List of Reference Level, High Sensitivity & SPL Speakers - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #541 of 983 Old 12-11-2012, 01:10 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
did not Toole studied mostly linear distortion?
zheka is offline
post #542 of 983 Old 12-11-2012, 02:09 PM
JerryLove's Avatar
Liked: 82
Toole studied which variables affect subjective experience (psycho acoustics). Three of the more notable finds are that flat FR is preferred, absolute phase doesn't matter, and that off-axis performance is very important.
JerryLove is offline
post #543 of 983 Old 12-11-2012, 02:50 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
check this out
http://www.gedlee.com/downloads/AES06Gedlee_ll.pdf
the study found that audibility of linear distortion is increased with increase in delay AND playback level. It is possible that perceived non-linearity at higher playback levels is an artifact of human hearing rather then actual nonlinear distortion in the system.
The combined effects of playback level and delay have strong implications to the perceived perception of nonlinear distortion. It is not possible to say, without complicated objective tests, if what is being perceived is a nonlinearity in the system or a nonlinearity in the subjective perception as described in this paper. This has profound implications to the subjective evaluation of nonlinear distortion in audio systems most particularly loudspeakers where the delay factor can be quite strong.
Time delayed resonances, nearby cabinet reflections and edge diffraction, waves in horns; all have delay times on the same order as this study. A loudspeaker that is evaluated at 70–80 dB (SPL) may have a very different perception at 90-100 dB even if it is completely linear.
A THD distortion curve will not reveal this effect, nor will a frequency response graph. A careful look at the impulse response might yield the best insight, however this has not been quantified. Methods for measuring the nonlinear effects of our subjective perception are currently under investigation. Another point is that the usefulness of a loudspeaker for audio playback can have a sound power output limit that is independent of its electrical power handling or its nonlinear distortion characteristics. Loudspeaker evaluations that take place at a fixed level, are seriously inadequate at revealing the true quality of these systems.
zheka is offline
post #544 of 983 Old 12-11-2012, 03:58 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
check this out
Very fascinating. I wonder how much of that is going on in our perception of hearing that we attribute to the driver?
JBL Pro Cinema-JTR subwoofers-Sony SXRD projection
MANCHESTER UNITED!!
Reddig is offline
post #545 of 983 Old 12-11-2012, 08:04 PM
MKtheater's Avatar
Quoted: 1759 Post(s)
Liked: 1358
OK guys some real reference level numbers at my LP from 13 feet away and center channel only.
WARNING!!!!!
After running all these tests I ran a 15000 hz sine wave at 105 dBs and my amp started to smoke! This is running constant sine waves and are a brutal test so any movie peak will be lower in THD and much easier on the amp and speakers. Do not attempt above 10khz, especially after all these tests prior. I wanted to make sure I did not blow up my amp channels so I ran my test tones thru every channel and it is still working great. I will do more testing of the amp tomorrow. This is a beast of an amp THX rated 500 watts per channel into 4 ohms and stable to 2 ohms so these tests had to be brutal!
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is offline
post #546 of 983 Old 12-11-2012, 08:58 PM - Thread Starter
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
Wow! So about how many watts should the amp have ben outputting at 105db?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #547 of 983 Old 12-11-2012, 09:13 PM
MKtheater's Avatar
Liked: 1358
I was running sine waves from 10hz on up for a long time. I bet the sensitivity dropped quite a bit at 15Khz and caused the amp to use lots of power or the impedance dropped. Let's put it this way, how well do people hear 15000 hz? Well, it was very loud and I heard it thru my theater to my rack room and all the doors were closed. The THD was also very high so it probably was THD from the piezos that caused the amp to smoke. I will check it tomorrow. Anyways, Jerrylove's loud at 200hz at 5% THD at 1 meter is interesting. I hit 105.2 dBs at 200hz 13 feet away with 0.076% THD. I think it is pretty clean. BTW at 1 meter it would have been 112 dbs with .076% THD at 200hz.
Marantz 7704
2 Outlaw 7140s
post #548 of 983 Old 12-12-2012, 06:30 AM
Bill Fitzmaurice's Avatar
Liked: 5687
Originally Posted by MKtheater View Post
I was running sine waves from 10hz on up for a long time. I bet the sensitivity dropped quite a bit at 15Khz and caused the amp to use lots of power or the impedance dropped..
You can get in trouble real quick doing that with sine waves. You're pushing more or less constant power at every frequency, the equivalent of white noise, and that doesn't reflect what the system will normally see. We test speakers with pink noise, as that is typical of normal content, and the power spectral density of pink noise drops by 3dB with each octave increase. A swept sine at constant voltage is OK as the time duration is so small.
Bill Fitzmaurice is offline
post #549 of 983 Old 12-12-2012, 06:48 AM
MKtheater's Avatar
Liked: 1358
Well, I just learned that the hard way. I did not know something was happening until my room filled with smoke and I shut it down immediately. I was worried that I broke that channel so I ran test tones like I was calibrating and no problems. We will see when I throw some music and movies in. I get my expensive amps fixed for cheap so I am not that worried but I don't want my theater down for the 3 days it will take to get back.
BTW, how do the numbers look? Does it seem I did it right?
Marantz 7704
2 Outlaw 7140s
post #550 of 983 Old 12-12-2012, 08:57 AM
Liked: 5687
They look really good. I've never tested my DR250s at that high a level, lest the neighbors show up at my door with axes and pitchforks. eek.gif
post #551 of 983 Old 12-12-2012, 09:06 AM
MKtheater's Avatar
Liked: 1358
Just another reason I love my concrete bunker. My wife and kids were sleeping when I did these. I was not in the room but an adjacent with the gear.
Marantz 7704
2 Outlaw 7140s
post #552 of 983 Old 12-12-2012, 03:09 PM
JerryLove's Avatar
Liked: 82
How is that possible? You've been ranting about 105db, reference level as though it was a religion. You've been pounding your chest with your massive experience as a builder of pro gear. And you've never actually tested your gear at reference level before?!? (the logic: because of neighbors, implies you've tested nothing at this level)
Worse than a consumer and 105db zealot: you're a builder who hasn't tested his designs?
Um. Wow.
post #553 of 983 Old 12-12-2012, 03:15 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
Nothing like seeing your precious gear start to smoke lol. Cant remeber which amps you are using right now? Great graphs as usual. I love my 21x13 basement HT concrete bunker too.
MANCHESTER UNITED!!
Reddig is offline
post #554 of 983 Old 12-12-2012, 03:16 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
Um. Wow.
Im sure hes tested DR-250s before at that level just not in his home setting like MK.
MANCHESTER UNITED!!
Reddig is offline
post #555 of 983 Old 12-12-2012, 03:43 PM
Liked: 5687
A lot higher than that in live sound usage, hitting 115dB at 50 feet. But I won't subject my neighbors to those levels unless we decide to have a block party.
post #556 of 983 Old 12-12-2012, 04:29 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
Ya I bet so. 115dB at 50 feet is definitly gettin it done!! Lol major block party!
MANCHESTER UNITED!!
Reddig is offline
post #557 of 983 Old 12-12-2012, 05:22 PM
MKtheater's Avatar
Liked: 1358
It was not pretty but I think I stopped it before something melted. The test tones work fine but I have not tested it with program material yet. It is an Ada MPA-500 amp.
Marantz 7704
2 Outlaw 7140s
post #558 of 983 Old 12-12-2012, 06:37 PM
Peter M's Avatar
Quoted: 184 Post(s)
Liked: 215
I just happen to sell 'magic smoke' and can do you a great deal if you'd like some to refill that amp ! wink.gif
Cheers,
Peter M is online now
post #559 of 983 Old 12-12-2012, 07:27 PM
Liked: 5687
It was probably a resistor, they can throw off a lot of smoke before giving up the ghost. You should be able to see it easily if scorched, and swap it out before it dies.
post #560 of 983 Old 12-12-2012, 08:42 PM
JerryLove's Avatar
Liked: 82
So "Reference Level" is not a volume you actually listen in your home at.
That's really confusing given the importance placed on reference level in the posts arguing with me.
post #561 of 983 Old 12-12-2012, 10:16 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
Good deal. Thats right an Ada MPA-500. Helluva amp.
MANCHESTER UNITED!!
Reddig is offline
post #562 of 983 Old 12-12-2012, 11:57 PM
MKtheater's Avatar
Liked: 1358
Yes it is, I always want to try new amps and I always come back to this beast. There are many amps with more power but not power reserves. I have been looking at the new emotiva XPR amp which boasts more power and 180k of microfarads of capacitance but my amp has slightly less power and much more reserve power, 500k microfarads of capacitance. That means it has lots of stored power for sustained material.
Marantz 7704
2 Outlaw 7140s
post #563 of 983 Old 12-13-2012, 10:15 AM - Thread Starter
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
What I got out of this thread: http://www.avsforum.com/t/1388399/how-many-watts-available-for-short-peak-db/0_50 and in reading an AES paper about the duration of music peaks is that some amps will provide double the RMS power for a period of time, and a lot of the time that period might be long enough, but if it was a sustained peak for like 1000ms then the amp would be clipping. Buying enough RMS power gives more assurance you can always handle the peaks. Depending on the application, that's not always feasible though, I imagine.
Eyleron is offline
post #564 of 983 Old 12-13-2012, 11:46 AM
MKtheater's Avatar
Liked: 1358
We are talking 600 watts vs 500 watts into 4 ohms. The Ada will provide 700 watts for 2 ohms as well and the emo is not stable at 2 ohms.
Marantz 7704
2 Outlaw 7140s
post #565 of 983 Old 12-13-2012, 12:33 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
Yes that stored power really seams to benifit dynamics. Think id rather go less power with more reserve potential than vice versa. Ive been eyeing the new Emotiva XPRs as well. Good specs. I have the Emotiva XPA-3 running my LCR SHO-10s and I really like the combo.
MANCHESTER UNITED!!
Reddig is offline
post #566 of 983 Old 12-13-2012, 12:37 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
I get your point about ample RMS power for sure. You can tell alot from an amp by how much more power it can put at at lower ohms. If one amp is say 200x2 at 8 ohms than 300x2 and 4 ohms, than another amp is 200x2 at 8 ohms than 400x2 at 4ohms, the second amp should have more reserve power. Would I be correct?
MANCHESTER UNITED!!
Reddig is offline
post #567 of 983 Old 12-13-2012, 01:03 PM
JerryLove's Avatar
Liked: 82
The Krell KSA-150 impressed me.
150@8 ohm, 300@4ohm, 600@2ohm, 1200@1ohm.
Only time I've ever seen that linearity... though I believe they did that by under-selling 8ohm power.
post #568 of 983 Old 12-13-2012, 01:45 PM
MKtheater's Avatar
Liked: 1358
Was that actually ever measured?
Marantz 7704
2 Outlaw 7140s
post #569 of 983 Old 12-13-2012, 01:56 PM
Reddig's Avatar
Quoted: 254 Post(s)
Liked: 521
I wonder that too. If so great linearity for sure.
MANCHESTER UNITED!!
Reddig is offline
post #570 of 983 Old 12-13-2012, 02:21 PM
Liked: 5687
Most amps have great linearity at small signal levels. It's a different story at full power, where power rail sag usually will result in halving of the load impedance giving only a roughly 1.7x increase in power. But if the amp is rated conservatively, at levels below where power rail sag occurs, it can be just as linear at rated power as at small signal levels. Most manufacturers don't rate their amps conservatively, of course. IMO watt wars are the only reason for nearly everyone jumping on board the series bridging bandwagon, even though it has limited usefulness.
Reply Speakers
