Home theater system under $800? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 69 Old 10-24-2011, 05:43 AM - Thread Starter
bahuffma's Avatar
Hi all. First time poster here. Thanks in advance for any suggestions/advice!
So i recently splurged and bought a 51" hd tv and now am looking to hook up a nice sound system. Currently i have a very old receiver (10+ yrs) and a pair of old bose bookshelf direct/relfecting speakers. I am torn as to what to do for a system. When i bought the tv i also bought a receiver (samsumg hwc700b for $116 on clearance), however after reading the reviews i am thinking i am going to return this. I was thinking of just buying a subwoofer and a new receiver and using the bose speakers that i have. I guess I would then have to buy surround speakers and a center channel to get the surround effect?? Would it be worth it to do this? Or am I better off buying a speaker (or home theater) set? Being that i have two decent speakers (even though old), I would like to incorporate them. I also found a deal for a Sony 5.1 channel speaker set (SA-VS310) for $250. Anyone have any knowledge of these (seem to have decent reveiws). Not looking to spend too much money, but would like to get something decent that sounds good at all levels.
bahuffma is offline
post #2 of 69 Old 10-24-2011, 06:38 AM
Havok305's Avatar
If you post your budget, the good folks here will do their best to piece you together a good system.
Havok305 is offline
post #3 of 69 Old 10-24-2011, 07:04 AM - Thread Starter
bahuffma's Avatar
Thanks for the advice! I would like to keep the budget under 800 for receiver and speakers. Again, wondering if keeping my existing bose bookshelf speakers would help with this. Also, this is for our living room (15x18) and mainly interested in getting a good surround sound for movies.
bahuffma is offline
post #4 of 69 Old 10-24-2011, 08:18 AM - Thread Starter
bahuffma's Avatar
Another question..What are your thoughts on acheiving a surround effect without rear speakers? I checked out the bose cinemate ii 2.1 at best buy and they sounded good cranked up, but have read that they are not great on lower levels.
bahuffma is offline
post #5 of 69 Old 10-24-2011, 08:59 AM
afrogt's Avatar
Quoted: 1439 Post(s)
Liked: 983
Here's what I would do with your $800.
1. Buy this Jamo S506 speaker system for $299
http://www.vanns.com/shop/servlet/it..._c=site_search
2. Buy the matching Jamo sub300 subwoofer for $199
3. But the Denon 1611 7.1 AVR for $289
All this for under $800 shipped. You could use your Bose bookshelf speakers for a 7.1 system.
Another option
1. Pioneer 5.0 speaker pacakge from Best Buy for $285
http://www.bestbuy.com/site/Pioneer+...018&st=pioneer speakers&lp=6&cp=1
2. Energy s10.3 subwoofer for $199 after promo code EMCJKJB98, deal ends today!
http://www.newegg.com/Product/Produc...82E16882269026
3. Denon 1611 mentioned earlier for $289
If you don't want towers and only want bookshelf speakers we can go in a different direction.
Afro GT
afrogt is offline
post #6 of 69 Old 10-24-2011, 09:00 AM
afrogt's Avatar
Liked: 983
If you want a really nice surround system, then skip the Bose Cinemate.
Afro GT
afrogt is offline
post #7 of 69 Old 10-24-2011, 09:08 AM
5seonds's Avatar
Think about these for speakers:
http://www.6ave.com/shop/product.aspx?sku=JAMS426HCS3WE
these for a receiver:
http://www.newegg.com/Product/Produc...15339&Tpk=v667
and this for a subwoofer:
http://www.amazon.com/BIC-America-F1.../dp/B0015A8Y5M
Not a bad system for the price, which fits your budget nicely, even with the speaker wire and interconnects ( from monoprice.com)
5seonds is offline
post #8 of 69 Old 10-24-2011, 09:17 AM - Thread Starter
bahuffma's Avatar
Thanks so much for these replies! This is exactly what I am needing. Regarding the speakers, i would like to keep the small (not towers?) if i can. Any thoughts on the energy 5.1?
bahuffma is offline
post #9 of 69 Old 10-24-2011, 10:08 AM
wowyahoo's Avatar
Receiver: $260
Subwoofer: $190
http://www.amazon.com/BIC-America-F1...=5336055023-20
bookshelf(pair): $132
http://www.ebay.com/itm/PAIR-Monitor...item53e97394ac
Center: $112
http://www.ebay.com/itm/CS2-BLACK-Se...item5ae2d90680
Surrounds(pair): $90
http://www.ebay.com/itm/PAIR-Monitor...item35b5c2dce2
TOTAL: about $784 then cables and what not
EDIT: Also, if you want to hear these speakers go to best buy and listen to the TSi line. They are nearly the same speaker; for example, the Polk monitor 40 series II is this speaker http://www.bestbuy.com/site/Polk+Aud...825471&st=polk TSI&cp=1&lp=4 ... it cose more because it's "new"
wowyahoo is offline
post #10 of 69 Old 10-24-2011, 10:37 AM - Thread Starter
bahuffma's Avatar
[quote=afrogt;21119480]
QUOTE]
This seems like a great deal..Being that it is the last day for the deal, should i jump on it and worry about the other speakers later? Or are there equally good subs for the same price?
bahuffma is offline
post #11 of 69 Old 10-24-2011, 10:49 AM - Thread Starter
bahuffma's Avatar
Thought i'd throw in the layout of the room..the long wall is probably closer to 25 feet,not 35.
bahuffma is offline
post #12 of 69 Old 10-24-2011, 10:49 AM
MarlinFan's Avatar
Quoted: 14 Post(s)
[quote=bahuffma;21119954]
QUOTE]
Yup. You won't see that sub at that price for a while.
MarlinFan is offline
post #13 of 69 Old 10-24-2011, 11:07 AM
afrogt's Avatar
Liked: 983
I have that Energy s10.3 sub, I highly recommend it.
Afro GT
afrogt is offline
post #14 of 69 Old 10-24-2011, 11:36 AM - Thread Starter
bahuffma's Avatar
Ok, so yet another question..how important is having a high quality subwoofer. In other words, would it be worth spending more on the other speakers and receiver and getting a sub that is a little less expensive? I don't have problem with spending 200 on a good one (energy s10.3), but just wonder how noticeable the difference would be with a cheaper one (say BIC America - 8" 100-Watt Powered Subwoofer; $99 at best buy)?
bahuffma is offline
post #15 of 69 Old 10-24-2011, 11:40 AM
afrogt's Avatar
Liked: 983
Very important! The s10.3 will run circles around the smaller bic 8" subwoofer. The s10.3 has tight bass and is good for movies and music.
The little bic sub won't play as deep and inexpensive subs are generally boomy.
Energy s10.3 goes down to 21hz, the 8" Bic only goes down to 37hz. Big difference!
Afro GT
afrogt is offline
post #16 of 69 Old 10-24-2011, 12:20 PM - Thread Starter
bahuffma's Avatar
Great thanks! I think i'm gonna go ahead and get the s10.3!
bahuffma is offline
post #17 of 69 Old 10-24-2011, 12:51 PM - Thread Starter
bahuffma's Avatar
Thoughts on these speakers..Boston Acoustics CS2310B? Looking at the Denon receiver (AVR1611) at vanns.com and these speakers can be added for $199.
bahuffma is offline
post #18 of 69 Old 10-24-2011, 12:55 PM
wowyahoo's Avatar
for music: the energy
for HT: the bic f12
wowyahoo is offline
post #19 of 69 Old 10-24-2011, 01:03 PM - Thread Starter
bahuffma's Avatar
Sorry..new to all this. what do you mean by HT?
bahuffma is offline
post #20 of 69 Old 10-24-2011, 01:05 PM
WhereToStart's Avatar
Quoted: 14 Post(s)
Home theater- movies
WhereToStart is offline
post #21 of 69 Old 10-24-2011, 01:05 PM
wowyahoo's Avatar
Home theater... the bic f12 has a 12" driver while the energy has a 10" driver...
wowyahoo is offline
post #22 of 69 Old 10-24-2011, 01:07 PM - Thread Starter
bahuffma's Avatar
I should have at least guessed that!! Feelin off my game today..anyway, i am definately more interested in speakers for home theater. I'm sure the energy sub would also be good for movies as well..correct? What makes one better for HT?
bahuffma is offline
post #23 of 69 Old 10-24-2011, 01:12 PM
wowyahoo's Avatar
http://www.hsuresearch.com/products/performance2.html you might look into this as well
the sub itself is $350 and the speakers alone are $300... you can get both for $550
hsu is highly regarded here!
wowyahoo is offline
post #24 of 69 Old 10-24-2011, 01:26 PM - Thread Starter
bahuffma's Avatar
Hmm..well that gives me something else to think about. The only issue with that is the shipping is $71..making a total of $620. The energy sub is $200 total, for a difference of $420. Are there other speaker sets (minus sub) that are as good as the Performance for under $420?
bahuffma is offline
post #25 of 69 Old 10-24-2011, 01:42 PM - Thread Starter
bahuffma's Avatar
Does anyone have any experience/review of the Performance2? http://www.hsuresearch.com/products/performance2.html
bahuffma is offline
post #26 of 69 Old 10-24-2011, 01:52 PM
Boojum42's Avatar
Has anyone heard both that Hsu Ventriloquist set and the DefTech ProCinema 800? The DefTech is my current frontrunner for the best satellite speakers I've found in my price range, but Hsu gets a lot of praise around here as well, and would also be somewhat cheaper. Can't just go to a store to listen to it, though.
Boojum42 is offline
post #27 of 69 Old 10-24-2011, 01:57 PM
afrogt's Avatar
Liked: 983
Bahuffma,
I've heard the performance2 speaker set. The subwoofer is awesome but I'm not that big on the Ventriloquist speaker set. They're still small satellite speakers and I'd rather have bookshelf speakers instead.
Concerning the F12 vs s10.3 if you're main purpose is home theater the larger F12 will have more impact than the smaller s10.3. Plus you've got a 15 x 18 room so the F12 might be a better choice.
I'm completely happy with my S10.3 but my room is probably 13 x 15.
Afro GT
afrogt is offline
post #28 of 69 Old 10-24-2011, 02:50 PM - Thread Starter
bahuffma's Avatar
Thanks Afrogt! I think I may go with the F12..although still considering the Performance 2. The $620 cost with shipping for these is a little much, plus as I said I already have nice Bose bookshelf speakers to use. If i use my Bose, i would then need to get the sub, 2 rears, and a center (buying individually??; which would probably add up pretty quick). Is there any problem with mixing speakers (ie. using my Bose as the 2 front speakers)? Or would I be better off going with a 5 speaker set? I really do not want to get tower speakers..would like them to be on the smaller side due to space issues.
bahuffma is offline
post #29 of 69 Old 10-24-2011, 03:08 PM - Thread Starter
bahuffma's Avatar
Question regarding placement of center channel speaker.my options for placement are either in front of the tv on the floor or directly behind the tv in which a tv would be blocking the speaker (only a 3 inch gap under tv; set on stand on top of entertainment center). Where is the best placement for this?
bahuffma is offline
post #30 of 69 Old 10-24-2011, 03:11 PM
ccotenj's Avatar
Liked: 101
definitely NOT behind the tv... and on the floor isn't a great option either...
over the tv mounted to the wall and aimed down towards the listener would work... i've had success doing that when setting up systems for people with limited space available...
- chris
ccotenj is offline
Reply Speakers
