Omd-15's or RC70's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 54 Old 01-06-2012, 05:17 PM - Thread Starter
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Both are $1000 for the pair right now. The listening area is pretty tight so the speakers will be close to the wall. The uses wood be mainly tv and movies with music being 20% of the listening. The center and rears would be the matches to the towers. Also I have hard wood floors if that makes a difference. Oh almost forgot as of now I will be using a pioneer sc-05 to power them.
CaTaSTrOphiK is offline
post #2 of 54 Old 01-06-2012, 05:23 PM
pjb16's Avatar
You can pick up a pair of clearance models from Vanns of the OMD-15s (that were returned for one reason or another) for as low as $700. And they will still have the full warranty.
I have never heard the RC-70s, but I have 4 OMD-15s and I think they're great.
Also, even though the OMD-C1 matches the OMD-15 (supposedly), I use a C2 as my center.
I know you say they will be close to a wall, and why the OMD-15s (and 28s) are supposed to be off the wall some, they may still sound great to you with your placement.
PSN - Mr_Frisch
XBL - Mr Frisch
Steam - Sneaky Pete
pjb16 is offline
post #3 of 54 Old 01-06-2012, 05:25 PM - Thread Starter
Quoted: 14 Post(s)
Thanks for the quick reply did you try the c1 as well or went straight to the c2?
post #4 of 54 Old 01-06-2012, 08:03 PM - Thread Starter
Quoted: 14 Post(s)
Anyone else?
post #5 of 54 Old 01-06-2012, 09:16 PM
pjb16's Avatar
I went straight to the C2 as I bought a C2, 2x 15s, and 2 Rs together used from a local guy who went from house to apt.
PSN - Mr_Frisch
XBL - Mr Frisch
Steam - Sneaky Pete
pjb16 is offline
post #6 of 54 Old 01-06-2012, 09:29 PM - Thread Starter
Quoted: 14 Post(s)
And I see that you like/love them. Any downfalls you can point out from your experience? I am surprised at the lack of response on the energy's people talk about them alot on here. Maybe I'll have to order them both and give them a shot. Going to have to check vann's return policy.
post #7 of 54 Old 01-06-2012, 09:53 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
I am unclear on what you own already if anything. If you own Mirage and want to expand on that then I would recommend that, but if you are looking to start new I would recommend Energy. Especially the RC series, but you have to consider that they are a discontinued series and may only be available for a short time at Vanns so you may want to purchase as a bundle now. Mirage and Energy are sister companies, but a little more info is needed before anyone can help you. You may also want to ask in the Energy thread about what you are looking for http://www.avsforum.com/avs-vb/showt...0450&page=1194
Life is hard, be harder.
Saints is offline
post #8 of 54 Old 01-06-2012, 09:54 PM
pjb16's Avatar
Only downfall I could speak of is that new speakers take time to "break in" supposedly, so you'll have to have them playing something for like 100hrs before they get their true sound.
PSN - Mr_Frisch
XBL - Mr Frisch
Steam - Sneaky Pete
pjb16 is offline
post #9 of 54 Old 01-06-2012, 10:45 PM - Thread Starter
Quoted: 14 Post(s)
I have a set of klipsch quintet sl's currently am looking for an all around upgrade.
post #10 of 54 Old 01-07-2012, 06:34 AM
Bluvette's Avatar
Quoted: 166 Post(s)
Liked: 159
Either choice will be good, they are just different. The Energy's will be direct and the Mirage have the Omnipolar design (non directional room filling). I own the 15's for my fronts, C1 for my center and (4) OMD-5 for surrounds. The placement is a bit fussy but when done sounds great. The C-1 is a great center, very clear. Remember when using the C-1 if mounting above the screen mount upside down. If you are planning to use the 5's for surrounds if those will be wall mounted 6 feet or higher also must be mounted upside down. Hope this helps, I love my 15, C-1, and 5 setup, great speakers. Good luck.
Bluvette is online now
post #11 of 54 Old 01-07-2012, 09:10 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
You should definitely read in the Energy owners thread. There are constant testimonials about the high quality of the RC-70s for the price.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #12 of 54 Old 01-07-2012, 09:43 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
Spending $1000 on either of those speakers WOULD be catastrophic...lol.
I can give you a long list of better-sounding speakers in that price range; I hardly know where to start!
I guess my #1 choice would be the Monitor Audio Bronze BX-6 for $1000/pair.
Comparing the Bronze BX-6 to those speakers would be something like the comparison between a Porsche and a Ford Fiesta. They are SO much better there IS hardly any comparison!
The second choice for $1000 would be the PSB Image T5 speakers; again, a much better-sounding speaker in every way.
The third choice would be the PSB Alpha T1 for $700/pair; still a better-sounding speaker (not as much LF extension on this one, but that is a non-issue if using a subwoofer).
ANY tower speaker you can find On the Audio Advisor speaker website for over $500/pair will sound a lot better than that crummy Mirage, and the Energy isn't much better!
Those speakers you named at the start are speakers that would give any serious listener a serious laugh, at their ridiculous prices. The Mirage has a terrible harsh tweeter and the Energy is just a 2nd-rate speaker in every way.
BTW; if you have hardwood floors and don't want the sound to be completely ruined by floor reflections, get a couple of 4' square or larger rugs and put them a foot or two in front of the speakers.
commsysman is offline
post #13 of 54 Old 01-07-2012, 09:59 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The reason they were returned was that the owner couldn't stand their crappy tweeter for more than a few days.
I'm sure they have LOTS of returned ones to dump, if they can find enough suckers.
t.
post #14 of 54 Old 01-07-2012, 10:33 AM
cel4145's Avatar
Liked: 2991
Originally Posted by commsysman View Post
Those would be owners, who have presumably never heard all of the better speakers available for the same price, wearing out their arms patting themselves on the back...lol. What a joke. I love these threads where people who all own the same crap gather around and do a circle jerk to congratulate each other on their junk. Anyone have a barf bag handy?
Anyone who spends more than $300/pair on ANY Energy speaker has wasted his money. There are so many competitive better speakers available that there is no excuse for that except ignorance of what is available.
Hmmm...there are some pretty knowledgeable people that regularly post in that Energy owners thread. Of course, you'd have to have followed it awhile to know that. Personally, I'm getting very tired of the assumptions and generalizations that characterize your posts that are based on very limited--or no--information.
cel4145 is offline
post #15 of 54 Old 01-07-2012, 10:50 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
"some pretty knowledgeable people"...is that an assumption or a generalization or both??? Sounds like BOTH!
"very limited or no information"...is that an assumption or a generalization or both??? Sounds like BOTH!
Anyone who thinks that ANY Energy speaker is worth $1000 is definitely operating in a zone where there is very limited or no information ( ...the Energy owners thread would certainly qualify...lol).
Ask the people at Audio Advisor who DUMPED Energy as a product line because they had so many returns from unhappy customers that they had to conclude, correctly, that they were crap!
Go LISTEN to pair of Monitor Audio Bronze BX6 speakers, and THEN tell me how good some Energy speaker is. The problem is that I KNOW because I HAVE heard them both and you obviously haven't! Until YOU get more information, don't attack those who are more knowledgeable than you are.
post #16 of 54 Old 01-07-2012, 11:10 AM - Thread Starter
Quoted: 14 Post(s)
Sorry double post from phone.
post #17 of 54 Old 01-07-2012, 11:11 AM - Thread Starter
Quoted: 14 Post(s)
Ok with this I am just lost do others back this up I guess time to do more research I wish there was actually somewhere I could here all this stuff I don't have all day everyday to do research I want to be able to sit and enjoy. I have read the energy owners forum along with a fair amount of the mirage forum.
Bronze is new to me. Thanks for the advice although I think you could handle yourself a little more respectfully you sounded pretty rash in your response ok you dislike the speakers I came across. Do you have any more logical explanations? And thank you for the rug suggestion I will take that into account.
post #18 of 54 Old 01-07-2012, 11:30 AM
cel4145's Avatar
Liked: 2991
Go LISTEN to pair of Monitor Audio Bronze B6 speakers, and THEN tell me how good some Energy speaker is. The problem is that I KNOW because I HAVE heard them both and you obviously haven't! Until YOU get more information, don't attack those who are more knowledgeable than you are.
If you have listened to the Monitor Audio towers in comparison to the RC-70s and like the MAs better, good for you. If Audio Advisor had trouble selling the RC-70s, I'm not surprised since they tend to charge full retail. Most Energy owners would agree that the RC series is not a good value at full price.
Nevertheless, if you reread this thread, I didn't make any claims about the RC-70s being better than the OMD-15s, or better than the Monitor Audios. Nor is this thread about the Monitor Audios (see the OP's original post). The OP is interested in information on the RC-70s and OMD-15s; the Energy owners thread is a good place to learn about that, despite your generalization that all owners threads are useless.
Not surprising, though. You seem to have an agenda of promoting Audio Advisor's products, and you have repeatedly demonstrated a willingness to make strong claims based on a lack of knowledge. Most recently, in another thread the last couple of days, you have told the OP to disregard the Denon 1712 for the 1612, even though your knowledge is based on one review, which, btw, I showed to you a couple of weeks ago when you had been talking about how bad Denons were (obviously a poor assumption since you are now championing one). If you did your research, you would know that the 1712 is not a worse choice (go see the evidence in that thread). But you chose to base a rather strong opinion on limited information, and this is not the first time this has happened.
cel4145 is offline
post #19 of 54 Old 01-07-2012, 11:31 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The audio press is not perfect, but in general they pick stuff to review that they are fairly sure that they can say something good about; often because they have heard the stuff somewhere first. They are at least pretty knowledgeable and reasonably objective when they do a review in Stereophile and The Absolute Sound. Home Theater is another good source.
PSB and Monitor Audio have repeatedly had excellent reviews in Stereophile and The Absolute Sound on several models (they obviously can't review every model from every manufacturer). Compare that to the COMPLETE ABSENCE of ANY review of ANY Energy or Mirage speaker in recent years. Duhhhhhh....
I have heard a lot of stuff because I go to audio shows, talk to friends in the audio business and listen as much as I can at various places, and have no reason to promote any brand EXCEPT because it sounds good and performs well. My only agenda is to try and help people find out how to get the most for their money. If that is a crime (some people act like it is...), then arrest me.
There seem to be a lot of refugees from the Energy Owners Thread or the Polk Owners Thread or what ever that lurk here and slavishly defend what they own and attack anyone who suggests otherwise. I hate that crap.
post #20 of 54 Old 01-07-2012, 11:35 AM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
Being able to sit and enjoy is not easy - you will always find pro's and con's.
Choose the speaker from any brand, that attracts you the most - then buy
and test it out in your home, for the 30 day trial period. While Mirage, or
Energy is not my first choice, I do not consider them bad speakers.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #21 of 54 Old 01-07-2012, 11:42 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
I NEVER said ONE WORD about the 1712. I DID NOT tell the OP to disregard it. That is completely untrue. I pointed out the positive attributes of the 1612 and told him where he could see the review that praised it for himself. Is that a crime? It seems that YOU are the one who can't get things correct! GO BACK AND READ MY POST AGAIN, and then knock off the untrue allegations!
I have NO agenda regarding Audio Advisor, except that IMO they are a convenient source for information on Monitor Audio and PSB and some other good products, AND that they have a 30-day free refund policy which I like very much. It's called trying to give people useful information.
As for Energy, and prices; the OP said he was contemplating spending $1000 for the Mirage or Energy, and I was merely trying to point out that IMO the general opinion of knowledgeable people is that there are MANY MANY better choices for that kind of money and PSB and Monitor Audio Bronze are only two of the many.
Not surprising, though. You seem to have an agenda of promoting Audio Advisor's products, and you have repeatedly demonstrated a willingness to make strong claims based on a lack of knowledge. Most recently, in another thread the last couple of days, you have told the OP to disregard the Denon 1712 for the 1612, even though your knowledge is based on one review, which, btw, I showed to you a couple of weeks ago when you had been talking about how bad Denons were (obviously a poor assumption since you are now championing one). If you did your research, you would know that the 1712 is not a worse choice (go see the evidence in that thread). But you chose to base a rather strong opinion on limited information, and this is not the first time this has happened.[/quote]
post #22 of 54 Old 01-07-2012, 11:43 AM
martinlongbow's Avatar
interesting that when you search for Monitor Audio Bronze BX-6, it direcly goes to audio advisor, with all the other links coming from the british monitor websites.
martinlongbow is offline
post #23 of 54 Old 01-07-2012, 11:59 AM
zieglj01's Avatar
Quoted: 941 Post(s)
Liked: 846
You can also look here
http://www.saturdayaudio.com/picture...o_specials.htm
Who AM I
zieglj01 is offline
post #24 of 54 Old 01-07-2012, 11:59 AM
cel4145's Avatar
Liked: 2991
I NEVER said ONE WORD about the 1712. I DID NOT tell him to disregard it. That is completely untrue. I pointed out the positive attributes of the 1612 and told him where he could see the review that praised it for himself. Is that a crime? It seems that YOU are the one who can't get things correct!
You didn't directly mention the 1712, but you definitely told the OP that he should buy the 1612, even though afrogt and the OP were discussing the 1712, too, and then acted like a jerk to afrogt when he asked you a question about the 1612 features. Just like you acted like a jerk towards me and every other Energy owner when you made that comment about the Energy Owners Thread.
I like Audio Advisor, too, since they are about a 10 minute drive from my house (I've been there on several occasions). But I don't just almost exclusively promote them and their speakers.
cel4145 is offline
post #25 of 54 Old 01-07-2012, 12:01 PM
alphaiii's Avatar
Quoted: 43 Post(s)
Liked: 56
Well said...
alphaiii is offline
post #26 of 54 Old 01-07-2012, 12:23 PM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
Thank you for admitting that you LIED about my post on the other thread. I welcome your correction, even though one really should apologize in that situation and you did not. I expressed my opinion about the Energy Owners thread, and it's still my opinion; sorry if it offends you in any way.
Apparently, according to you, expressing an honest opinion constitutes being a jerk, but posting lies about what other people have said is no problem and doesn't even merit an apology.
post #27 of 54 Old 01-07-2012, 12:26 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
I have come to the conclusion that you are out of your mind. While you make people believe that you know what you are talking about by going in depth in your posts I have read numerous posts by you that make me believe you are more of a " if you can't convince them of the truth, dazzle them with ********" type of guy.
Saints is offline
post #28 of 54 Old 01-07-2012, 12:29 PM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
I'm still waiting to hear specifically who all of these people are, and why they are assumed to know so much about anything. I can assemble some respected people in the audio business who would all assume that any Energy owner is de facto not very knowledgeable about speakers.
Originally Posted by alphaiii View Post
Well said...
post #29 of 54 Old 01-07-2012, 12:34 PM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
In that case, I think that as a public service you should send a letter to the state department of Mental Health and carefully document the evidence for your conclusion. Maybe when they get the letter they will come and lock YOU up...lol.
post #30 of 54 Old 01-07-2012, 12:39 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
Thanks for proving me right. That is the most ignorant blanket statement that I think I have read on AVS to date.
Saints is offline
Reply Speakers
