Speakers for Television - Low Budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2011, 10:19 AM - Thread Starter
dabomb1188's Avatar
I am in the market for speakers for my father's television. I am looking to keep a low budget (under $200 is definitely where I want to be). I basically want something that will be a marked improvement from the built-in speakers on the television. I want to use this to be a base to build a sound system step-by-step.
I do not have a receiver, and am not sure if one is necessary. I have the Swan M200 MkII in my own place and love the sound.
Please let me know if any of you have any suggestions. Is this doable? Thanks again!
dabomb1188 is offline
post #2 of 6 Old 12-30-2011, 10:50 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you like the Swans, why not get them for your dad?
Afro GT
afrogt is offline
post #3 of 6 Old 12-30-2011, 11:09 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I saw some Sony SSF-6000 speakers on amazon yesterday for $120/pair. That would be good for you if you want floorstanding speakers. Nice price.
If you want a bookshelf/monitor type speaker, the Polk Audio Monitor 40 is a good speaker at $150 on Amazon or the Polk Monitor 30 for around $100.
You have to have an amplifier or receiver to drive the speakers.
You can go to the Sony website and get the STR-DH100 stereo receiver for $99 direct from Sony. Get the Sony SSF-5000 speakers from Amazon for $100 and you are in at $200.
Make sure that the TV has analog audio outputs to go to an amplifier or receiver; some sets do not have them (two RCA jacks, L and R).
If it doesn't you need to get a receiver with an optical digital input (assuming the TV has an optical digital sound output, which most do).
If you want a multi-channel receiver for expanding to an HT 5.1 -channel system later, the Onkyo TX-SR309 is a cheap option for $180 on Amazon. It has both optical and coaxial digital audio inputs as well as 5 analog audio inputs.
commsysman is offline
post #4 of 6 Old 12-30-2011, 11:10 AM
afrogt's Avatar
Liked: 755
Remember, he doesn't have a receiver.
It'll be a little tough to get a receiver and two speakers unless he goes ultra cheap like the Dayton speakers for $39/pr.
http://www.amazon.com/Dayton-B652-2-...5268601&sr=8-1
Afro GT
afrogt is offline
post #5 of 6 Old 12-30-2011, 11:27 AM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Unless you buy him some Swan speakers - then this is one of the few options
Infinity speakers
http://www.amazon.com/Infinity-Primu.../dp/B000LKC37W
Sherwood receiver - and it is decent.
http://www.parts-express.com/pe/show...number=252-125
When you build up in the future - donate the Sherwood receiver, and use
the Infinity for surrounds.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #6 of 6 Old 12-30-2011, 11:32 AM
Hamilcar Barca's Avatar
The Audioengine A2 is about $200/pr. I have their A5's attached to my TV.
I think that to "build a sound system step-by-step", you'd really want to start
with an amp or receiver and (passive) speakers. Otherwise, integration is at
least more difficult.
Hamilcar Barca is offline
Reply Speakers
