Bookshelf speaker recommendation for behind bar. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-21-2011, 01:29 PM - Thread Starter
danger dan's Avatar
Just finished with a basement remodel project. Wanting to mount some bookshelf speakers behind my bar. They will have to be mounted on the wall. Looking for recommendations of up to $400 for a pair. They will be powered from an Integra DTR 7.8 receiver. Also, the speakers will be pretty close to the wall without much room between them and the wall so I must take that into consideration. Any help here would be greatly appreciated. Thanks very much.
DANger
danger dan is offline
post #2 of 7 Old 09-21-2011, 05:54 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Look into the Energy RC-10 for $299
http://www.vanns.com/shop/servlet/it..._c=site_search
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #3 of 7 Old 09-21-2011, 06:20 PM
Knucklehead90's Avatar
Quoted: 390 Post(s)
Liked: 335
Since there will a narrow sweet spot if you use mono-poles you might want to consider a pair of bi-pole/di-pole speakers like Emotiva ERD-1s. They mount on the wall and take up very little space. The tweeters fire at different angles to each other - the woofer directly away from the wall - and should make a wider sweet spot - something a bar area would need. I wouldn't normally recommend such a speaker but they are small - less than 5" off the wall when hung. I'd use them in bi-pole mode where both tweeters fire in unison. In di-pole mode the polarities are switched to fire 180* from the other tweeter. While not a critical listening solution they should give a soundstage similar to a direct/reflecting speaker such as a Bose 901 which has a very wide sound dispersion. A small sub would be needed with such small drivers. They do sound very good. I own a pair and use them for surrounds.
Just a thought...
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #4 of 7 Old 09-21-2011, 06:26 PM
zieglj01's Avatar
Quoted: 945 Post(s)
Liked: 847
Check the Infinity Primus - front ported speaker
http://www.crutchfield.com/p_108P162...nfinity+primus
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #5 of 7 Old 09-22-2011, 08:03 AM - Thread Starter
danger dan's Avatar
All. Thanks very much.
DANger
post #6 of 7 Old 09-22-2011, 12:15 PM
Elihawk's Avatar
Quoted: 1026 Post(s)
Liked: 869
These come highly regarded, but I have not heard them. Definitive Technology MONITOR 450s.
http://www.amazon.com/Definitive-Tec...6715283&sr=1-2
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #7 of 7 Old 12-29-2011, 09:39 AM - Thread Starter
danger dan's Avatar
Ended up getting these for 50 bucks at Best Buy.
http://www.pioneerelectronics.com/PU...ers/SP-BS21-LR
I have a full front projection 5.1 home theater on the other side of the room so these will do for simple background music when sitting at the bar. Can't really go wrong for the price paid. Putting the money I saved into a new cd player.
DANger
Reply Speakers
