flush L / R / C speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-12-2012, 05:02 PM - Thread Starter
KeyMastur's Avatar
looking to get rid of my onkyo 6200 HTIB basically. bought 4 SNELL OH-S7 for my ceilng, looking to put something similar around the wall mounted tv.
are these Yamaha's from amazon decent ?
also, would i just buy the 3-pack and use the 3rd as a center speaker, or should the center have different specs ? i'm not sure i can mount that center speaker sideways given the center-position of the tv. it would run across a stud due to it's width, so would need something slimmer width wise
or if anyone can point me in the direction to some decent speakers, within a decent price range, i'd appreciate it
KeyMastur is offline
post #2 of 4 Old 01-26-2012, 09:03 PM
FunHouse Austin's Avatar
you may be under estimating the number of studs that are in the walls around the windows as well. this can be a tricky install. I prefer the Polk OWM series for this kind of install.
If you want to know if a product is "good", please tell us your definition of "bad" for an understood point of reference. Do you want subjective opinions or objective facts?
- FunHouse Media
FunHouse Austin is offline
post #3 of 4 Old 02-02-2012, 09:04 PM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
Look for on-wall LCR speakers, and then they can match, which is more ideal. A horizontal center in not a deal-breaker, though.
Maybe Definitive Technology Mythos?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #4 of 4 Old 02-02-2012, 09:15 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
I would look at NHT on-wall speakers, and the Absolute center
http://www.nhthifi.com/Home-Theater-...&category=7166
http://www.nhthifi.com/Absolute-Cent...&category=3774
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
Reply Speakers
