AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   5.1 setup: Center of the same type but smaller size (http://www.avsforum.com/forum/89-speakers/1384576-5-1-setup-center-same-type-but-smaller-size.html)
Vintageologist 01-03-2012 11:06 AM
Hello,
I'm planning on upgrading my front speakers and need to decide whether to buy 5 of the same (including front widths) or 4 slightly larger with a smaller center of the same type. (The larger one unfortunately doesn't fit my rack for the center). We're talking same brand, same line of speakers.
Both types have the same tweeter but the larger would have a volume of 18,6l and a 180mm low frequency driver, whereas the smaller would have 11,2l and 150mm respectively. The smaller one would also have a crossover at a 100Hz higher frequency.
I'd somehow like to get the larger ones... would that be a problem with that center? Power and low-frequency handling for both would be above (or below in the case of low-frequency handling - I'd pass it on to the sub @80Hz) what I need.
Thanks in advance!
punman 01-03-2012 06:16 PM
I have iQ KEF speakers. iQ5s for the front, iQ1s for surround and an iQ2 for the centre. Works great! iQ1s are too small for the front and tower iQ5s would not work for the centre. It is not only okay - it may be preferable to have different sizes. My sub takes all the <80 signals.
Vintageologist 01-04-2012 07:01 AM
Why do you think that? The general chorus usually advises to have all the front speakers of the same exact type.
rdclark 01-04-2012 07:50 AM
I think this could be problematic under a couple of conditions.
If you play movies big and loud, the center could be taking most of the load. Sonically, it could limit the dynamic range of the entire system.
It could also be a problem if your system doesn't allow you to set the crossover separately for the center. If you have to use that 100Hz xover for everything, you've changed the sound of your system in a way you can't really compensate for. It might not matter, but if it does you're powerless.
Sometimes a phantom center is a better solution than an inadequate center.
punman 01-04-2012 08:42 AM
I had not heard that.
My fronts and my centre of of the same brand and same speaker series but are of different model numbers, The centre was designed as a centre, not as a front.
I am not saying you are wrong, only that I had never heard that all speakers should be identical, only that they should be the same brand and same line so they have the same characteristics.
I am calibrated with Audyssey and can set each speaker's crossover. My KEF subwooer gets all the low signals.
flickhtguru 01-04-2012 08:51 AM
Ideally your front 3 speakers should be completely identical and oriented vertically. All the woofers/mids and tweeters should be the same size and at the same height.
Most ppl don't have the room for that type of situation so that's why the horizontal center was created. If you can do 3 identical fronts do that! If not buy the center to match the Front L&R speakers and make sure the center has the same size drivers in it.
For me when researching for my near future system, any speaker company or model line that had a center with smaller woofer/mids than the Front L&R were ruled out immediately. I also wanted to have a minimum of a 2 - 6" woofers in each speaker and wanted a freq resp of down to 60hz +/-3db or lower so they can be crossed over at 80hz without being driven to their limit.
Vintageologist 01-04-2012 09:01 AM
Is it like that? I once heard the center basically doesn't handle much more than the vocals really. I think I need to set my l&r to minus whateveristhehighestvalue dB in order to find out.
Ah sorry, I think I didn't formulate that clear enough! I was talking about the crossover frequency from the tweeter to the mid-low-frequency driver of the speakers themselves, which is at a frequency 100Hz higher for the smaller one (i.e. 2600Hz vs. 2700Hz). They both go way deeper than required. 41Hz for the "smaller" one.
It that opinion based on theory or have you already had centers with slightly smaller woofers with less-than-favorable outcome?
cel4145 01-04-2012 10:17 AM
Some centers are better designed to match the L/R speakers than others. Rather than keeping the speakers you are interested in a mystery, you might benefit from getting feedback on THE particular center you are considering.
Vintageologist 01-04-2012 10:52 AM
Oh... that would be Elac BS243 and BS244 "Black Edition". So I'm either considering going all 243 or going 243 for the center and 244 for the rest.
cel4145 01-04-2012 11:51 AM
What about the Elac CC241 with the 244s? Will it fit in your rack? Then you have more drivers pushing sound to match up with larger driver of the 244.
Gertjan 01-04-2012 12:10 PM
It has often been said that the center channel is the most important speaker. It carries most of the dialog and a large amount of the regular sound. (An easy way to demonstrate this for yourself is to play a movie and just disconnect your center speaker without telling your AVR you just did that. Depending on the movie of course, you'll probably be amazed at how relatively little sound comes from the L & R speakers.)
My personal experience is that having 3 identical speakers is better than non-matching speakers; Sound that pans from side to side through the center is unlikely to sound the same along the way if your center has a different set of drivers than your L & R mains. If the "small" versions of the speakers are rated to down well below 80Hz, i would consider just doing all "small" speakers; what's the point of going with the bigger speakers if your sub is going to handle the stuff <80Hz anyway?
Vintageologist 01-04-2012 02:28 PM
No the CC241 unfortunately is way too wide. The BS243 really is the only one that would fit in. The BS 244 is just a tad (about 3cm) too high. The thing that really creeps me out is that I've been considering another rack but there's none that would offer enough height for the 244 (at least over here). I'd have to actually build one myself...
You're probably right about the matching speakers.
I'd think larger speakers not only go down deeper but also handle deeper frequencies within their spectrum with more "ease".
cel4145 01-04-2012 05:32 PM
What about a new rack for the CC241? That shouldn't be nearly as hard to fit as getting one tall enough for the BS 244.
Florida_Gator 01-04-2012 05:37 PM
I started with a center with dual 5.25" drivers, and ended up upgrading it to one with dual 6.5" drivers (which is what my L and R mains have). Much better.
If anything, go BIGGER than the rest on the center, not smaller.
flickhtguru 01-05-2012 06:09 AM
I have had experience with centers will smaller woofers than the Front L&R and didn't like it, granted they were Onkyo HTIB speakers.
Also take Klipsch Synergy and Icon Series speakers: they offer towers with dual 6.5" woofers and also dual 8" woofers and the centers for those systems have either dual 4" woofers or dual 5.25" woofers. I hate the way it sounds panning across the front with dual 8" towers and dual 5.25" centers. The crossovers are obviously different and doesn't sound seemless like it should.
Vintageologist 01-05-2012 09:00 AM
Probably... but if I'm honest, I'd prefer upright speakers.
I see, well that does sound valid.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
