Need Help With Fiio D3 DAC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-18-2011, 04:32 PM - Thread Starter
iamloco724's Avatar
Quoted: 16 Post(s)
not sure where to put this topic so ill try it here
so i bought the fiio d3 cause i wanted sound from my ps3 through headphones i was also goign to use it for general tv use as well so i connected the optical on the tv to the optical on the d3 put the tv on mute cause i only wanna hear it through the headphones and i connect my rca y headphones cable to the d3 plug in the headphones and i have no sound
i then try to connect the d3 directly to the ps3 and still no sound
i have the d3 set for optical..i am not sure what i am doing wrong..mind you this is my first hdtv and first time dealing with optical cable but everything was as secure as it could be
this is my tv
Panasonic VIERA TC-L37DT30 37-Inch 1080p 3D LED HDTV
iamloco724 is offline
Reply Speakers
