Infinity RS-3 and 2000.3, same exact speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-01-2011, 12:07 AM - Thread Starter
digiz's Avatar
From the looks of these 2 models they look exactly the same. How come 2 different models for the exact same speaker? Are there any difference in specs or build quality? Which is the newer of the 2 model? These are the Reference Series that came out in the late 90's and early 2000's. I am looking to buy a set, but would like to find out the differences so that I can make the choice on which model to get. I would prefer the newer one.
digiz is offline
post #2 of 12 Old 10-01-2011, 02:35 PM
Looneybomber's Avatar
Liked: 25
There will be subtle differences between the two, but I didn't pay much attention to the details back in the day; I don't know if there were any crossover or driver tweaks, although I assume there are.
I believe the RS speaker line came out before the 2000.reference series.
YID DIY
Looneybomber is offline
post #3 of 12 Old 10-01-2011, 04:25 PM
Bud Dickman's Avatar
I sold Infinity back in the mid 80's. It's been a long time but I could swear the RS-3's were out then. Not a bad speaker for the money, but why would you want to buy a 25 year old speaker where parts are likely unavailable? I can't remember if that model had the EMIT tweeter or the polycell tweeter, but the EMIT parts haven't been available for years. Unless they are a garage sale find for ridiculously cheap, I would pass. You are essentially considering a speaker owned by a completely different company. The original Infinity, and then some time in the 90's I believe they became part of Harmon International. Harmon isn't really known for their support of the "old company" models. Ask anyone who owns vintage Mark Levinson gear.....
Bud Dickman is offline
post #4 of 12 Old 10-01-2011, 10:23 PM - Thread Starter
digiz's Avatar
I really loved how my RS-5 so I wanted to finish my set and match those. So are the 2000.3 newer than the RS-3?
digiz is offline
post #5 of 12 Old 10-02-2011, 06:30 AM
Yes.
I happened to find my old (1999) copy of an Orion Blue Book. It says the Reference 2000.3 was made in '97 and were only $330 a pair new. The RS-3A and 3B were made from '82-87, and were $1300-1500 per pair. According to the '99 Blue book they were only worth ~250 used then, and they certainly haven't increased in price since.
So the 2000.3 was from a lesser, different series that the RS. My recommendation to pass on either still stands unless someone gives them to you. Why not consider something current from Infinity where you have a warranty and parts are available?
post #6 of 12 Old 10-02-2011, 05:26 PM
Liked: 25
Originally Posted by Bud Dickman View Post
Yes.
I happened to find my old (1999) copy of an Orion Blue Book. It says the Reference 2000.3 was made in '97 and were only $330 a pair new. The RS-3A and 3B were made from '82-87, and were $1300-1500 per pair. According to the '99 Blue book they were only worth ~250 used then, and they certainly haven't increased in price since.?
The rs3a's are quite different than the rs3's.
Rs3a
RS3
2000.3
YID DIY
post #7 of 12 Old 10-02-2011, 05:40 PM - Thread Starter
digiz's Avatar
Looney thanks for posting those pictures up. The 2 speakers I am referring to are the RS-3 and the 2000.3 that was just posted up. They look exactly alike and I just needed to know the differences, if any and which of the two is the newest model.
digiz is offline
post #8 of 12 Old 11-06-2011, 09:01 AM
ericlecarde's Avatar
Bump!
Digiz, Im looking to do the same as you because I have a pair of RS2's, RS3's, and RS5's and tweeter went bad in one of the RS2's. I see the Reference series (2000.2, .3, .4, etc) on Ebay constantly. The one thing I do know is that the tweeter on the Reference ones are the silk dome type. The problem is that I don't know what the RS's have. Take a look at the product finder with the link below and see if this helps you.
infinitysystems.com/home/product_support/default.aspx
ericlecarde is offline
post #9 of 12 Old 02-21-2013, 10:34 AM
bigredishott's Avatar
I know this is an old post but, just last spring I ordered 2 tweeters for my RS3 model speakers. I replaced both didn't want one old and one new. Anyways, the tweeters are available from infinity maybe it was harmon anyways, just send them an email and they will get you the part number. I think the were about $50 each. now I have a new tweeters and a already broke in spare. I hope this helps people in the future.
bigredishott is offline
post #10 of 12 Old 10-09-2013, 12:45 PM
CherylJosie's Avatar
Quoted: 680 Post(s)
Liked: 271
it might be a polycell tweeter
CherylJosie is offline
post #11 of 12 Old 03-16-2016, 06:32 PM
Liked: 0
Thanks for posting that. However, Infinity's model numbering has grown increasingly confusing (ridiculously so, in fact) over the years. The "RS-3A" speakers in the Blue Book are not bookshelf speakers, but large 3-way, 4-speaker towers. The model number for this Blue Book entry should be shown as "RS-IIIa". I bought a pair of RS-IIIb speakers in 1985 for $1500, and I still have them. They need huge amps (250-300+ wpc) to drive them properly - extremely inefficient.
Audiophilic is offline
post #12 of 12 Old 03-16-2016, 06:35 PM
Liked: 0
These big 3-way, 4-speaker models with the EMIT tweeter aren't RS-3A's, they are RS-IIIa. I still own a pair of RS-IIIb.
Reply Speakers
