5.1 for a "happy home" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 08-30-2011, 03:34 PM - Thread Starter
zeffer111's Avatar
I need some desperate help guys.
My girlfriend and I just moved into a home together.
For the last few years I have been happily rocking out with:
Infinity beta 50 fronts
Infinity beta 20 rears
Infinity beta C250 center
Velodyne VX-10B
Harmon Kardon AVR-140
I would say I listen to music 60% and movies 40%. Our new living room is 18' x 15'
I've been told that speakers are too big to make a happy home
I'm in need of some recommendations. Should I swap it out for a whole new 5.1 system? should I just replace the fronts and rears and keep the center and sub? Our budget is max $850. I think best thing I've seen so far is this KEF C1 system for $500.
What do you all think?
zeffer111 is offline
post #2 of 18 Old 08-30-2011, 03:40 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Velodyne VX-10B
Uhh... not to be rude, but you have no reason not to throw a BIG stink about that. She'll back off, especially if you had them prior to dating her...
Jay1 is offline
post #3 of 18 Old 08-30-2011, 04:05 PM
Havok305's Avatar
+1, or get really awesome monitors/bookshelves and keep your sub.
Havok305 is offline
post #4 of 18 Old 08-30-2011, 04:12 PM
drewh01's Avatar
Order a set of these and see how fast your other speakers pass the bar.
http://www.montanaloudspeakers.com/s...rence-speakers
drewh01 is offline
post #5 of 18 Old 08-30-2011, 04:16 PM - Thread Starter
zeffer111's Avatar
Well, I used to have them in a big studio/loft and I also do find them a bit imposing in the new space, and I do somewhat see her point.
I'm looking for recommendation for a replacement set. Either a new 5.1 set, or a combination thereof.
Thanks everyone.
post #6 of 18 Old 08-30-2011, 04:24 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
The Classia replaced the Beta - on super close out pricing
Buy 3 for the front, left and center
http://www.bestbuy.com/site/searchpa...egories&ks=960
An option for surrounds
http://www.vanns.com/shop/servlet/it..._c=site_search
One sub to look at - Bic
http://www.amazon.com/BIC-PL-200-Aco.../dp/B001W3FXAQ
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 18 Old 08-30-2011, 04:29 PM
Havok305's Avatar
Thanks everyone.
I am in a similar boat, I want floor standers, but the wife isn't having it.
Eyeballing Paradigm monitors, DefTech Promonitor 1000's, MartinLogan Motion 4's.
I was looking seriously at the HSU HB1, Energy RC-10, Aperion Initimus, but they are larger and less aesthetically pleasing to her.
I showed her the DefTech Mythos, and she wasn't having it.
I think you are in a better position because you should be able to negotiate a decent sized speaker (larger drivers) since you have towers now. Keep your Beta 20's and get the best front three you can get away with. Then upgrade your rears later.
Good luck!
Havok305 is offline
post #8 of 18 Old 08-31-2011, 10:45 AM
JPark's Avatar
Velodyne VX-10B
$850, eh? I have a well cared for Bose system you can buy off me.
http://www.avsforum.com/avs-vb/showthread.php?t=1249863
JPark is offline
post #9 of 18 Old 08-31-2011, 12:54 PM
Big Whitey's Avatar
JPark, I just read that whole thread and it almost made my day. Some people. How are you liking your Jamo's?
Throw that Bose up on craigslist or something for like 200 bucks less than retail.
Going Deaf.... And Lovin' It
Big Whitey is offline
post #10 of 18 Old 08-31-2011, 01:34 PM
JPark's Avatar
Yeah, those were good times. I'm loving the Jamos. They sound pretty good and the finish quality is impossible to beat for that price. I still need to build some floating shelves to put the surrounds on, and I do sometimes feel guilty for taking up so much space in the front room, but other than that life is good.
JPark is offline
post #11 of 18 Old 08-31-2011, 02:55 PM - Thread Starter
zeffer111's Avatar
I found some Paradigm Titan V.6 monitors at a local retailer for $500.
They sounded pretty amazing in their listening room, and I'm pretty sure that I'll pick them up.
Do you think that I should throw down another $300 (for the demo) for the Paradigm CC-190 center channel? or should I just stick with the Infinity C250 center? will it be a total mismatch?
post #12 of 18 Old 08-31-2011, 03:57 PM
Drew Eckhardt's Avatar
Velodyne VX-10B
You're not going to get what many of us consider to be acceptable performance from physically smaller speakers because they lack the displacement needed for distortion free peaks at pleasant listening levels.
The SAF friendly compromises which accommodate that are to either get nicer large speakers that are more like furniture, hide the speakers behind an acoustically transparent projection screen and/or false wall, or use in-walls built with rigid enclosures behind decorator friendly grills.
Three of these for the front stage should work OK for $2700 retail.
http://www.triadspeakers.com/products/iws4lcr.html
You guys might prefer to keep your existing speakers until you've saved up enough extra pennies.
Drew Eckhardt is offline
post #13 of 18 Old 08-31-2011, 04:07 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
If you buy Paradigm, then get the Paradigm center.
Who AM I
zieglj01 is offline
post #14 of 18 Old 09-01-2011, 05:05 AM
Dasteru's Avatar
http://www.luxurylaunches.com/gadget...music_buff.php 2800lbs of solid aluminum
Dasteru is offline
post #15 of 18 Old 09-01-2011, 06:24 AM
bbrio's Avatar
Good luck!
He's in a better position because he's not married yet. Once he's married, then the hammer will come down and he will be shopping for cute speakers.
bbrio is offline
post #16 of 18 Old 09-01-2011, 06:26 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
And there's always these:
http://www.higherfi.com/audio_speakers/sa
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #17 of 18 Old 09-01-2011, 07:24 AM
tjayl's Avatar
Velodyne VX-10B
Do you have another room you could move your existing 5.1 set up (basement?) and then go 2.0 or 2.1 in the living room? Especially with favoring music over movies, a nice 2 channel set up might be ideal with 5.1 elsewhere in the house.
tjayl is offline
post #18 of 18 Old 09-02-2011, 08:58 PM
rcoyne's Avatar
Good luck!
Maybe she'll consider the Aperion Verus. . .
rcoyne is offline
Reply Speakers
