Help/Questions about Energy Veritas V-Mini Bookshelf - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-19-2011, 08:53 AM - Thread Starter
Pipa's Avatar
I bought 4xV-mini bookshelf speakers with a Energy Veritas V-Mini LCR (Center Channel)
My Room is 17x16 wit 9 foot ceilings. (open concept floor plan)
I heard these speakers and they sounded really crisp, loud and clear.
About to purchase a Denon AVR-2111CI as I can get it for a good deal.
80% movies/tv and 20% music
Few questions:
Is this a good setup me?
Is the amp a good fit with my system?
What type of subwoofer would you recommend? Budget is around $400-$500
Pipa is offline
post #2 of 5 Old 11-19-2011, 09:35 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I have a pair of RC Mini's and they're very similar to your V-mini's.
17 x 16 is a good sized room but the Mini's might be okay. Did you get a great deal on them or something? The reason I ask is because the V5.1 is only $30 more right now at Vanns and would be a much better choice.
V5.1
http://www.vanns.com/shop/servlet/it..._c=site_search
V-Mini
I have RC Mini and RC-10's and the difference is pretty significant, more bass and room filling sound from the larger speakers. It would be the same between the V Mini and V5.1. I would at least want the larger V5.1 as my front speakers instead of the V Mini.
As far as subwoofers, the guys in the subforum would probably recommend one the following speakers.
Epik Legend
http://www.epiksubwoofers.com/legend.html
Outlaw LFM-1
http://outlawaudio.com/products/lfm1plus.html
Emotiva Ultra 12
http://emotiva.com/ultra_sub12.shtm
Denon 2111 should be fine. Of course I didn't know there was a 2111? I know about the 1911 and 2311 but not 2111. Are you overseas?
Afro GT
afrogt is online now
post #3 of 5 Old 11-19-2011, 10:22 AM - Thread Starter
Pipa's Avatar
Sorry my mistake its a Denon AVR-2112CI.
I got the V-mini's for $159.99 each and the wife didn't want anything big so the mini's fit the bill as I am going to mount the front 2 on the corners.
Thanks for the feed back.. I did hear them in a similar size room and they were quite loud and clear but I guess I will see when I get home.
Pipa is offline
post #4 of 5 Old 11-19-2011, 04:24 PM
afrogt's Avatar
Liked: 755
Well, when the wife speaks you gotta listen!
I think you'll be fine you've already heard them in a similar size room. Music listening will be more critical than movies but you're 80% movies so I'll think you'll be happy.
Enjoy!
Afro GT
post #5 of 5 Old 01-16-2013, 07:44 AM
puddnhead's Avatar
I love the V-minis, and ironically also have mine hooked up to a a Denon 2112ci in a slightly smaller room. I suspect Pipa is as happy with his, as I am with mine. IMO they are superior to the RC-mini.
puddnhead is offline
Reply Speakers
