eD c12/SHO-10 or Energy RC-70 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-07-2012, 07:40 PM - Thread Starter
hoffmand34's Avatar
I'm considering upgrading my 10 yr old Energy e:XL-26 towers and e:XL-C center in my 14x19x9 sealed home theater. They still sound good but the smallish center leaves some room for improvement during higher volume movies.
Nothing but great reviews for the RC-70 and RCLCR in the Energy thread and the Vanns pricing is great now. But my reservation is this room is almost 100% used for HT. This led me to the compression driver pro-audio models from ED and CHT. I've never heard either and reviews are hard to come by.
I have a Pioneer Elite SC-35 to drive them and a sub upgrade is the next step (BIC F12 now, rythmik or svs soon).
Any thoughts on which speaker would perform better for HT duties?
hoffmand34 is offline
post #2 of 6 Old 01-07-2012, 08:28 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
There is no doubt that the pro horn speakers will give you that bigger theater sound.
The RC's will most likely be more refined with music and look 100% nicer.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #3 of 6 Old 01-08-2012, 05:51 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Many have stated that the SHO-10's sound just as great for music as they do for HT.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 6 Old 01-08-2012, 07:32 AM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
With a receiver a more sensitive speaker will sound much better as the dynamic peaks won't get clipped or compressed. The eD has more Midbass and is bigger. If you can cross over high to the subs it won't matter.
Marantz 7702 Atmos
MKtheater is online now
post #5 of 6 Old 01-08-2012, 09:59 AM - Thread Starter
hoffmand34's Avatar
Thanks. I plan on crossing the sub(s) at 80hz (to start), are you saying the SHO-10 and eD will be similar? And if I crossover lower, the eD will have an advantage due to the larger woofer?
post #6 of 6 Old 01-08-2012, 06:46 PM
MKtheater's Avatar
Liked: 1122
With an 80hz crossover the eD will have more Midbass. Of course the one I have has much more but I am coming from the upgraded version. The stock 12 might have a slight edge over the 10 in the SHO-10. They both are great.
Marantz 7702 Atmos
Reply Speakers
