How to hook up Logitech Z-2300 speakers to TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2012, 06:27 PM - Thread Starter
newby89's Avatar
I have searched the forum, but there were no up to date threads on this subject. I want to connect my Logitech Z-2300 speakers to my TV (Via a simple analog out)
I have lost the Y adapter that came with my speakers, what do I need to have in order for this to work?
Will these work? Is there anything else I would need?
http://www.jr.com/hosa/pe/HOS_CFR210...q*0UvqWXYOS7aQ
http://www.*******.com/255-036.html
Would this set-up work to get sound out of my blu-ray player as well, or would I need to unplug them from the tv and back into the Blu-ray player with a simialr Y cable?
newby89 is offline
post #2 of 4 Old 01-03-2012, 07:21 PM - Thread Starter
newby89's Avatar
bump
newby89 is offline
post #3 of 4 Old 01-10-2012, 10:05 AM - Thread Starter
newby89's Avatar
Is this the right cord?
newby89 is offline
post #4 of 4 Old 01-10-2012, 10:39 AM
Hamilcar Barca's Avatar
I bought a pair of powered speakers (Audioengine A5) which came with a Y-
adapter. I've never used it. I use one I bought from Amazon. They work
absolutely identically.
Either of those, or anything equivalent, is all you should need.
If you connect external speakers to your TV, the audio from its tuner and
attached devices, like blu-ray players, will go through them.
Hamilcar Barca is offline
Reply Speakers
