Mounting MartinLogan MLT-2 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-11-2011, 10:48 AM - Thread Starter
kmusku's Avatar
Hi All,
I recently bought MartinLogan MLT-2 series, and I'm planning to mount these on my wall. But when I look at the back of the speakers, there are 2 holes which seems to be meant for mounting, but I don't see any threads to these holes, so that the screws fit them tightly.
Can someone please help regarding this like how to mount these speakers.
kmusku is offline
post #2 of 3 Old 11-12-2011, 04:47 AM
buzzy_'s Avatar
Quoted: 79 Post(s)
Liked: 105
Congratulations. Nice speakers.
Your set must have arrived without the manual. Here's a replacement:
http://www.martinlogan.com/pdf/manuals/manual_mlt2.pdf
See page 7.
They have keyhole mounts, often used on light speakers like these. You put a screw into the wall, and hang the speaker on the screw, kind of like you'd hang a picture.
It says "If model has two key holes, measure distance apart and use two screws." You can adjust the angle a little by how far out you leave the screws.
You don't need heavy duty screws, anything that will stay in the wall will do for these.
buzzy_ is offline
post #3 of 3 Old 07-09-2013, 06:22 PM
scottw311's Avatar
I used a #12 machine screw in the top hole on the back of the speaker to mount to brateck sb-29 wall mounts. Holds nice and tight, no issues whatsoever.
scottw311 is offline
Reply Speakers
