B&W 683 + Rotel or B&W CM9 + Denon? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-12-2012, 01:12 PM - Thread Starter
V. Rossi's Avatar
i'm currently running my 683 with a 12 year-old previously top-of-the-line denon avr-5700 receiver with a specced 140 w/ch. i was looking for an incremental upgrade to my STEREO system and was looking for input on the following pairings:
A) set of 683 paired with a rotel rb-1582 200 w/ch class AB amp
or
B) set of better b&w cm9 paired with the existing denon avr-5700
so what do you think would sound better? choice A is a stronger amp making a better overall pairing. choice B is a better pair of speakers (exactly twice the cost of the 683) with an inferior amp. thanks for your input.
V. Rossi is offline
post #2 of 3 Old 01-12-2012, 01:43 PM
jclif77's Avatar
I always say go for the speakers....they will make the biggest audible improvement.
jclif77 is offline
post #3 of 3 Old 01-12-2012, 02:17 PM
KyaDawn's Avatar
I agree, I think the CM9 with the Denon is going to sound better than your existing 683s with the Rotel amp, which may be overkill in any case.
KyaDawn is offline
Reply Speakers
