Need Speakers! Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-27-2011, 01:59 PM - Thread Starter
cyniclaus's Avatar
I'm looking for a 7-speaker setup for my HT. I'm getting rid of my Klipsch Synergy F30 towers and C3/S3 surrounds as they were too harsh/bright for me. They were OK for movies, but listening to DVD-A and FLAC was disappointing. I am anticipating spending under $3000. I guess I could go with cheapies for the rears since they will really only be used in movies. I'm planning on keeping my MWF-15 sub and buttkicker LFE
I'll be powering them off an Onkyo TX-SR805 that I bought for it's audio-centric quality and tested output of 130w/ch @.1% with all channels driven. Since the Onkyo is THX Ultra2, should I be looking at THX speakers?
Don't care if they are bookshelves or towers or what they look like as long as they are gray or black.
I want something flexible since I'll likely be moving in a year, but my current HT room is approximately 13' across and 17' deep, acoustically treated with GIK tri traps and 6 x ATS fiberglass panels on the primary reflection points.
Thanks in advance for any recommendations!
cyniclaus is offline
post #2 of 4 Old 10-27-2011, 04:21 PM
zieglj01's Avatar
Quoted: 963 Post(s)
Liked: 862
These are good and black - NHT - You can still buy them with out the sub.
http://www.nhthifi.com/NHT-Classic-T...System-Package
Get another pair of Absolute Zero's to make 7.1
And, you can get Focal in black
http://www.spearitsound.com/focal/focal_700_series.htm
Do not worry about buying THX speakers.
__________________________________________
Who AM I
zieglj01 is online now
post #3 of 4 Old 10-27-2011, 04:32 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
Smaller Paradigm Studio v.5's would be my first recommendation. I love 'em. So much more musical and transparent than the Klipsch's.
http://www.paradigm.com/products/pro...tudio-speakers
Another suggestion if you don't have a brink 'n' mortar Paradigm retailer handy...
Energy RC-70 (front) - $1,200 a pair
Energy RC-LCR (center) - $350 each
Energy RC-10 (two pairs for surrounds) - $300 a pair
Good prices at Vanns.com They have promo codes every so often too. They're well received, laid-back speakers for the money on this forum. Black ash.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #4 of 4 Old 10-28-2011, 09:22 AM - Thread Starter
cyniclaus's Avatar
Thanks for the suggestions thus far; I am looking into them
Reply Speakers
