kef center speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-19-2011, 11:03 AM - Thread Starter
craig2425's Avatar
this is a question for my dad. hes looking for a new center speaker and the ones hes been looking at are klipsch kc25 and polk cs20 from best buy.
he has older kef coda 7 bookshelf speakers and im asking what would be a good match. im thinking that going with kef would be the best because it would match the fronts but they dont make that series anymore. i think that he would also buy new kef fronts too when he decides to.
i dont know much about kef speakers so any input on any of these center speakers would be great.
hes has a dennon avr 1905 receiver.
craig2425 is offline
post #2 of 9 Old 12-19-2011, 11:49 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I found a detailed review on the Coda 7 speakers from 2003, in the CNET Archive, and their efficiency and design seem to match up well with the Monitor Audio M2 speakers. For this reason I would suggest that the Monitor Audio Bronze BX Center Speaker would be a good match. I see it listed on the Audio Advisor website for $299. The second choice would be the Monitor Audio MCenter for $199.
Another good choice would be a the PSB Alpha CLR 1 speaker for $200.
The thing you want to match is the efficiency, as well as the general speaker type. The Coda 7 has an efficiency rating of 91db/watt, so you want something that is between 89db/watt and 93db/watt.
The Klipsch RC42 and KC25 are a bad match because they are 6-8 db more efficient than the coda 7 speakers, and that is going to be a big problem; that means that the Coda 7 requires about 8 times as much power for the same volume level compared to those Klipsch speakers; matching the levels would be almost impossible.
I don't think that Polk would be a good match for the Coda 7 from a sonic standpoint.
[quote=craig2425;21369420]this is a question for my dad. hes looking for a new center speaker and the ones hes been looking at are klipsch kc25 and polk cs20 from best buy.
commsysman is online now
post #3 of 9 Old 12-19-2011, 12:22 PM - Thread Starter
craig2425's Avatar
thanks for the response.
im pretty sure hes going to be upgrading his other speakers i just dont know when. i just know that his current center speaker is shot and my mom wants to buy him a new center speaker for christmas.
so what would be a good speaker? should he wait and buy all new speakers together?
[quote=commsysman;21369648]I found a detailed review on the Coda 7 speakers from 2003, in the CNET Archive, and their efficiency and design seem to match up well with the Monitor Audio M2 speakers. For this reason I would suggest that the Monitor Audio Bronze BX Center Speaker would be a good match. I see it listed on the Audio Advisor website for $299. The second choice would be the Monitor Audio MCenter for $199.
The Klipsch RC42 and KC25 are a bad match because they are 6-8 db more efficient than the coda 7 speakers, and that is going to be a big problem; that means that the Coda 7 requires about 8 times as much power for the same volume level compared to those Klipsch speakers; matching the levels would be very difficult.
post #4 of 9 Old 12-19-2011, 12:27 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
[quote=craig2425;21369796]thanks for the response.
post #5 of 9 Old 12-19-2011, 12:30 PM - Thread Starter
craig2425's Avatar
sorry but i dont understand what a sonic standpoint is.
what would you think about both those center speakers if the coda 7 speakers werent invloved?
is it better to worry about the center speaker or front? or all equal?
thanks again.
post #6 of 9 Old 12-19-2011, 12:31 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I am very partial to the sound of PSB speakers, personally.
If I was in the situation you describe, I would go ahead and get the PSB CLR 1 speaker $199) right now for the new center speaker, and then plan on getting the PSB Alpha B1 speakers ($299/pair) at some later date.
The PSB CLR 1 should match up well with the existing speakers, and then when you upgrade to the Alpha B1 speakers you will definitely have a matched set.
[quote=commsysman;21369820]
post #7 of 9 Old 12-19-2011, 12:33 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I just mean that I don't think the Polk speakers would sound as good as the Codas; it wouldn't be a good match.
post #8 of 9 Old 12-19-2011, 12:46 PM - Thread Starter
craig2425's Avatar
so pretty much he needs to figure out what speakers hes gonna want to go with otherwise hes just wasting his money.
post #9 of 9 Old 12-19-2011, 02:47 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
If he knows he is going to buy some new front speakers later for L and R, it certainly would make sense to get the center speaker now that is going to match what you intend to buy later.
Reply Speakers
