Can you recommend a center channel for >$200 that would go well with my setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-05-2011, 04:37 PM - Thread Starter
ahreno's Avatar
I have:
  • Elemental designs sub
  • 4 (old) Paradigm Titans that i'm using as surrounds
  • 2 (newish) The Speaker Company P6-Pr that i'm using as front right and left (should i move these to be surrounds and use the paradigms up front?
  • and a denon avr 3808ci
I have been using a Paradigm cc-150 but both speakers in it blew and i think i might as well replace as opposed to repair.
I have a budget of around $200. Should i go with another elemental designs product? Someone has some Paradigm cc90 bookshelfs and a center channel for sale on my local craigslist which is tempting
ahreno is offline
post #2 of 14 Old 12-05-2011, 05:20 PM
Timothy91's Avatar
Liked: 33
How the heck did you blow the original center?
Timothy91 is offline
post #3 of 14 Old 12-05-2011, 05:21 PM - Thread Starter
ahreno's Avatar
I'm not really sure... I think i was streaming a Phish concert on a new years eve. Excuse my lack of correct terms here but the foam/rubber ring around the speaker has separated from the plasticy part of the speaker.
ahreno is offline
post #4 of 14 Old 12-05-2011, 07:33 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
If so, your thread title should read: "Can you recommend a center channel for <</font>$200 that would go well with my setup?"
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5 of 14 Old 12-05-2011, 07:35 PM - Thread Starter
ahreno's Avatar
Thanks for catching that.
ahreno is offline
post #6 of 14 Old 12-05-2011, 07:58 PM - Thread Starter
ahreno's Avatar
would that paradigm cinemea cc be a good match? The craigslist seller will sell the two bookshelves (cinema 90s) and center channel for $70...seems like a killer deal.
otherwise HarmanAudio.com has Infinity CC225 on clearance for $212
ahreno is offline
post #7 of 14 Old 12-05-2011, 08:18 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Unless it will be a hassle to remove them from their installation, why not try three of the Titans in front right now? It would be a perfect timbre match.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #8 of 14 Old 12-05-2011, 08:21 PM - Thread Starter
ahreno's Avatar
I guess i never thought of that. Does it matter much that the titans i have are from the late 1990's? I'd have to replace my current center with a new Titan, or throw a new titan as a side/rear
ahreno is offline
post #9 of 14 Old 12-05-2011, 10:48 PM
cel4145's Avatar
Liked: 2991
You have nothing to lose by trying. If they sound good, it doesn't matter how old they are. I just sold a Paradigm Phantom v1 pair a few weeks ago that I have had for years. They still sounded great.
If it does sound good, then why not run 5.1 until you can save up for a nice set of matching L/R/C that would be a good upgrade to your system?
cel4145 is offline
post #10 of 14 Old 12-05-2011, 10:51 PM - Thread Starter
ahreno's Avatar
What would be a good upgrade to my paradigms? I dont have a need or desire to go to crazy on a home theater but I don't mind spending a couple hundred per speaker. i was thinking maybe three of these elemental designs... Does $200 buy a "decent" speaker?
http://www.edesignaudio.com/product_...roducts_id=967
ahreno is offline
post #11 of 14 Old 12-05-2011, 11:38 PM
cel4145's Avatar
Liked: 2991
I wouldn't recommend Elemental Designs to anyone. There have too many discussions about customer service issues on AVS, such as this one: http://avsforum.com/avs-vb/showthrea...ight=elemental
But that's up to you.
cel4145 is offline
post #12 of 14 Old 12-05-2011, 11:51 PM - Thread Starter
ahreno's Avatar
any suggestions?
ahreno is offline
post #13 of 14 Old 12-07-2011, 04:01 AM
cel4145's Avatar
Liked: 2991
I have not heard those Paradigm Titans. Which version number are they? Maybe someone would have an idea then.
As far as $600 for L/R/C, the HSU HB-1 and HC-1 are popular.
For a little bit more, a lot of people like the Energy RC series, on discount: RC-10 and RC-LCR.
The Ascend Acoustics CBM-170 SE and CMT-340 SE are also often recommended on AVS (I think there is a sale price if you click the Thanksgiving Day Sale link).
Maybe someone else can offer additional speaker suggestions in that budget range.
cel4145 is offline
post #14 of 14 Old 12-07-2011, 05:53 PM - Thread Starter
ahreno's Avatar
Thank you for the links. Much appreciated. I'm not sure the version number. I looked at the tag on them and it doesn't say anything. They're literally from 1998 or 1999. I bought them at the same time as my center channel, which is a Paradigm CC-150 if that helps.
The speakers seem fine but i realize it's probably time to upgrade...
ahreno is offline
Reply Speakers
