Advice on 5.1 setup required please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-16-2011, 08:34 AM - Thread Starter
jonop's Avatar
see attached jpeg. I need to know if this configuration will work, have i got this right?
Due to open ceiling and corner placement of TV i'm unable to have in ceiling/ wall center - i have placed this under the tv - is this ok, what make center should i go for?
Also, will the RC80i be good enough for room music (Hifi) ?
thanks
Jonathan
jonop is offline
post #2 of 2 Old 11-14-2011, 01:52 PM
FunHouse Austin's Avatar
I would use a LCR in-ceiling speaker to better aim the sound at you. also add a sub.
If you want to know if a product is "good", please tell us your definition of "bad" for an understood point of reference. Do you want subjective opinions or objective facts?
- FunHouse Media
FunHouse Austin is offline
Reply Speakers
