd like to do this to my monitor 70's/center channel if it will work. Changing the caps should be a piece of cake. Seeing as my monitor 70's are from 2006 (i think) i dont believe they'd be under warranty still, but I really doubt I'd need the warranty for them anyway at this point.
Should I try it and see what happens? I'm getting the upgrade 'itch' (looking for a cleaner sound) but have no $$, so if changing a couple caps will give a different sound all together, I'm willing to try it.
Suggestions?
dunan is offline
post #2 of 27 Old 08-23-2011, 07:56 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
Doubtful.
Charlie
chashint is offline
post #3 of 27 Old 08-23-2011, 08:49 PM
Dennis Murphy's Avatar
Quoted: 397 Post(s)
Liked: 581
Originally Posted by chashint View Post
Doubtful.
I've participated in a number of blind A-B comparisons with caps, and they always yield the same results--no difference. The only possibly legitimate complaint about using NPE caps in the woofer circuit is that they might leak over time and change value. And I have tested one line of NPE's that had very wide tolerances. The Bennics from Madisound were spot on, however. If you have a little change lying around, and if the series capacitor(s) in the tweeter circuit are NPE's, you might replace it (them) with a decent poly cap like the Jantzens. Typical values for tweeter caps are 4.7 uf to 8.2 uf, and that shouldn't cause you much financial grief. I doubt that you will hear a difference, but you might sleep better. If by chance you do think you hear an improvement, (and it will probably just be your imagination), you might replace the woofer cap. It can't hurt, and it might be more stable over time. However, the bottom line here is that there's no objective evidence that cap upgrades help, and no logical explanation as to why they might help other than the issue of long-term stability and possibly poor quality control for some brands.
Dennis Murphy is offline
post #4 of 27 Old 08-23-2011, 09:13 PM
tony123's Avatar
Liked: 38
You can look through my construction thread and find where I documented my experience.
My LaScala were 30 years old and it is recommended by the manufacturer to replace capacitors because they dry out and fall out of spec over that length of time. It did, in fact, have an improvement on sound. I've since also experimented with polycarbonate and metal film bypass caps. I could percieve the polycarbonate, but not the metal film.
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #5 of 27 Old 08-24-2011, 12:02 AM
Colm's Avatar
Liked: 94
If there isn't something wrong with the capacitors in the first places, it is not likely replacing them will result in an audible difference. Obvious targets for replacement are electrolytic and paper in oil capacitors which generally do not age gracefully. Film capacitors generally don't need replacing.
Frankly, there is nothing wrong with electrolytics where they are typically used (where large values are needed) as long as they haven't degraded. They do tend to have more hysteresis than other types, but it doesn't seem to hurt the sound significantly.
Changing capacitors is not going to make a $150 speaker sound like a $900 one. At best it will probably return it to something closer to its original performance.
Colm is offline
post #6 of 27 Old 08-24-2011, 02:12 AM
Dave1027's Avatar
Quoted: 12 Post(s)
Is the OP talking about replacing the electrolytic caps with identical value film caps? Or modding by changing the values and yes, the tonal character of a speaker? Either one can yield positive results. The latter much more dramatic of a difference. My BICs are highly modded and they sound like a totally different speaker than stock. You better know what you are doing though. Getting the sound just the way you want it is not as easy as simply throwing in new caps. Getting the values correct with all the different variables is a major process.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #7 of 27 Old 08-24-2011, 02:45 AM
Colm's Avatar
Liked: 94
OP linked to 33uF capacitor, which logically would be part of the woofer filter. Replacing a properly function electrolytic there with a film capacitor won't yield an audible result, let alone what the guy he is reading claimed.
If you start changing values, it might be possible to get a little better performance at the crossover points (measurable if not audible), if you know the actual impedances of the components at the crossover points. Individual components vary, and speaker manufacturers typically use the closest standard value instead of the exact value for crossover components. But that is probably beyond OP at this point.
Now, if you want to completely redesign the crossover, that is another story...
Colm is offline
post #8 of 27 Old 08-25-2011, 08:12 PM - Thread Starter
dunan's Avatar
Quoted: 62 Post(s)
I'm sure you guys know your stuff, I was just curious to see if trying it would have yielded some good results.
I won't try it at this point, but if the responses were overly positive, I'd have experimented and seen what would have happened.
dunan is offline
post #9 of 27 Old 08-25-2011, 08:22 PM
truwarrior22's Avatar
Quoted: 333 Post(s)
Liked: 77
I've upgraded basically my whole crossover in my BP7000SC, I can't say it made a night and day difference, but it does sound a little better. The time spent on proper speaker placement well out weighs the cost to upgrade the crossovers. If you don't like how your speakers sound now, I don't think you'll really like how they sound after replaceing the crossover parts.
truwarrior22 is offline
post #10 of 27 Old 08-26-2011, 06:26 AM
Bud Dickman's Avatar
Over the years I've done a number of Xover upgrades for my self and a few customers with results varying from slight improvements, to quite noticeable improvements. However there are a few "rules" to consider.
1. You cant polish a turd. If the speaker was very cheap such as a modern speaker in the $250/pair or less, you are usually dealing with cheap cabinets and internal wiring that will make Xover improvements much less noticeable. Don't spend a lot on trying to upgrade them or leave them alone altogether. Sometimes a cheap poly bypass cap with the stock electrolytic is about all you should try or you will be throwing your money away.
2. I've found the greatest improvements to be had on mid priced speakers, (~$400 - $1200). Some Klipsch classic series speakers come to mind here. I've done things to improve the seal of the cabinets, and upgraded the internal wiring to some basic Audioquest or Kimber, that helped the imaging quite a bit, and left the Xovers alone. Consider the complexity of the Xovers. I once owned a pair of B&W DM7mkII speakers that had a very complex Xover so I would have had to spend hundreds to upgrade them. It wasn't worth it so I left them alone.
3. Electrolytic caps do not make great Xovers, but manufacturers use them because they are cheap. You may wonder why a company didn't spend another $25 to use better grade capacitors and resistors, but that could end up meaning that the retail price would be $100 higher, and people are budget minded.
Bud
Bud Dickman is offline
post #11 of 27 Old 08-26-2011, 06:33 AM
LaScalas, as well as Heresys, Forte II, etc. from he 70's and 80's are prime candidates for upgrades to internal wiring and upgrades that seal the cabinets better, dampen horn resonance, etc. I sold Klipsch for years and it was common for me to have pairs cranked up and feel the cabinets "breathe" around the joints. Even on ported speakers.
Bud
post #12 of 27 Old 08-26-2011, 07:13 AM
tony123's Avatar
Liked: 38
Bud, can you expand on some of the techniques used in dampening and sealing. I've also got the old nasty wires inside the cabinets. Next time I get back behind the screen I'll replace all that too.
Construction Thread
tony123 is offline
post #13 of 27 Old 08-27-2011, 04:34 PM
The last pair I did was probably 15+ years ago...you can dampen the horns (the back side) with plumbers putty and then if you don't like it, it can be removed. I generally did this with the older models that used metal horns, the ones from the late 80's and newer used plastic and "ringing" wasn't as much of an issue, so the putty trick may go too far. Generic Dynamat type material can also be used on the back of the woofer baskets. I've also used the plumbers putty (the rope kind) on the inside corner joints of the cabinet. Make sure you get the really sticky type and the surface is clean because you dont want it to come off and drop to the bottom of the cabinet. You can also use silicone caulking applied liberally and then smoothed out with your finger or a plastic putty tool. Whichever you use, make sure to push it in well so you get a good seal.
For replacing the wiring I had really good results with the old Audioquest Type 2 wire, but I'm not sure if they make that anymore. Basically use the round stuff thats less than $2 a foot, you dont need to go real expensive. If you can push it into the corners with the putty it will also help it from vibrating from internal cabinet pressure, which will help slightly to increase fine detail. Most of these tweaks are slight by themselves, but cumulatively can be pretty noticeable. Although one of my guys who owned Quartets only had time to do the wire upgrade on one speaker one night and said it was noticeably louder and clearer than the other until he had time to do the other one.
Oh, and if you can run your Klipsch with a tube amp and preamp, thats the best upgrade of all :-) But that costs a bit more.
Good luck and happy listening!
Bud
post #14 of 27 Old 08-28-2011, 05:55 AM
tony123's Avatar
Liked: 38
Thanks Bud. I'll put all that on my list for the next time I have the cabinets pulled out. I'm pretty sure I have the metal horns, but also pretty sure I don't notice ringing. Still, I'll give it a shot.
Construction Thread
tony123 is offline
post #15 of 27 Old 08-28-2011, 01:34 PM
I believe "ringing" is the technical term, but in reality it's usually perceived as a harshness in certain middle and high frequencies. The putty trick usually smooths things out. You CAN go too far with the putty, start off with a few small blobs mashed onto the back of the horn flares and then increase the amounts gradually until you get the desired results. You can remove some of it when you reach the point of going too far.
Bud
post #16 of 27 Old 01-06-2013, 09:06 AM
twc5964's Avatar
I'm the one the op is referring too regarding the review on my capacitor swap out in the monitor 40's. Of course,I'm 1 1/2 years late finding this thread.I can say using the Jantzens made a huge improvement.I have since used the Z-Superior which made them sound even better.Been doing this for many years with all kinds of audio equipment-especially speakers.I also swapped out the caps with Jantzens in my Monitor 30's with dramatic improvement in sound.Considering the speakers are low end this is as far as I wanted to go with these speakers. Some claim it's a waste of time doing this and they are entitled to their opinion..I can say for a fact it has elevated the Polks to another level.Still using them-still loving them.
twc5964 is offline
post #17 of 27 Old 07-04-2013, 11:37 AM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 87
Sorry for butting in. I have a question on this pair of old Infinity SS2003 speakers. I'm in the process of re-foaming them so while I have them apart I saw somewhere where they recommended a poly cap upgrade. Looking at these pics, can you guys recommend if it's worth it and which ones I should replace. Looks like there are two caps in place.
Mike
See My System Here
Processor: Emotiva XMC-1
R/C/L Amps... (3) Emotiva XPR-1's (1750w x 3 = 5250w)
Surround Amps: Emotiva XPA-5 G2 (200 x 4 = 800w) not using 5th
Zone 2: Emotiva Mini-X a-100 driving 2 Boston Acoustics Voyager 70's
10050 watts total power.
mhrischuk is offline
post #18 of 27 Old 07-04-2013, 01:41 PM
Bill Fitzmaurice's Avatar
Liked: 4628
Both of those caps are NPE. Chances are the smaller is in the high-pass filter, so it might benefit from swapping out for a poly. Then again, it might not. Just as with high priced wire chances are any improvement can be chalked up to placebo effect. If you're spending five bucks for a Dayton then what the heck, but if it's fifty bucks for a Mundorf, save your money.
mhrischuk likes this.
Bill Fitzmaurice is online now
post #19 of 27 Old 07-06-2013, 04:39 AM
mhrischuk's Avatar
Quoted: 63 Post(s)
Liked: 87
Thanks Bill.
See My System Here
post #20 of 27 Old 12-05-2015, 10:26 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
I know this is an old thread, but I came across it in my search, and I must say my 2 cents. With respect, changing out Capacitors makes a huge difference if you use higher quality ones than stock. I put better (from PE) caps, resistors, and inductors in my Klipsch RF-3 II speakers and the difference is absolutely NIGHT AND DAY. Without question. Anyone I ask who heard them before the upgrade also confirmed there was a massive difference. Like buying all new higher quality speakers. Don't listen to those saying there isn't a difference, THERE IS.
A lot of speaker manufacturers skimp on their crossover networks, but I assure you, there is a huge difference in sound with better parts. For example, many manufacturers use crappy Electrolytic caps, where-as film and foil or metalized polypropylene caps sound far far better. Same thing with the crappy quality grainy resistors many use, Mills resistors sound far superior. Biggest place they skimp, however, is the inductors. Many speaker companies use horrible sounding constraining tiny gauge air core inductors. Upgrade them to some nice 12-14 gauge inductors, and the difference is astonishing.
I am unsure how anyone could possibly claim the crossover on the top (pictured below) doesn't sound better than the stock crossover on the bottom. It's simply a nonsensical thing to say. It is NOT placebo. Anyone claiming that has simply never heard a properly upgraded crossover network from a small low quality stock crossover. A quality crossover network is every bit as important as your drivers, bracing, and over enclosure design. It is the brains of your speakers, of course it makes a difference!!
Also note, there is not just a difference from swapping out old caps, as the caps on my personal speakers were still in good condition and fully function. Quality difference, like with drivers, makes all the difference.
Lumenlab "Community driven video lab".
blake18 is online now
post #21 of 27 Old 12-05-2015, 10:35 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
Mike
Keeping the same values, but rebuilding that network on a new board with higher quality parts would yield MUCH better sound.
post #22 of 27 Old 12-05-2015, 10:59 PM
Shadowed's Avatar
Quoted: 639 Post(s)
Liked: 542
Originally Posted by blake18 View Post
I am unsure how anyone could possibly claim the crossover on the top doesn't sound better than the stock crossover on the bottom. It's simply a nonsensical thing to say. It is NOT placebo.
Yes, we can hear the difference just looking at it.
Marantz guy likes this.
Shadowed is offline
post #23 of 27 Old 12-05-2015, 11:32 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
What before & after tests did you run on your speakers to determine these improvements? What parameters improved? If you did listening tests only, how exactly did you do them? I would imagine it takes time to rebuild the crossover - so how did you compare old vs. new?
How does one go about determining the "sound" of a cap (you said one sounds "far far better")? Same with resistors - how does one go about determining their "sound?" What parameters are you improving? And how are you conducting the listening tests that lead you to these conclusions?
How do you know it's not placebo? What double-blinded, controlled tests did you run?
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #24 of 27 Old 12-06-2015, 01:01 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
Go ahead and think what you want, but the upgraded crossover is clearly superior, and many people who've done the upgrade confirm this.
I didn't do actual measurements, but many others have, and confirm my claims. Check out the Klipsch forums and the Klipsch thread on this forum, it is not placebo, I assure you. It does amaze me that people are actually arguing in favor of very clearly crappy crossover components vs ones that are of much higher quality. Do you honestly not think Jantzen, Dayton, ERSE, Mundorf, Mills, North Creek, ect are better quality than those little bottom of the barrel extremely cheapie components? Come on now. Oh well, think what you wish.
P.S. I did test one speaker with stock crossover, and one with the upgraded crossover. Again, night and day difference. You'd honestly have to be off your rocker to think the stock crossovers sound anywhere near as good as the upgraded ones if you heard my setup.
post #25 of 27 Old 12-06-2015, 07:23 AM
Liked: 4628
It's true that most speakers do use inferior crossover components, and that significant improvements can be made when you go from high DCR small gauge coils and high ESR electrolytic caps to low DCR large gauge coils and low ESR poly or mylar caps. But as with all things there is a point of diminishing returns, and where crossover components are concerned that point is reached very early on. A five dollar poly cap will work better than a fifty cent electrolytic. A fifty dollar, or even five hundred dollar, cap won't work significantly better, if at all better, than a five dollar cap.
post #26 of 27 Old 12-06-2015, 09:20 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
Excellent point, Bill. I totally agree. I would never pay beyond what I paid for my Dayton, Jantzen, and Mills components.
It's just like with high-end audio, you can pay $100,000 for speakers, and they will be great quality, but worth $100,000? Doubt it.
post #27 of 27 Old 12-06-2015, 09:33 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
[QUOTE=dunan;20855917]Hey,
There are certainly some high-quality caps that will make a big difference in sound quality. Any speaker designer or sound engineer is well aware of this. Anyone who says different is simply ignorant of the facts.
Putting an audio signal through an electrolytic capacitor, particularly, can can distort the waveshape and introduce significant distortion.
Many high-end speaker manufacturers put hundreds of dollars for each speaker system crossover network into the kinds of high-quality capacitors that have been proven to produce the least waveform distortion.
Since those capacitors are hidden away, the manufacturers only have one reason to do this; confirmed improvement in the way the speakers sound.
One company that offers many brands and types of high-quality crossover capacitors and can advise you on the best for your needs is PartsConnexion.com (ph 866-681-9602).
Another place that high-quality caps can make a big difference in sound quality is the input coupling caps of an amplifier or preamp. I made a huge improvement in one of my power amps by replacing the stock coupling caps with Infinicaps, which Audio Research and other high-end amplifier manufacturers use on their most expensive amps and preamps.
BTW- the claim that one capacitor could change the sound of all ranges in a speaker is not really credible. Since the Polk Monitor 40 is a 2-way speaker, the capacitor in question would probably affect the sound quality of the tweeter only.
commsysman is offline
Reply Speakers
