can this avr handle these speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-06-2012, 10:50 PM - Thread Starter
skichiiwa's Avatar
I want to run Definitive Technology UIW RLS III in walls with my onkyo tx-nr609. Is it possible?
specs:
Driver Complement :One 1" pure aluminum dome tweeters; Two 5-1/4" cast-basket bass/midrange drivers pressure coupled to two 5-1/4 bass radiators
Frequency Response :24 Hz - 30 kHz
Impedance :Compatible with 8 Ohm outputs
Sensitivity :92 dB
Recommended Associated Amplifier Power :10 - 325 watts
A/V Receiver Crossover Setting :60 Hz
Inputs :One pair of gold plated spring loaded posts
onkyo 609:
http://www.us.onkyo.com/model.cfm?m=...s=Receiver&p=s
skichiiwa is offline
post #2 of 13 Old 01-06-2012, 11:23 PM
UtahPaul's Avatar
Stereo? 5.1 system? Other? Distance from speaker(s) to main listening position? How loud do you want it in db? Are you crossing over to sub(s)? If so, at what frequency?
UtahPaul is offline
post #3 of 13 Old 01-06-2012, 11:59 PM
cavu's Avatar
Short answer? Yes.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #4 of 13 Old 01-07-2012, 08:23 AM
commsysman's Avatar
Quoted: 977 Post(s)
Liked: 526
The only spec that matters there is the Sensitivity; any amplifier over 20 watts will run speakers with that high 92db/watt sensitivity.
specs:
Sensitivity :92 dB
onkyo 609:
commsysman is offline
post #5 of 13 Old 01-07-2012, 10:54 AM - Thread Starter
skichiiwa's Avatar
Sorry so if I want to run any more then the speakers I will need an amp? Also is it better to buy an amp or more powerful avr?
post #6 of 13 Old 01-07-2012, 11:29 AM
cavu's Avatar
An AVR is much more efficient.
An AVR with 'pre-outs' leaves you the OPTION of using external power-amps.
Based on your questions, I wouldn't worry about external amps unless you're the kind of person who buys a Hummer to cruise the mall.
" - MLK
cavu is offline
post #7 of 13 Old 01-07-2012, 11:48 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Or unless you are planning to set your HT system up in a giant cavern
The Onkyo TX-NR609 has good reviews and has plenty of output for the average HT system. You'd have to spend substantially more money to do better, and you might not notice any difference.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #8 of 13 Old 01-08-2012, 12:12 PM - Thread Starter
skichiiwa's Avatar
interesting points. thank you all but i still don't know if it can handle those speakers plus more. am i reading into this too much?
thank you
post #9 of 13 Old 01-08-2012, 12:47 PM
cavu's Avatar
So I re-read your question but have no idea what you are asking!!
" - MLK
cavu is offline
post #10 of 13 Old 01-08-2012, 02:13 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
The NR609 could handle 7 of those Def Tech speakers if you had them. 92db sensitivity and 8ohms isn't tough to power at all.
Afro GT
afrogt is offline
post #11 of 13 Old 01-08-2012, 04:38 PM
UtahPaul's Avatar
It depends on the OPs desired SPL and listening distance. Without that information all opinions are meaningless. The OP should consult an online power requirement calculator.
UtahPaul is offline
post #12 of 13 Old 01-08-2012, 05:29 PM
cavu's Avatar
OK, let's deal with distance, multiple speakers and reflected power.
I'll make the assumption that the OP wants to generate THX standard levels of 85dB SPL average and 105dB SPL peak. I'll present two scenarios which will likely cover the OP's situation.
A. The listener is in the centre of a room with a 5.1 speaker array placed around the outside of the room, 10ft distant from the listening position.
Let's ignore the sub-woofer for the moment and apply pink noise at 0.2w to all remaining 5 speakers (each with 92dB efficiency), the following calculations could be made:
Each speaker will produce 85dB SPL @ 1m
  • We will lose 9.7dB per speaker due to the distance the listening position (10ft)
  • We will gain 7dB from the multiple (5) speakers
  • We will gain 3dB from reflected sound in the room
  • The sound pressure level at the listening position will be 85.3dB SPL, exceeding the THX average requirement.
Let us do the same but at 20w per speaker:
Each speaker will produce 105dB SPL @ 1m
The math is the same:
  • The sound pressure level at the listening position will be 105.3dB SPL, again exceeding the peak spec.
If the OP was using a 7.1 system, the SPL level in the two above cases would be 1.45dB SPL louder ... 86.75dB and 106.75dB respectively.
B. Sitting 20ft away from the speakers will require more power:
The loss per speaker for the additional 10ft to the listening position would be another 6dB so you would have to have 0.744w/ch to produce 85dB SPL at the listening position with a 5.1 system and 74.4w/ch to produce 105dB SPL.
Using a 7.1 system, the power requirements to meet THX standard levels would be 0.53w/ch and 53.14w/ch respectively.
So, in summary, as I stated in post #3, "Short answer? Yes."
This AVR (with 100-ish w/ch) will handle those speakers (unless the OP is operating outdoors or in a gymnasium) with headroom left over.
" - MLK
cavu is offline
post #13 of 13 Old 01-09-2012, 04:04 PM - Thread Starter
skichiiwa's Avatar
whoa. thanks for the detail . IM no more then 10 feet from the wall they will go into. I'm also in a great room( living and kitchen in 1). so it is big.however, IM probably going to do 3.1 system maybe 5.1 but never 7.1.
thanks for all the detail. Greatly appreciated.
Reply Speakers
