List of Reference Level, High Sensitivity & SPL Speakers - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
Old 01-21-2014, 09:55 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Originally Posted by Emetw View Post
Good timing, I just ordered my MiniDSP Umik yesterday. By ear I don't sense any combing issues; these are by far the best speakers I have ever heard and they impress me every time I listen to them. Once the Umik arrives I'll get some response graphs posted to show everyone what they look like. Thanks!
So funny i just ordered the exact same mic myself yesterday!
Blazar!
blazar is offline
Old 01-21-2014, 09:56 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
What did those speakers run you? Im curious of those as an option for surround speakers in-wall custom made.
Blazar!
blazar is offline
Old 01-26-2014, 09:34 AM
Emetw's Avatar
Liked: 37
The line arrays? I'd reach out to Al at RAW, I bought them directly from Bob at CSS and now that they use the RT2 ribbon (less expensive but still based on a high-end Aurum Cantus ribbon) and a newer mid, pricing is quite different. PM me for his contact info if you want, he's a super nice guy with amazing build skills.
Anthem MRX-500 - Vincent SAV-P200 - RAW Acoustics Lambda Plus arrays, Apex C II center - HT4 tower surrounds - CSS WR.30 sides - Rythmik FV15HP - Vizio XVT553SV - Xbox One - Xbox 360 - WD Live TV - QNAP TS212 NAS w/WD Red drives - APC H15BLK
Emetw is offline
Old 01-26-2014, 11:57 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
Hey Eyleron. Was wondering if you could add a speaker to the list to see how it stacks up? Its the Electro-Voice TS940D. One of my local theaters has them as stage speakers in two of there rooms and Ive been so impressed with them over the years watching countless movies on them. Its always a treat when I hear them. Here is some specs.
Specifications
Usable Frequency Response
30-20,000 Hz
Sound Pressure Level at 1 Meter,
1 Watt Input:
100 dB
Power Capacity Per EIA Standard
RS-426A,
Long-Term Average:
300 watts
Short-Term Peak:
1,200 watts
Crossover Frequency:
500 Hz
Recommended Crossover Frequency
(see Crossover and Basic Equalization
section):
1,150 Hz
Crossover Slopes,
Recommended:
24 dB per octave
Minimum:
12 dB per octave
Sound Pressure Level at 1 Meter, 1 Watt
Input,
LF (100- to 800-Hz average):
96 dB
LF (65- to 125-Hz average):
94 dB
HF (800- to 5,000-Hz average):
110 dB
Power Capacity Average Power-Handling
Capacity,
Low Frequency (per EIA RS-426-A
1980):
600 watts
Low Frequency, Continuous
Program:***
1,000 watts
High Frequency (per AES2-1984/
ANSI S4.26-1984):
60 watts
Dispersion, Horizontal and Vertical:
90°
Nominal Impedance, HF and LF:
8 ohms
Components:
DH2As1 compression driver; HP99T horn;
TL15-1XS low-frequency system with
EVX-150A woofer; HMK-4 horn/drivermounting
bracket
Finishes:
Matte black HF horn, black driver and
mounting bracket, and black textured
Heres its spreadsheet link: http://www.rsem.com/pdf_manuals/electro-voice/ts940d.pdf
Heres a link where you can see a pic of them: http://www.rsem.com/equipment-details.asp?partnum=TS940D
These guys have always blew me away with there incredible midrange and dynamics. 2-channel preshow music is played thru them before the previews start and they always image so well. I had read an article by Tom Holman who use to judge cinema setups with stereo content to test imaging. Also from reading the specs Im a little confused on the crossover point from the CD to the low frequency drivers. Says 500hz but reccomends 1,150hz.
Thanks alot!
JBL Pro Cinema/PSA subs/Crown power/Sony SXRD projection/Elite screen/Seatcraft Granadas
MANCHESTER UNITED!!
Reddig is offline
Old 03-11-2014, 07:24 PM
dustwvl's Avatar
so how would the HSU HB1-MK2 compare in sensitivity to the Klipsch RF-62II. Does the HSU really have a sensitivity of 92 in the same way most speakers rate sensitivity? I am trying to decide between a Klipsch setup and the HSU. I currently have some ascend acoustics CMT-340 that show a 89db sensitivity anechoic that I m told is the same as the HSU because of them being meausred in half space which would drop the real sensitivity by 3db.
dustwvl is offline
Old 03-11-2014, 08:07 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Klipsch has been known to over-rate their sensitivity badly. There is no way the RF-62 is 97 dB like they claim. 97 dB is more like pro-audio speakers. Klipsch are more sensitive than normal, but the only honest specs for their speakers are on the Heritage line and pro lines. No doubt the RF-62s are more powerful than the Hsu speakers though, but at least Hsu spec their speakers correctly. A lot of speaker manufacturers will spec their sensitivity to an 'in-room' rating without mentioning that fact, like 1/2 space, 1/4 space, or even 1/8 space. Hsu at least tells you how their speaker was rated.
shadyJ is offline
Old 04-11-2014, 10:20 PM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
Anyone use SLS Speakers? http://www.slsloudspeakers.com/SLS%20Audio%20Products.htm
Looks like stage, studio, cinema, home.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
Old 05-29-2014, 07:28 PM
oOOBillO0o's Avatar
First, great effort on this thread. The challenge is that all of this data is flawed in one way or another. Second, its extremely challenging to model speaker behaviors on a spreadsheet.
There are speakers on this list that really exceed THX's and the SMPTE Standards, but if you are single factor weighting for high output, you will be disappointed.
I cannot say this enough, "Trust your ears."
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
Old 05-29-2014, 07:56 PM
Bill Fitzmaurice's Avatar
Liked: 4838
Professional loudspeaker designers trust their ears, but they're just as emphatic as Mr.Reagan was in that they also verify, with measurements. Measuring tools have at least a hundred times the accuracy and resolution that the human ear does. The problem with manufacturer supplied specs is that very few show the single most important piece of data, a measured SPL response chart. In the absence of measured SPL charts manufacturer data should be considered unsubstantiated advertising copy.
Bill Fitzmaurice is online now
Old 05-29-2014, 08:06 PM
oOOBillO0o's Avatar
Bill, Yes! Trust, but verify!
Old 07-18-2014, 08:22 AM
frankie2075's Avatar
Quoted: 453 Post(s)
Liked: 108
Can i add pro audio technology speakers? Anyone experience with these?
frankie2075 is offline
Old 10-06-2014, 12:32 AM
garygarrison's Avatar
Quoted: 515 Post(s)
Liked: 550
Smile
Does such a chart show the SPL across the advertized frequency bandwidth? Which manufacturers provide that?
I don't know enough about it to know what would be helpful, but how about various kinds of distortion (Harmonic & Frequency modulation & ______) at a certain specified SPL, like 100 dB @ 1 meter?
Isn't that a CIA slogan?
garygarrison is offline
Old 10-06-2014, 12:02 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
Pro Audio Tech should indeed be on the list.
MANCHESTER UNITED!!
Reddig is offline
Old 10-06-2014, 12:03 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
Seems this thread has gone cold in the last few months. I really enjoy this thread.
MANCHESTER UNITED!!
Reddig is offline
Old 10-06-2014, 03:58 PM
Quoted: 22 Post(s)
Liked: 3
I'm here! I just requested an RMA for my 3 cbm 170se. They just could not keep up with my listening levels for movies. Looking for a trio of less expensive speakers to take their place that can handle the 120-140 watts of my receiver. Looking at klipsch rb61 II but concerned they may be too bright.
Receiver: Yamaha RX-A2030
LCR: Klipsch RB-81 II C: Klipsch RC-62 II
SS: Klipsch icon KB-15 RS: Bic Acoustech PL-66 2 Polk OWM-3
LFE: 2 PSA XV-15
Source: PC, Directv AC: Furman M8-Dx Display: Viewsonic PJD7820HD, Silver Ticket HDTV 16:9 120" Fixed Frame Projector Screen
jas wats is offline
Old 10-06-2014, 06:59 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
Cool man. You sound like you need a speaker that has a compression driver unlike the Klipsch you mentioned that just had a horn loaded soft dome tweeter.
Look into the JBL PRO Cinema 3677's. Super high sensitivity your AVR can power no problem. They are around $500 a piece if you call Full Spectrum.com and get a price quote over the phone. The JBL Pros are always listed at manuf. suggested price.
They will do reference level without a sweat.
MANCHESTER UNITED!!
Reddig is offline
Old 10-06-2014, 07:01 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
The downside is they are ugly as they are really made to be put behind an AT screen.
MANCHESTER UNITED!!
Reddig is offline
Old 10-06-2014, 08:04 PM
Quoted: 22 Post(s)
Liked: 3
Thanks Reddig, but the Klipsch are already on the way. I can get them, try them out and return them if need be by this time next week!(up to 30 days) I love Amazon! We will see how it goes!
Reddig likes this.
LFE: 2 PSA XV-15
jas wats is offline
Old 10-06-2014, 08:16 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
Right on man cool. Don't let my opinion sway yours as the those Klipsch aren't a bad speaker. Good luck man!
MANCHESTER UNITED!!
Reddig is offline
Old 10-07-2014, 08:58 PM
Quoted: 22 Post(s)
Liked: 3
An update: While my RC-62 hasn't gotten here yet, I did find a local store with 2 RB-81 II. Pretty smoking deal, I think. $720 out the door. I am using one as a center now and already, WOW. If the RC62 is at least that good I am going to be very happy! It's so much more open and explosive. I guess I should have just gotten what I wanted first instead of trying to go cheap.
LFE: 2 PSA XV-15
jas wats is offline
Old 10-09-2014, 02:16 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
How do the JBL LSR6332s compare to the 3677s? I'm looking at moving away from some Paradigm speakers in my dedicated home theater (seem a bit harsh at close to reference) and have always been intrigued by the LSR633s. I can also place the 6332s behind my screen (can not for the Paradigm L & R) and move them a bit further back from listening position.
barhoram is offline
Old 10-09-2014, 06:55 PM
Reddig's Avatar
Quoted: 168 Post(s)
Liked: 309
I havnt personally heard the LSR's but they are a 3-way studio monitor where as the 3677 is a 2-way speaker with a compression driver, used in small cinemas. Your gunna get a bigger more dynamic sound with the 3677s while the LSR's will
prolly sound more refined at lower volumes. If you listen at reference and wanna save money the 3677s are they way to go. They lose in the looks department tho. The LRS I bet sound great with music.
MANCHESTER UNITED!!
Reddig is offline
Old 10-10-2014, 12:42 PM
popalock's Avatar
Quoted: 1236 Post(s)
Liked: 1723
@Eyleron
Jericho J3.
popalock is offline
Old 10-13-2014, 12:57 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
The new CX line of speakers from Reaction Audio would certainly qualify as speakers that would be added to the list of reference high sensitivity & SPL speakers.
http://reaction-audio.myshopify.com/...tions/speakers
jbrown15 is offline
Old 10-13-2014, 02:25 PM
mastermaybe's Avatar
Quoted: 378 Post(s)
Liked: 315
Should the new JBL EON 600 series be added to the list?
They can all easily reach reference at 12 feet.
http://www.jblpro.com/www/products/p...s#.VDw00_ldVZE
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
Old 10-26-2014, 09:25 AM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
JBL 5732 sensitivity corrected for lower LF
Originally Posted by psgcdn View Post
It is now sitting at the top of your list, but hold on... 115 dB is the sensitivity of the HF section. The bass bin is the limiting factor at 103 sensitivity with an input rating of 1200 W. That will drop it down in the list.
I'm back after a hiatus. Good point about the low frequency unit's lower sensitivity: http://www.jblpro.com/ProductAttachm...BL_5732.v6.pdf
Corrected.
Old 10-26-2014, 10:01 AM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
Originally Posted by Nyal Mellor View Post
Hey Eyleron what is the explanation for the mismatch between your calculated amp power figures and those on the calculator you refer to on pg 1?
Sorry for the super long delay. I took a hiatus from home theater to deal with family health issues.
I'm trying to get caught up now while I renovate basement theater at the same time.
New Column: In-Room Sensitivity
The mismatch: A couple pages ago there was discussion with Wayne Parham about measuring sensitivity. Around that time I decided to add another column for sensitivity, so now I show groundplane and in-room. The latter is 3dB higher.
Where the manufacturer is suspected to use groundplane, which is/should be a standard, I'll use their published sensitivity in the groundplane column, and the in-room column will raise it 3dB.
Calculated Output
The next change was with which sensitivity is used to calculate dB SPL 12 feet away. Previously it used groundplane. But because I wanted to make the numbers more relateable for the average enthusiest and be closer to what they'd get in their own room, I decided to switch to in-room sensitivity.
Old 10-26-2014, 10:10 AM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
Klipschorn: corrected per a review
Originally Posted by garygarrison View Post
RE: footnote # 13: I believe that the 105 dB efficiency of a Klipschorn is in the special built-in trihedral wooden corner in Klipsch's anechoic chamber, which, of course, is anechoic except for the corner. The corner is considered part of the Klipschorn's design.
Others (e.g., a French magazine) have obtained a figure of about 98 dB when there was no corner. That may have been out in the middle of a room, or in an anechoic chamber (unspecified). I think the highly respected Heyser of Audio magazine also got 98, but then wrote that 1 watt probably would produce 104 (or 105) in a room corner -- an educated guess on his part?
I corrected with a note that the speaker is intended to be used in a room corner where one will get more efficiency in bass.
Old 10-26-2014, 10:31 AM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
Added Electro-Voice TS940D
Added!
Reddig likes this.
Old 10-26-2014, 10:54 AM - Thread Starter
Eyleron's Avatar
Quoted: 258 Post(s)
Liked: 150
Consolidated and sorted marketing data focusing on high output speakers
Thanks. And yup, it's a big challenge. Consider this more of a, "Consolidated and sorted marketing data focusing on high output speakers."
Completely different than, say, data-bass.com with its measured data on subwoofer performance.
As always, a prospective consumer should look up trusted reviews, get input from real owners, and try to audition the speakers, in theirs or someone's equivalent space, if possible.
The utility of this spreadsheet is in presenting the marketing data, adjusted where possible, such that their spaces are being compared to eachother. And you can discount speakers that even the lying bastards in the marketing department don't claim good output.
For instance, if Paradigm's Series 7 Center 3 was advertised as only having 90dB anechoic sensitivity, and 93dB in-room, and able to handle 175w program, we can figure...
  • 100w from a typical receiver would only get you 102dB
  • That 100w is about 2/3rd of its own program watts rating
  • The 212w it'd take to reach 105dB from 12ft is above what its published rating will allow. You're right, that's probably thermal. It's much worse in terms of distortion.
  • The higher SPLs, if they can even be generated, are probably full of distortion.
So this is not a high output speaker, as pitched by their marketing department. If you want to listen at -5 or have a large space, this is not the speaker for you.
