List of Reference Level, High Sensitivity & SPL Speakers - Page 29 - AVS Forum
 10Likes
post #841 of 868 Old 10-26-2014, 09:10 AM - Thread Starter
Eyleron's Avatar
Liked: 38
Klipschorn: corrected per a review
Originally Posted by garygarrison View Post
RE: footnote # 13: I believe that the 105 dB efficiency of a Klipschorn is in the special built-in trihedral wooden corner in Klipsch's anechoic chamber, which, of course, is anechoic except for the corner. The corner is considered part of the Klipschorn's design.
Others (e.g., a French magazine) have obtained a figure of about 98 dB when there was no corner. That may have been out in the middle of a room, or in an anechoic chamber (unspecified). I think the highly respected Heyser of Audio magazine also got 98, but then wrote that 1 watt probably would produce 104 (or 105) in a room corner -- an educated guess on his part?
I corrected with a note that the speaker is intended to be used in a room corner where one will get more efficiency in bass.
Eyleron is online now
post #842 of 868 Old 10-26-2014, 09:31 AM - Thread Starter
Eyleron's Avatar
Liked: 38
Added Electro-Voice TS940D
Originally Posted by Reddig View Post
Hey Eyleron. Was wondering if you could add a speaker to the list to see how it stacks up? Its the Electro-Voice TS940D. One of my local theaters has them as stage speakers in two of there rooms and Ive been so impressed with them over the years watching countless movies on them.
Added!
Reddig likes this.
post #843 of 868 Old 10-26-2014, 09:54 AM - Thread Starter
Eyleron's Avatar
Liked: 38
Consolidated and sorted marketing data focusing on high output speakers
Originally Posted by oOOBillO0o View Post
First, great effort on this thread. The challenge is that all of this data is flawed in one way or another. Second, its extremely challenging to model speaker behaviors on a spreadsheet.
There are speakers on this list that really exceed THX's and the SMPTE Standards, but if you are single factor weighting for high output, you will be disappointed.
I cannot say this enough, "Trust your ears."
Thanks. And yup, it's a big challenge. Consider this more of a, "Consolidated and sorted marketing data focusing on high output speakers."
Completely different than, say, data-bass.com with its measured data on subwoofer performance.
As always, a prospective consumer should look up trusted reviews, get input from real owners, and try to audition the speakers, in theirs or someone's equivalent space, if possible.
The utility of this spreadsheet is in presenting the marketing data, adjusted where possible, such that their spaces are being compared to eachother. And you can discount speakers that even the lying bastards in the marketing department don't claim good output.
For instance, if Paradigm's Series 7 Center 3 was advertised as only having 90dB anechoic sensitivity, and 93dB in-room, and able to handle 175w program, we can figure...
  • 100w from a typical receiver would only get you 102dB
  • That 100w is about 2/3rd of its own program watts rating
  • The 212w it'd take to reach 105dB from 12ft is above what its published rating will allow. You're right, that's probably thermal. It's much worse in terms of distortion.
  • The higher SPLs, if they can even be generated, are probably full of distortion.
So this is not a high output speaker, as pitched by their marketing department. If you want to listen at -5 or have a large space, this is not the speaker for you.
post #844 of 868 Old 10-26-2014, 10:29 AM - Thread Starter
Eyleron's Avatar
Liked: 38
Danley Sound Labs: Jericho J3
Originally Posted by popalock View Post
@Eyleron
Jericho J3.
OK, so it's time to go there.
Added the Jericho J3.
Low frequency: 6 x 15"
Mid frequency: 8 x 6"
High frequency: 4 x 1.4"
Specs aren't complete, so I extrapolated based on the 4200w program for the low frequency, which is supposed to be 153dB, and I assume outdoors at 1m. Subtract 3dB for 4ohm.
Hope that helps someone towards their...outdoor theater dreams?
zheka, Reddig and popalock like this.
post #845 of 868 Old 10-26-2014, 11:24 AM
popalock's Avatar
Quoted: 453 Post(s)
Liked: 775
Outdoor?
Thanks, welcome back buddy.
popalock is offline
post #846 of 868 Old 10-26-2014, 12:11 PM - Thread Starter
Eyleron's Avatar
Liked: 38
2 Pro Audio Tech added and Surrounds
Pro Audio Tech should indeed be on the list.
The Pro Audio Technology SCR-12sm has been on the list for a while.
But there should be more of them, I agree.
I've added the SCR-15sm. This will get you 115dB from 12' away without dipping into peak watts. This would be reference level without straining/distortion.
  • 92dB sensitivity (LF)
  • 1 x 15" woofer
  • 3" compression driver on large constant directivity horn
  • Requires own active amp, 1400w LF / 220w HF
  • Price?
Selfishly, since I am looking for some in-wall surrounds speakers to go with SEOS fronts, I'll find some surrounds to add to the list.
I've added the SCRS-26im in-wall. This will get you 109dB from 12' using 560w program power. Less than half that will get you reference level with less distortion, which is fantastic for in-wall surround speakers.
  • 90dB sensitivity (LF)
  • 2 x 6" woofers
  • 1" compression driver on elliptical constant directivity horn
  • Fits in 2 x 4 stud bay
  • Requires active amp, 560w LF / 120W HF
  • Price?
Tough to find surrounds that can keep up
Does anyone have some good suggestions for other surround speakers >= 94dB sensitivity?
I was looking at those that fit in a 3.5" stud cavity, but that depth restriction is sure limiting. I have a narrow room, but in the rennovation I was able to move a load-bearing wall a few inches and am now at 12' wide. I think I can get away with a little bump-out of a column of a couple inches. This would maybe enable some of the diy speakers that need 5-6" depth.
post #847 of 868 Old 10-26-2014, 12:50 PM - Thread Starter
Eyleron's Avatar
Liked: 38
SLS Audio: Cinema System 50 ribbon
SLS Audio specializes in pro ribbon speakers.
The Cinema System 50 (CS12) is for smaller cinemas, typically used behind an acoustically transparent screen.
  • 12" woofer
  • 3 or 4" ribbon
  • 98dB sensitivity
  • 119dB from 12' when sending its 800w rated program watts
  • 34w will get you reference level from 12'
post #848 of 868 Old 10-26-2014, 01:29 PM - Thread Starter
Eyleron's Avatar
Liked: 38
Reaction Audio Speakers
http://reaction-audio.myshopify.com/...ions/speakers/
Added three coaxial speakers from Reaction Audio, which I first heard about for their subwoofers.
These could be alternatives to Tannoy coaxial driver speakers, that image as a point-source due to no driver spacing between high and low frequency drivers.
The CX-8 is an 8", the CX-10 a 10", and the CX-15T a 15". Sensitivity in the low to mid-90's as they extend a little deeper (70, 70, and 35Hz respectively).
post #849 of 868 Old 10-26-2014, 03:37 PM
Gooddoc's Avatar
Quoted: 462 Post(s)
Liked: 347
The JBL M2 should be on the list. As effortless at reference as anything I've heard.
Gooddoc is online now
post #850 of 868 Old 10-26-2014, 04:05 PM
jbrown15's Avatar
Quoted: 1008 Post(s)
Liked: 1068
Sensitivity on the CX-15T's is rated 99dB and I can tell you that they are every bit as sensitive as my JTR 228HT's. And in room response is at least down to 30hz. We ran them full range at a little GTG that I hosted yesterday and anyone that was there will tell you how impressive they were running full range. No sub needed for music use that's for sure.
oneeyeblind and Emetw like this.
jbrown15 is online now
post #851 of 868 Old 10-27-2014, 09:46 AM
MKtheater's Avatar
Quoted: 318 Post(s)
Liked: 476
Is there a review of the GTG? I want to know more!
oneeyeblind likes this.
MKtheater is online now
post #852 of 868 Old 10-27-2014, 10:43 AM
Reddig's Avatar
Quoted: 34 Post(s)
Liked: 170
Thanks Eyleron great to have you back!
JBL Pro Cinema
Reddig is online now
post #853 of 868 Old 10-27-2014, 10:51 AM
jbrown15's Avatar
Liked: 1068
Vancouver GTG round 2.
reviews of the speakers are slowly trickling in. All of the speakers at the GTG would be considered high sensitivity & spl speakers.
I personally really liked the new CX-15T's and think I'll be going to those over my JTR 228HT's in my theater room.
post #854 of 868 Old 10-27-2014, 12:06 PM
MKtheater's Avatar
Quoted: 318 Post(s)
Liked: 476
Nice!
post #855 of 868 Old 10-27-2014, 03:59 PM - Thread Starter
Eyleron's Avatar
Liked: 38
Ah I see y'all already put it through the paces!
I think out of habit I assumed the sensitivity was in-room. If it's half-space then I'll keep as they've listed it. I've corrected the spreadsheet.
post #856 of 868 Old 10-27-2014, 05:14 PM
Gooddoc's Avatar
Quoted: 462 Post(s)
Liked: 347
Here are JBL M2 specs:
System Format: 2-Way Floor Standing or Soffit Mountable
High Frequency Model: D2430K Dual Diaphragm Dual Voice Coil Compression Driver
Low Frequency Model: 2216Nd 15 in (381 mm) Differential Drive® Woofer
Crossover Frequency: 800 Hz
Frequency Range: 20 Hz - 40 kHz
Image Control Wave Guide Dispersion: 120º H x 100º V
Sensitivity: 92 dB
Continuous/Peak SPL@ 1m: 117 dB /123 dB; 108 dB Peak SPL @ 8m
The System Requires: One Crown® iTech 5000HD power amp for each speaker,
or BSS® Soundweb London Processor with Crown Macro-Tech® MA-5000i
Recommended Amplifier Power: 1,200 Watts into 8 ohms
Dimensions (W x H x D): 508 mm x 1256 mm x 355.6 mm (20 in x 49.5 in x 14 in)
Weight: 58.5 kg (129 lb)
post #857 of 868 Old 10-27-2014, 06:08 PM
zheka's Avatar
Quoted: 18 Post(s)
Hi there.
Do you think you are settled for a while? I mean does it get any better?
zheka is online now
post #858 of 868 Old 10-27-2014, 06:42 PM
Gooddoc's Avatar
Quoted: 462 Post(s)
Liked: 347
Originally Posted by zheka View Post
Hi there.
Oh, I'm definitely settled for a while . Does it get any better? Well, I don't know for sure. But if it does I definitely want those speakers, lol. The M2's set a very high standard, that's for sure.
zheka likes this.
post #859 of 868 Old 10-28-2014, 08:03 PM - Thread Starter
Eyleron's Avatar
Liked: 38
Jbl m2
The JBL M2 has been added. It's JBL's latest pro reference monitor. It's a system that requires specific Crown amps for gobs of power. These are the culmination of their decades of engineering work.
post #860 of 868 Old 10-29-2014, 05:21 PM
mastermaybe's Avatar
Quoted: 123 Post(s)
Liked: 172
What about the JBL EONS? I've been running a pair of 612 for a couple of weeks now and they sound absolutely fantastic.
http://www.jblpro.com/www/products/p...s#.VFGEVmK9KK0
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #861 of 868 Old 10-29-2014, 09:44 PM
Gooddoc's Avatar
Quoted: 462 Post(s)
Liked: 347
post #862 of 868 Old Yesterday, 01:22 PM - Thread Starter
Eyleron's Avatar
Liked: 38
Meyer Sound: Acheron 80
Meyer Sound is a big name in pro audio, furnishing installed sound, touring speakers, and cinema speakers. They're based out of California.
Here we have the Acheron 80, intended for small-to-medium theaters and screening rooms.
An active speaker, it has a huge 4" compression driver, huge horn, and a 15" woofer. Powered by its own 1685w program amp, active cooling, it'll yield 139dB peaks with distortion not exceeding .02% (program or peak watts?)
Here's an AVS thread discussing a few years ago
post #863 of 868 Old Yesterday, 01:30 PM - Thread Starter
Eyleron's Avatar
Liked: 38
JBL: Eon 612
The JBL Eon 612 is an active powered, portable stage speaker. 57-20kHz, 126dB peaks. $450.
A good speaker in that Mackie, Electrovoice, etc. pro speaker range, but with a lot more output.
post #864 of 868 Old Yesterday, 05:41 PM
walter duque's Avatar
Quoted: 18 Post(s)
Liked: 1
These here http://www.sourcespeaker.com/OD8211.html aren't bad, they can also be ordered with custom veneers.
They even make a sound bar that puts out 120db
http://www.sourcespeaker.com/PlasmaLCRlist.html
walter duque is online now
post #865 of 868 Old Today, 06:14 AM
Quoted: 123 Post(s)
Liked: 172
Correct. I was suggesting that it be added to the list as it meets all the criteria as far as I can tell.
James
post #866 of 868 Old Today, 09:45 AM
MKtheater's Avatar
Quoted: 318 Post(s)
Liked: 476
The EON seems to be a 97.5 dB sensitive speaker so yes, it belongs here too.
LCR-Dual stacked BFM DR-250's
Surrounds- Dual stacked BFM W10's
subs-12 SI 18's ported 6hz.
post #867 of 868 Old Today, 10:34 AM
popalock's Avatar
Quoted: 453 Post(s)
Liked: 775
Belongs here? There are a few speakers with sensitivity in the 80's on the list.
popalock is offline
post #868 of 868 Old Today, 10:37 AM
popalock's Avatar
Quoted: 453 Post(s)
Liked: 775
@Eyleron
FYI, my "unofficial" sources say the J3 runs about $25K per speaker. Not sure where the $1,250 figure came from.
popalock is offline
Reply Speakers
User Tag List
