Building a room - need audio advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-06-2011, 08:23 AM - Thread Starter
Vaison's Avatar
After having a home built over 3 years ago, I finally have the ability to build a room in the basement just for me. With that being said, I have to be budget conscious. The room will be roughly 12x24 with 8 foot ceilings. I intend to put a plasma in the middle of one of the 24' walls and would need to add a surround system, receiver, blu ray and a directv box. The plasma, tv and blue ray I have under control. But it has been many years since I have bought any type of surround systems and now seek advice.
My research so far has basically been cnet reviews and random forum reading. I like the idea of the Energy Take Classic 5.1 as I can mount everything to the wall and out of the way of a 2 year old. Floor speakers are out because of that. I've seen some mention that if I choose that system, I should only buy the sats and center channel, opting to purchase an ungraded Energy sub, but I can't seem to locate a way to make that purchase for $400. However, I am open to other options for wall mounted, semi small system for both movies and music. I listen to quite a range of things and I'd like the speakers to be able to handle movies as well as being able to play the music pretty loud when I want.
As for a receiver, I am completely lost. My old systems had CDand DVD players but this one will not. I'd like to be able to connect something like an ipod if needed. But I don't have an iphone or ipdad for the airplay function so that isn't important to me. I'd say that spending no more than $500 on the speakers and $400 on the receiver would be ideal.
I hope I've given enough info to warrant advice from you folks. I appreciate your feedback. Thanks.
Vaison is offline
post #2 of 9 Old 11-06-2011, 08:42 AM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
If it were me, I'd put $600 into the speakers an $300 into the receiver. Something like the Denon AVR-1611. Get the Energy Take Classic 5 Pack at $300, and then the Energy S10.3 sub. Or use Polk Monitor series or Infinity Primus speakers with that Energy.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 9 Old 11-06-2011, 08:42 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The energy take classics are a bit small for your room might want to look at Infinity P152's with a Infinity pc350 center with a Bic F12 subwoofer
crazyrob425 is offline
post #4 of 9 Old 11-06-2011, 11:18 AM - Thread Starter
Vaison's Avatar
With infinity set, would I need to match them somehow? I guess I've always gotten the impression that the premade sets are balanced and takes the guess work out of having to piece together a system for it to sound good?
Vaison is offline
post #5 of 9 Old 11-06-2011, 11:56 AM
Quoted: 443 Post(s)
Liked: 337
Well the Infinity Primus P152 are matched to other speakers in the Primus line So buying other speakers in the Primus line gives them the same balance sign you are looking for
http://www.infinitysystems.com/home/...USA&Country=US
post #6 of 9 Old 11-06-2011, 02:13 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
I have a question to the OP:
Is this "man cave" a dedicated room for A/V or a theater? The reason I ask is that you have a 12x24 room and you're placing your TV on one of the wide walls. Usually, if it's possible, you want to orient your TV or screen with it placed on one of the short walls and work from there.
Just asking...
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #7 of 9 Old 11-06-2011, 07:17 PM - Thread Starter
Vaison's Avatar
No, it isn't going to be a dedicated room. I understand what you are saying about putting the set on the shorter walls but it doesn't work well for me. I would prefer floor speakers up front, but that wont work either. I may build everything in wall or RF if so everything is hidden and clean. I just want something that rocks without having to destroy my wallet. Building the room is going to be pricy enough.
Vaison is offline
post #8 of 9 Old 11-06-2011, 07:47 PM - Thread Starter
Vaison's Avatar
So with the deals on Crutchfield, I can get the Infinity P162 for $85 each plus the PC350 for $200 more - $540 total. But I need still need a sub. Do you think this set would be good for my room at that price? What sub would fill these?
Vaison is offline
post #9 of 9 Old 11-07-2011, 11:41 AM
Liked: 1766
You have a decent sized room, so you need speakers and a sub that can handle it.
A nicer sounding alternative to those particular Infinity's, IMHO, that would play well in that room would be these due to price vs. performance. Get a little bit at a time, if you need to.
HSU HB-1 mk2 bookshelf monitors... $129 each (sale price)
HSU HC-1 mk2 center... $209 each (sale price)... some use an HB-1 as a center for three identical speakers across the front, depending on space requirements.
http://www.hsuresearch.com
Denon AVR-1712 - $399 (probably will go on sale towards the holidays)... 90 watts / channel.
Add a sub later.
Reply Speakers
