Is there a way to power in-wall speakers without receiver ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-28-2011, 09:42 AM - Thread Starter
jabney's Avatar
Ok here's the scenario, I currently have a Sony all-in-one cd/receiver which powers my 4 in-wall surround speakers. The problem is i dont have room for it in my TV niche above the fireplace but without the reciver i can't power my surround speakers. I thought about adding a sound bar but cant find any that will also power 4 additional surround speakers. Does anyone have a solution to this issue ?
This wasn't a problem before when i had a 40'' LCD but with the 47' i have no extra clearance for a receiver. Please tell me there's something out there to help me out.
Thanks soo much!
Jay
jabney is offline
post #2 of 17 Old 11-28-2011, 10:14 AM
Hamilcar Barca's Avatar
Do you have any free space at all?
Hamilcar Barca is offline
post #3 of 17 Old 11-28-2011, 10:14 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
You need an amplifier and you have to find a place to put it. Should be no larger than a receiver.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #4 of 17 Old 11-28-2011, 11:29 AM - Thread Starter
jabney's Avatar
Right now i have a HTIB receiver (Sony DAV-FX100W) that powers my speakers, but i honestly cant even use it to play DVD's because the tv blocks access to it. The existing receiver works fine but in order to load dvd I literrally have to move my TV in order to access the slot-load drive. Then put the TV back and then commence to watching...
I guess another alternative may be to see if i can mount the exisiting receiver vertically in the niche....nope just thought that through it won't work as my tv niche has sliding doors which prevents that type of mounting.
It looks like im stuck....
jabney is offline
post #5 of 17 Old 11-28-2011, 11:36 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
I suppose a mere mention of RECEIVER one thinks of a 50LB behemoths they sell nowadays, but I've always like slim-line components. I have 1U (1.75" high) power amps. So if there's $, there is a way.
MrBobb is offline
post #6 of 17 Old 11-28-2011, 11:39 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
You can buy a small 2 or 4 channel amp that would be smaller than a DVD/receiever, but it would take up some space. Something like this...problem is, you may or may not be able to control volume with your TV remote.
http://www.amazon.com/Dayton-DTA-100...xp_grid_pt_2_2
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #7 of 17 Old 11-28-2011, 11:49 AM - Thread Starter
jabney's Avatar
Thanks i checked that out but it only powers two speakers and i have 2 front and 2 side surronds so i need something that powers at least 4 speaker.
I'm not appossed to spending $$$ in fact i have liberty (WAF) to spend whatever to get this problem fixed without construction . The only thing i cant do again is demo and rebuilt the niche as i did 3 years ago in order to go from accomodating a 40" to the 47". Do you have any suggestions on what i can purchase ?
jabney is offline
post #8 of 17 Old 11-28-2011, 12:17 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Google for "1u power amplifier" or "slim multichannel amplifier." A quick google yielded me this SITE, looks like a Pro equipment site, I don't have direct experience with them. Look further and you should find more main-stream (consumer) vendors, although be ready to spend up to $500. If yr patience, maybe able to get used if ur not oppose to that.
The items on the proacoustic site is also spec'ed as D-Class. D-class amps are a class of amplifiers designed to more power in small packages, some purists turn their noses at class-Ds so you have to decide (class D used alot in confined car stereos). I would try to get the smallest package possible with a more standard class A-B myself but nothing on top of my head, ur legwork.
MrBobb is offline
post #9 of 17 Old 11-28-2011, 12:26 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
How about a slim receiver from Marantz like the nr1602 or nr1501? Will that work?
crazyrob425 is offline
post #10 of 17 Old 11-28-2011, 12:43 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Can you supply a picture of the niche from closeup and one from further back that encompasses the front of the room? That might aid suggestions.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 17 Old 11-28-2011, 12:57 PM
Elihawk's Avatar
Liked: 856
This is about as "not tall" as any AVR I have seen recently...Sherwood R-904N
http://www.amazon.com/Sherwood-R-904...510094&sr=1-12
Elihawk is offline
post #12 of 17 Old 11-28-2011, 01:16 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
+1, photo please
Also, why can't you raise the TV a few inches so it doesn't block the niche?
rick240 is offline
post #13 of 17 Old 11-28-2011, 03:59 PM
cel4145's Avatar
Liked: 2985
Originally Posted by rick240 View Post
+1, photo please
Here's another thought. Your receiver/dvd player has the dvd on the left. If it were on the right, would that help? Perhaps a new blu-ray player that has the drive on the right side? Or, a Sony PS3 can be mounted vertically and it wouldn't be as tall as you receiver. It's a blu-ray/dvd player.
Pictures really would help, though
cel4145 is offline
post #14 of 17 Old 11-28-2011, 07:57 PM
Ironlight's Avatar
Do you need to just run one HDMI cable from the receiver to the TV? If so maybe you can put the receiver somewhere outside the niche to the side somewhere and run a longer HDMI cable to it?
Pictures would help a lot.
Ironlight is offline
post #15 of 17 Old 11-29-2011, 11:36 AM - Thread Starter
jabney's Avatar
Pics as requested. One pic shows the Niche as a whole. The other shows a closeup of the bottom right of the TV and the silver thing at the bottom is the exisiting dvd/receiver that i have to move the TV to reach.
thanks for all the help guys!
Pics added to thread.
jabney is offline
post #16 of 17 Old 11-29-2011, 12:00 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Another option:
Mount the TV wall-style using an articulated arm, that way u can rid of the stand and frees u some space on the bottom, then purchase a separate DVD player, some are very thin and look like it will fit in there, and keep the receiver for amplification only.
MrBobb is offline
post #17 of 17 Old 11-29-2011, 01:58 PM
Slare's Avatar
I think all you need is a IR repeater or a receiver that has a jack for a remote IR sensor.
Put the receiver anywhere and wire it up. Behind the TV. In a closet. Up in the attic. IR receiver goes in your nook. Everything runs as normal, just the AVR is out of site. It sounds bad but think about it, how often do you actually have to touch the AVR once everything is installed and setup?
Also looking at it you might have enough room to work with to take the stand off the TV and put it on a wall mount, creating enough clearance below for a slim line avr.
Slare is offline
Reply Speakers
