What other setups should I consider? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-05-2011, 09:39 PM - Thread Starter
91bball's Avatar
I've been lurking here for a while, trying to digest all of the info on lower budget and bang-for-the-buck setups. Before I pull the trigger on the below L/R/Center speakers, I'd like to see if anyone here has an alternate setup I should consider given the spec's below.
Goal: bang-for-the buck 3.1 system, minimizing impact on the wallet while providing an improved movie watching experience (note: we currently do not have a speaker setup, just use the TV speakers, yes I know just about anything will be a step up!). A 5.1 system is not really possible at this time.
Room: L-shaped basement with the TV area being 11 x 14, TV will be along the 14' wall so listeners are ~10 feet away. (Other leg of the room is 12x26).
Media: TV/Movies 95%, games 5%.
From posts here, it seems folks are generally happy with Polks. And given their current price @ newegg, they seem to fit the goal quite nicely.
Polk Monitor 40s (for L/R) and CS1 Center for just under $200 total.
So the question is what other front speaker setup should I be considering for roughly the same price range?
(I have not decided on the receiver/amp and sub yet).
thanks!
91bball is offline
post #2 of 11 Old 09-06-2011, 02:31 AM
YeuEmMaiMai's Avatar
I use Yamaha NS-6590s with a NS-C125 center speaker total cost for 2.1 was under $200
I run these with a Yamaha HTR-5635 receiver and a YST SW-215 sub. Speakers are great looking and sounding and are acustic suspension type. center and sub are ported
I run 5.1 so my total cost for subs receiver and speakers was about $630. my setup is about 8 years old and still works flawlessly
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #3 of 11 Old 09-06-2011, 06:23 PM - Thread Starter
91bball's Avatar
thanks, I'll look into those yamahas. Anyone else?
91bball is offline
post #4 of 11 Old 09-08-2011, 08:29 PM - Thread Starter
91bball's Avatar
any other inputs? thanks
91bball is offline
post #5 of 11 Old 09-08-2011, 08:46 PM
Knucklehead90's Avatar
Quoted: 389 Post(s)
Liked: 334
I presume you meant NS-6490? I have a pair and can recommend them. I did a review (of sorts) of them. I found the tweeter to be bright compared to my Infinity speakers with the CMMD tweeters but other than that I was quite surprised at how well these inexpensive speakers sound.
If you have a bigger budget there are many better speakers out there. The 6490 sell for under $150 per pair and are a three way speaker.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #6 of 11 Old 09-09-2011, 10:45 AM - Thread Starter
91bball's Avatar
Thanks. So if I increased my budget to around $400 for the front 3, what ones should do you all recommend?
91bball is offline
post #7 of 11 Old 09-09-2011, 10:52 AM
jonnythan's Avatar
Three Infinity P163s.
Ideally, you would mount all three P163s at the same level across the front. If for whatever reason you can't mount the P163 vertically you can get a PC251 center instead.
jonnythan is offline
post #8 of 11 Old 09-09-2011, 11:13 AM
Quoted: 389 Post(s)
Liked: 334
The Infinity speakers would be a great choice. Polk Monitor speakers with a CS2 center is another. The Monitor 60s fit well in your revised budget. For bookshelf speakers the Monitor 40s.
***GO SEAHAWKS ***
post #9 of 11 Old 09-09-2011, 07:32 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
I would also look at getting 3 ea - of the Infinity Classia
http://www.bestbuy.com/site/Infinity...68&st=INFINITY CLASSIA&cp=1&lp=1
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #10 of 11 Old 09-09-2011, 08:29 PM - Thread Starter
91bball's Avatar
floor speakers won't work so that's why I was looking at the Monitor 40s to begin with. Will the CS2 mesh well with the 40s?
91bball is offline
post #11 of 11 Old 09-11-2011, 01:30 PM - Thread Starter
91bball's Avatar
Any opinions on the BIC America DV62si as compared to the M40's?
91bball is offline
Reply Speakers
