Polk Audio Tower Speaker (RTi12) setup advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-24-2011, 05:46 PM - Thread Starter
johaln2's Avatar
Hi everyone,
I would like to thank you for the great work here on AVS Forum, I been here quite often for help but never asked for a question in till today because most of my questions are already answered in most forum topics here.
I have a noob question on buying an audio system, I currently own Samsung U55D8000 series TV. I could get two Polk Audio Tower Speaker (RTi12) for pretty cheap price, I was wondering if I also need to buy a receiver or amp? and what is the difference between buying these tower speakers rather than 7.1 surround sound system?
Thank you all.
johaln2 is offline
post #2 of 8 Old 12-24-2011, 08:07 PM
G-Bull's Avatar
Originally Posted by johaln2 View Post
Hi everyone,
Thank you all.
Yes you need an a receiver.
The difference between 2 speakers and 7.1 surround? 5 speakers and a sub.
G-Bull is offline
post #3 of 8 Old 12-24-2011, 08:17 PM
zieglj01's Avatar
Quoted: 1713 Post(s)
Liked: 1630
Check this out
http://www.dolby.com/us/en/consumer/...ur-sound.html#
However, you can use a different brand for surrounds if needed - And you do not
need to match the sub brand.
"I was wondering if I also need to buy a receiver or amp? and what is the difference between buying these tower speakers rather than 7.1 surround sound system?"
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 8 Old 12-26-2011, 11:39 AM - Thread Starter
johaln2's Avatar
Thank you, based on my research I found out that these speakers need a good receiver with lot of power, what do you think is a good receiver that would compliment these speakers under $500 ? Also I read a lot about Bi-Amping or Bi-Wiring, and can't seem to figuring out if I should have these speakers in bi-wiring or bi-amping?
johaln2 is offline
post #5 of 8 Old 12-26-2011, 12:11 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Does your TV have analog (RCA) output jacks to connect an amplifier? Some models do not.
I personally am a believer in quality over quantity. A good stereo amplifier and 2 quality speakers is my choice. Spread the money around on 5 channels and you get much lower quality sound. Quality trumps quantity any time, in my book.
My recommendation to any friend of mine would be to go to Audio Advisor and get a Cambridge Audio 650A integrated amplifier for $499 (was $799; great deal) and a pair of tower speakers for about the same price. The Monitor Audio M4 speakers are excellent for $500 per pair and their M6 is even better for $650 per pair. They will sound better than anything Polk makes at any price.
The Polks are not too bad if that is all you can afford now, but you will probably get tired of them and what something that sounds better in the future. What is the price you can get them for?
If your TV has only a digital or HDMI sound output, you might as well get an HT receiver. An Onkyo TX-NR609 would be a good choice if that is where you need to go.
Thank you all.[/quote]
commsysman is offline
post #6 of 8 Old 12-26-2011, 12:21 PM
afrogt's Avatar
Quoted: 1437 Post(s)
Liked: 982
johaln2,
Are you in the US or Canada?
If the US, check out some of the Marantz receviers like the 5005 or 5006.
http://www.accessories4less.com/make...eceiver/1.html
http://www.accessories4less.com/make...AirPlay/1.html
And then if you feel you need more power add an external amp later.
Or these less expensive Yamaha receivers might work too.
http://www.amazon.com/Yamaha-RX-V667...4930771&sr=1-2
http://www.amazon.com/Yamaha-RX-A700...930771&sr=1-13
This Onkyo NR709 may be the best option and it right at your price point.
http://www.amazon.com/Onkyo-TX-NR709.../dp/B004V8KWQO
Afro GT
afrogt is online now
post #7 of 8 Old 12-26-2011, 09:36 PM - Thread Starter
johaln2's Avatar
Right now I got these two pairs of Polk for about $700, however I don't want to return these, they were such a hassle to bring home due to their weight 88 lbs!
Well I think my TV has RCA output jack, however I know it does have Optical Digital Audio Output. Should I just get a amp and connect it to my TV with Optical Digital Audio Output or by RCA? Which one has better quality RCA or Optical Digital Audio Output? and is this even possible
Thank you all.
[/quote]
johaln2 is offline
post #8 of 8 Old 12-28-2011, 07:49 AM - Thread Starter
johaln2's Avatar
Yes I am looking to go with Onkyo NR709, however I am not sure if the 3D output is good, I heard some issues with 3D on this receiver.
Originally Posted by afrogt View Post
johaln2,
johaln2 is offline
Reply Speakers
