Improve my speakers? Cash in on an X-Mas deal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 12-02-2011, 10:03 AM - Thread Starter
RYANtheTIGER's Avatar
Quoted: 288 Post(s)
Liked: 30
Hey guys I've got the setup listed below. I have invested $$$ into my TV & Receiver. I got my front speakers on deal last year after some help from AVS. My rear and sub are part of a HTIB that I got a few years ago. That being said, I would like to maximize my audio experience per my budget. I'm not an audiophile, but I figure I might as well take advantage of X-Mas deals if at all possible. My budget is $300.
TV: Pioneer Elite Pro 111FD
RECEIVER: Pioneer VSX-1121-K 7.1
FRONT: Energy C-100 (L/R) & C-C100 (C)
REAR & SUB: JBL SCS 180.6S
Thanks for your help!
RYANtheTIGER is offline
post #2 of 29 Old 12-02-2011, 10:12 AM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
That sub is very wimpy compared to what you can get for $300. To greatly improve the front speakers, you'd need to replace all three and spend some good money probably beyond your budget. I would put the $300 into the Klipsch RW-12D on sale for $300 (promo code EMCJHKJ65) or the BIC PL-200 at $250 (check to see if this special is still available). That would greatly enhance your HT experience.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 29 Old 12-02-2011, 10:28 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
THANKS ... Like I mentioned, I'm not an audiophile and my knowledge on the audio-side of things is little. So, this might be a dumb question, but why do you suggest an amp? What does it add to the overall sound?
post #4 of 29 Old 12-02-2011, 10:35 AM
cel4145's Avatar
Liked: 2991
An amp? Those are subwoofers. I'm confused.
post #5 of 29 Old 12-02-2011, 10:36 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
Sorry, I meant sub. Same questions, though.
post #6 of 29 Old 12-02-2011, 11:06 AM
cel4145's Avatar
Liked: 2991
It adds significant bass. There's a lot of good bass content in movies that HTIB sub you are using won't effectively be able to produce. If you want to "feel" the HT experience, you need a better sub.
post #7 of 29 Old 12-02-2011, 11:10 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
Does a sub benefit my front & rear speakers (ie in clarity, crispness, etc)? What about watching cable or other things without bass? Do I just notice the bass? I ask because you mentioned that my current bass was weak and my wife is not a fan of it as it is.
post #8 of 29 Old 12-02-2011, 12:27 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
post #9 of 29 Old 12-02-2011, 01:22 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
The above are $99 - worth it? Better than my Energy's? Or still go with a bass?
post #10 of 29 Old 12-02-2011, 01:39 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
Heck, if I got the JBL bookshelves, can they serve as my rear speakers?
post #11 of 29 Old 12-02-2011, 03:25 PM
cel4145's Avatar
Liked: 2991
Yes. You could use the JBL speakers as your rears.
I don't know which are better between the Energy or the JBLs. But if you replace the front L/R, you should replace the center, too, with the same series JBL. It's important to keep them the same for the front sound stage.
Maybe try the JBLs. If you like the sound a lot, get the matching center. If not, use them in the rear.
post #12 of 29 Old 12-02-2011, 03:51 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
I let the $99 deal pass. Maybe I should have jumped on it as the sub will be on deal later on as well.
It almost sounds like I'm back at Square 1. What is my best option? Sub? Something like this:
http://www.amazon.com/Polk-Audio-5-C...=2J8I2QA4MK9KP
post #13 of 29 Old 12-02-2011, 03:55 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
That is the purpose of the subwoofer, to add lower frequencies to your system. This also allows your receiver to produce only the higher frequencies which will enable your speakers to sound better since they don't have to put out as much bass which can make them sound muffled.
It is highly recommended that you get a subwoofer.
Afro GT
afrogt is offline
post #14 of 29 Old 12-02-2011, 04:00 PM
afrogt's Avatar
Liked: 756
Why are you looking at those Polk RM95 speakers? You don't even need them.
What you need is a better subwoofer and two have already have been pointed out to you.
Klipsch RW-12d for $299 after using promo code
http://www.newegg.com/Product/Produc...=1ur2e9xjzaiou
BIC PL-200
http://slickdeals.net/permadeal/62466
You don't need any more speakers, you need a better subwoofer if you want better bass!
Afro GT
afrogt is offline
post #15 of 29 Old 12-02-2011, 04:09 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Oh what a diff. a good sub makes.
I agree with the sub recommendation.
I've got Polks 70's and CS2 for the front stage in a 7.1 set up. They're even being amped for extra power driven.
My sub runs off a different circuit and the switch of off when not in use. When I forget to turn it on for a movie, the movie sounds pretty good, when I realize what I'm missing, I turn on the sub and presto, we're suddenly back in the "theater".
Of course I'm running an Empire on 1/4 volume but the aforementioned subs sound great for the set up at hand.
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #16 of 29 Old 12-02-2011, 04:26 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
So a new sub it is ... Any other sub suggestions? What about this one:
http://www.amazon.com/gp/aw/d/B00166...A2ERWWPLDX80YE
post #17 of 29 Old 12-02-2011, 05:24 PM
cel4145's Avatar
Liked: 2991
Stick with the PL-200 or the RW-12D. Those are excellent deals. If you want to go cheaper, get the BIC F12. But the other two would be better choices.
post #18 of 29 Old 12-02-2011, 07:57 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
Sorry to be so naive, but if I go with the PL-200 or RW-12D, I will hear a difference in my current speakers? I'll be getting more out of my Pioneer 1121? Will my current speakers be adequate (I know that's relative)?
post #19 of 29 Old 12-02-2011, 09:39 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Are your L/R speakers towers? Do you have them set to small? Setting them to small make a difference in how they sound. I didn't really believe it at first but I did some back to back comparisons with a CD, and taking the base out of the towers made a great difference in detail.
When you set them to small, the low frequencies are sent to your sub and relieves the F/R speakers of any low end duties. This sound about right to the others here?
Set up:
post #20 of 29 Old 12-02-2011, 09:55 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
They are bookshelves, not towers.
http://www.energy-speakers.com/na-en...-100-overview/
Does this make a difference?
post #21 of 29 Old 12-02-2011, 09:58 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Not really, you'll set them to small even though they are small. With my receiver, I have the option to set them to "Full Band" which is equivelent to large.
Set up:
post #22 of 29 Old 12-02-2011, 10:50 PM
cel4145's Avatar
Liked: 2991
You have a nice receiver. The sub will plug into the subwoofer out on the back and then set the crossover to 80hz (you can experiment beyond that). The sub will help the speakers by taking over some of the bass, in addition to how much lower lower bass you will get.
And certainly, at some point in the future you might want to upgrade your speakers with new L/R/C. But save up $600 or so and get something nice to go with that nice receiver.
post #23 of 29 Old 12-03-2011, 08:54 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
So if I ordered the PL-200 sub, I will be fine on speakers? The sub takes care of the bass so that my speakers can handle the highs and produce better sound there? In the end, I'll be better off and can wait until I have more $$$ to upgrade my speakers?
post #24 of 29 Old 12-03-2011, 10:54 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
BIC PL-200
Which of these would you recommend? I do somewhere in the following:
TV/Blu Ray - 80%
Music - 20%
post #25 of 29 Old 12-03-2011, 11:10 AM
vcatalasan's Avatar
When I finally hooked up a subwoofer, my front speakers sounded so much clearer. Invest in a good subwoofer now, enjoy and upgrade other speakers later, you may already be happy with what you have.
vcatalasan is offline
post #26 of 29 Old 12-03-2011, 04:17 PM
cel4145's Avatar
Liked: 2991
TV/Blu Ray - 80%
Music - 20%
Either sub will be a good value at those prices. If you are unsure, go with the PL-200 and save your money toward speakers
post #27 of 29 Old 12-03-2011, 04:21 PM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
I really don't know much when it comes to audio. It's a $50 difference so I just want the better sub. I trust your recommendations.
post #28 of 29 Old 12-04-2011, 09:32 AM - Thread Starter
Quoted: 288 Post(s)
Liked: 30
Probably a dumb question, but does the sub affect which speakers I get down the road?
post #29 of 29 Old 12-04-2011, 11:09 AM
cel4145's Avatar
Liked: 2991
Either sub would pair equally well with new speakers.
Reply Speakers
