KRK RokitG2 5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-08-2011, 10:52 AM - Thread Starter
anismo's Avatar
Hi all,
I currently have M-Audio AV40 as my computer speakers (Which by the way is an excellent near field Monitor). I have an opportunity to pick up the KRK RokitG2 5s for under 200$.
Anyone know if they are worth an upgrade over the M-Audio? Should I be looking at KRK Rokit 6s instead?
anismo is offline
post #2 of 4 Old 09-08-2011, 11:21 AM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 601
I've heard the Rokit 6s. They are pretty good. Good bass but don't go very loud.
Even the Rokit 5s would definitely be a step up from the M-Audio AV40s. M-Audio BX5A would be comparable to the Rokit 6s.
I've owned a pair of M-Audio BX5A with the M-Audio SBX10 subwoofer and it was a killer computer speaker setup.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #3 of 4 Old 09-08-2011, 12:31 PM - Thread Starter
anismo's Avatar
Thanks. I agree that these are awesome with their great midrange and stereo imaging. So much better than the popular computer 4.1s. I am actually ok with the lower bass. Looks like I can get a pair for around 175$. so I might just pull the trigger and sell the AV40!
anismo is offline
post #4 of 4 Old 05-11-2012, 02:07 PM
ota.dt.man's Avatar
Are these KRK active monitors reliable?
Broadcast TV - a vital national public resource
Just say "no" to a never-ending subscription TV bill that increases faster than the rate of inflation.
ota.dt.man is offline
Reply Speakers
