Energy RC-Micro 5.1 vs Energy Take Classic 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-22-2011, 10:43 AM - Thread Starter
kailas123's Avatar
Hi,
I understand this question has been asked few times in the past. Sorry for the repeat. I guess when this question came up in the past, price was a major factor and most of the discussions were based on the price point.
Now that both are available at the same price ($399) and we can set aside the price factor. Now my question is, which one is better in terms of the sound quality? My living room is 15x10.
Kailas
kailas123 is offline
post #2 of 17 Old 12-22-2011, 12:51 PM
jaeelarr's Avatar
Quoted: 47 Post(s)
Liked: 43
It looks like the RC setup is a bit better if only looking at specs. The SW goes down a tad lower, as so the sats. The RC is also slightly larger in terms of drivers.
jaeelarr is offline
post #3 of 17 Old 12-22-2011, 01:12 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
Your looking at the wrong specs.... The RC-micros have smaller drivers and don't go as low as the takes
Take classic
http://www.energy-speakers.com/na-en...-5-1-overview/
RC-Micro
http://www.energy-speakers.com/na-en...icro-overview/
crazyrob425 is offline
post #4 of 17 Old 12-22-2011, 01:23 PM
tarzan1234's Avatar
What do you mean by saying the RC has "better" specs?
Let me make a quick comparison of the frequency response:
Center channel: RC - 150Hz to 23KHz Take Classic- 110Hz to 20KHz
Satellite: RC - 150Hz to 23KHz Take Classic- 115Hz to 20KHz
Sub: RC - 36Hz to 180Hz Take Classic-33Hz-150Hz
I can't say which one is better because I have never listened and compared them directly. But if the specs are the only indicator, the Take Classic looks better to me. The Take Classic satellite and center speakers cover lower range, so does the Take Classic sub-woofer. They are also little bigger in size too, so they may have an advantage at higher volumes.
tarzan1234 is offline
post #5 of 17 Old 12-22-2011, 01:36 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
I haven't heard them, but I've ready good things about both the Take and Micro packages in the Energy Owners Thread (I own Energy RC-10s). I'd recommend the Energy Take Classic 5.0 package so that you can get a better sub, such as the Energy S10.3.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 17 Old 12-22-2011, 03:11 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
I recommend skipping both speakers systems and get two or three pair of CB-5's for $99/pr. If you buy 3 pair, use one CB-5 as a center.
http://www.crutchfield.com/p_732CB5/...Brand%7cEnergy
And add the Energy s10.3 for $199
http://www.newegg.com/Product/Produc...82E16882269026
This will blow away the Take Classic or RC Micros due their larger size and ability to play down to 80hz. It'll also blend better with the subwoofer.
If you'd rather have the CC-5 as a center you can get it from Vanns. I'm pretty confident they will come down off their $219 price quite a bit.
http://www.vanns.com/shop/servlet/it..._c=site_search
Afro GT
afrogt is offline
post #7 of 17 Old 12-22-2011, 03:36 PM - Thread Starter
kailas123's Avatar
I am inclined to go with @cel4145's suggestion - Take Classic 5.0 and S10.3. It's just $50 more for better sub.
Any suggestions for receiver that goes very well with these speakers? I am inclined towards Denon-1912. Appreciate your input.
-Kailas
post #8 of 17 Old 12-22-2011, 07:34 PM
cel4145's Avatar
Liked: 3002
afrogt is right though. If you can make the jump to the CB-5s, they are a better speaker than the micros and the take fives.
As for your receivers, it would be best to allocate more money towards speakers and sub than a receiver. That's where you will get the most sound benefit. What budget did you have in mind for the receiver? Any requirements?
cel4145 is offline
post #9 of 17 Old 12-22-2011, 07:49 PM - Thread Starter
kailas123's Avatar
@cel4145: I am going with CB-5x4, CC-5, and S10.3 options as suggested by @afrogt in another thread. As far as the receiver goes, my budget is around $500-$600. I am leaning towards Denon-AVR-1912. I like the AirPlay option. Another friend of mine also suggested Marantz NR1602 for its slim size but it pumps only 50W per channel. With my speaker options Denon-1912 seems to be a good choice. Again, I am not an expert and welcome any suggestions including other brands and models.
Kailas
post #10 of 17 Old 12-22-2011, 09:23 PM
cel4145's Avatar
Liked: 3002
If Airplay is important, that sort of limits your options; I think it's a fairly new features. One of the best ways to get a good value with a Denon receiver is to look at the previous year's model lines.
cel4145 is offline
post #11 of 17 Old 12-22-2011, 09:54 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
Most of Denon's previous year's models don't have airplay (can upgrade 3311). The 1912 or 2112 should work for you. That Marantz 1602 is a nice receiver. I wouldn't be concerned about the 50W/channel plus it has pre-outs for front L/R speakers (and of course the subwoofer).
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #12 of 17 Old 12-22-2011, 09:59 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
I wouldn't worry about AirPlay as a deciding factor in an AVR. That is easily remedied with a $99 apple tv2 which would give you much better options than AirPlay alone.
Life is hard, be harder.
Saints is offline
post #13 of 17 Old 12-23-2011, 11:02 AM - Thread Starter
kailas123's Avatar
I am getting a following package for $1000. Please let me know if it's worth.
CF-30 - two (front L&R)
CC-5 - one (C)
CB-5 - two (surround)
EW-100 sub
Denon AVR-1712
For AirPlay support, yes I have Apple TV2. What I am little worried is EW-100 sub compared to S10.3 sub.
Please share your thoughts.
Kailas
post #14 of 17 Old 12-23-2011, 12:52 PM
cel4145's Avatar
Liked: 3002
The EW-100 is not a very good sub and there are much better for its price (the S10.3 is much better). Where are you buying your package?
cel4145 is offline
post #15 of 17 Old 12-23-2011, 06:59 PM - Thread Starter
kailas123's Avatar
@cel4145: I dropped EW-100 and upgraded AVR to Denon-1912 (mainly for component up-conversion) in the package. I got it for $1015 from Electronics-Expo. I also got S10.3 separately for $200 from newegg. The total is ~$1200.
Kailas
post #16 of 17 Old 12-23-2011, 10:03 PM
cel4145's Avatar
Liked: 3002
Congratulations. That's a nice setup
Since I'm guessing this might be your first Denon and sub setup, read through AVS member batpig's guide and other resources (I, II, & III). It will help you to figure out how to use Audyssey to get the most out of your system.
cel4145 is offline
post #17 of 17 Old 08-12-2012, 05:51 PM
YamahaEnergycla's Avatar
I think the classics are the way to go bud. Love mine on my Yamaha RX-V373 5.1 av reciever!
Yamaha RX-V373 5.1 AV reciever,PS3 Gunmeatal gray MGS special edition,Pioneer Elite DV-37 progressive scan DVD/CD player,Energy take 5 classic 5.0 speakers,Pioneer Elite TZ-SW05 150W 10" Subwoofer,Monster M series component, HDMI,Subwoofer cables,Radio Shack 14 AWG flat copper speaker cable,Radio...
YamahaEnergycla is offline
Reply Speakers
