Sansui sp-2500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-18-2011, 07:46 AM - Thread Starter
ludespeedny's Avatar
Quoted: 28 Post(s)
I just started building my HT system, and for a receiver I bought a Pioneer Vsx-521-k. I have a pair of Sansui Sp-2500's right now hooked up to it and I will be adding more speakers as I am able to afford good ones.
The speakers sound good, but it seems lacking on the bass, which I find odd since they have a 12" woofer in them.
Any suggestions?
I also am considering pulling the trigger on some Polk RM6750's, maybe it is time to do that and get rid of these?
ludespeedny is offline
post #2 of 5 Old 11-18-2011, 08:29 AM
m_vanmeter's Avatar
check the speaker setup menu in the receiver and make sure they are set to "large", or whatever Pioneer calls full frequency speakers that can handle the lower bass frequencies. You will need to check the crossover frequencies to confirm if they are set lower and not cutting off low bass to the Sansui's.
PS: I have a set of Sansui speakers with the 15" woofers (mid 1970's era) hooked up in a den for a stereo system......still love the sound those beasts produce !!! SP-7500 models....I think....haven't looked at the name plates in a number of years.
m_vanmeter is offline
post #3 of 5 Old 11-18-2011, 11:12 AM - Thread Starter
Quoted: 28 Post(s)
The MCACC set it to large, and the crossover is 100.
post #4 of 5 Old 11-18-2011, 11:24 AM
m_vanmeter's Avatar
100 Hz is way too high, that would be appropriate for 4" satellite speakers. Try 60 Hz and if the Sansui's seem to accept that, then slowly work lower until you think they may be distorting.
post #5 of 5 Old 11-18-2011, 11:26 AM - Thread Starter
Quoted: 28 Post(s)
Ok, I'll try that. I had changed it manually to 80 and 50 then back to 100, cause I didn't notice a distinct difference
Reply Speakers
