List of Reference Level, High Sensitivity & SPL Speakers - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #961 of 976 Old 02-29-2016, 01:32 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
[QUOTE=Frohlich;41891001]In the land of AVS member insanity, there are many folks on AVS who use pro-audio speakers from JBL, QSC, JTR, Danley, etc..... and pro audio amps from Crown, QSC Behringer,etc.. I personally have a JBL pro set-up with Crown amps.[/QUOTE
+1
Yes in this land you'll find pro audio used in home cinemas to great effect. I also have a JBL Pro Cinema setup powered with vintage Crown amps.
Reddig is offline
post #962 of 976 Old 03-16-2016, 09:44 AM
alamez's Avatar
Quoted: 36 Post(s)
did i miss something or are the behringers?, b212xl and b215xl not on the list
nomjolnir likes this.
alamez is offline
post #963 of 976 Old 06-16-2016, 03:32 AM - Thread Starter
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
Originally Posted by DXProSound View Post
Forgive me for being new to this. Just an old guy who loves audio.
You have listed several Professional grade speakers. Do many people really use these? I did pro installs for churches, schools and club for 20 years and have used dome of the model mentioned in this HT list. I did an HT for a guy using powered QSC boxes. The guy spent $100K plus on the room including 3D projector and screen and servos under all of the seats driven by a 12kW Crown Amp. I was crazy loud and did sound totally awesome and 100+db but during softer spoken parts you could hear the hiss coming from the 10kW worth of speakers.
I'd think we'd want amps with higher signal to noise ratios with sensitive speakers.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
post #964 of 976 Old 06-16-2016, 04:28 PM
garygarrison's Avatar
Quoted: 507 Post(s)
Liked: 536
Yes, and not only better (or adequate) measured, weighted, signal to noise ratios, but also spectral characteristics that cause noise (hiss, especially) to be less noticeable. I had two name brand pre/pros with highly similar measured S/N ratios; one had objectional hiss, hum, and buzz with my Klipschorns and the other didn't. The one that did have the noise measured fine (measurement done by the manufacturer). The noise came from beyond the volume control, i.e., turning down the volume didn't help. When the pre/pro was turned off, there was no noise (except when a few feet from the Khorns), so it was not the power amp. The dealer and I checked, and found NO hum loop. Replacing the pre/pro with another make and model fixed the problem.
garygarrison is offline
post #965 of 976 Old 06-21-2016, 05:22 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Thumbs up
Hey @Eyleron , I stumbled upon these awesome looking Danish speakers the other day...
Quoted specs are a bit sketchy... I had to hunt for the sensitivity and maximum SPL conditions:
Operating range: 65Hz (-3dB) to 40kHz
Axial sensitivity (whole space SPL) LF/MF-HF: 110dB/1W/1m
Nominal beamwidth; horizontal, vertical: 90º, 40º
Impedance nominal minimum:
Recommended HPF: 80Hz; 24dB/octave
Maximum power handling: 140W
Calculated axial output limit (whole space SPL), average peak LF/MF-HF (30W): 130dB @1m
[UK price.]
Specs for all of Artcoustic's speakers are summarised here: http://www.artcoustic.com/speaker-comparison-tables/.
GIEGAR is online now
post #966 of 976 Old 06-21-2016, 09:18 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
[UK price.]
Wow! All the design problems of an MTM centre and a pseudo line array in one convenient package.
A9X-308 is offline
post #967 of 976 Old 06-21-2016, 09:47 PM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
Yes, but they claim high sensitivity/SPL.
I take it they're seriously flawed? I'm broadly across the issues of a horizontal MTM, but have no idea about line array theory.
post #968 of 976 Old 06-22-2016, 01:04 AM
A9X-308's Avatar
Liked: 951
Line arrays have two main problems in my experience. The first is that the MF/HF drivers are side by side, putting lobing issues on the horizontal axis rather than the vertical where it is generally less of an issue. The second is, that the taller the panel, the greater the time of flight difference is between the top and bottom drivers versus the central ones. This results in strong comb filtering and is annoyingly audible to me. It makes it sound unfocussed for want of a more technical description. Large panels like electrostatics and Magneplanars are the same.
The MF drivers in this design are quite small about 4" by eyeball. That gives them the area (Sd) of about 52cm^2 so the total area is 1248cm^2 or about the same as a pro 18" driver. The problem is that small drivers have a small Xmax so the volumetric displacement which determines SPL is not going to be the same as a pro driver, so the drivers will be using a larger % of their Xmax than the pro 18 to get the same SPL. More excursion from rest, the more distortion. Also, because a large number of drivers are used in my experience they are cheaper units than designs using a smaller number of drivers in a more conventional way, and the drivers will have to be wired in series/parallel to get the impedance to a reasonable number. Let's hypothesise they are in groups of 3, which are then paralleled; each driver will see the inductance and the Le(x) of the other two, reducing rise rate and increasing distortion.
Even very expensive designs with lots of high quality drivers still have these issues, but to a lesser extent. Many years ago we built a 3 way line array based upon a similar design, just longer and using ribbons for the HF and using a separate enclosure for the LF drivers. Compared to a number of other designs such as a coaxial (compared using the same LF array) we could never seem to get the midrange clarity and imaging of the point sources, through the dynamics were quite good.
It would be interesting to try to work around the TOF differences, by outputting to multiple DACs and amps (1/driver) with small delays to adjust for the TOF differences as much as possible, but that will have to be a project for someone else.
Gotta go shortly. I'm being dragooned to some function. Apparently there is some football match being played tonight, and I'm not a fan.
GIEGAR and bgtighe23 like this.
A9X-308 is offline
post #969 of 976 Old 06-24-2016, 11:16 AM
DaveyMac's Avatar
Quoted: 570 Post(s)
Liked: 104
Does Goldenear speakers reach reference?
I have Triton 5's which are not their best, and I measure reference levels in my rather large room with them..
DaveyMac is offline
post #970 of 976 Old 07-26-2016, 10:43 AM
vantage78's Avatar
Quoted: 63 Post(s)
Liked: 5
Just stumbled on this thread. Great info, thanks for putting it together!
Can you add the Monitor Audio Gold series, specifically the 300 towers? I'm curious how those stack up.
vantage78 is online now
post #971 of 976 Old 07-26-2016, 11:57 AM
A9X-308's Avatar
Liked: 951
Not HE.
A9X-308 is offline
post #972 of 976 Old 01-12-2017, 08:05 PM - Thread Starter
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
It theoretically can, as 200w at 12ft from a 90dB (they don't qualify as 1w, 1 speaker, so who knows?) speaker can be 105dB. But with no headroom.
Two quarterbacks can both throw the ball 80 yards, but one of them usually goes the target, the other usually misses.
When we crudely measure with meter we are reading sound (pass distance), not necessarily good sound. You could also measure for distortion (pass accuracy).
200w to achieve 105dB is half their stated power handling until the speaker breaks. Usually that means distortion that may not be obvious until you hear speakers effortless at that level.
If the speaker is big, it MIGHT play low and with great efficiency.
If it also plays low like a sub, it often gives up efficiency.
Lots of drivers, and big drivers, might also indicate efficiency. Triton 5 has two 6" woofers for midbass, but one 10" woofer would have 50% more surface area.
Seems like it's intended for two channel use and not reference level theater or concerts, like most of the towers are.
They are selling most people on that unqualified spec of 26Hz response (-3db? -10db?) when the user may have subs and not need that extension anyway. They could make a speaker that plays to "only" 60Hz that's 96dB and would pay loud and clean.
Sent from my SM-G930V using Tapatalk
post #973 of 976 Old 01-16-2017, 09:12 AM
Tomas2's Avatar
Quoted: 27 Post(s)
...Reference Level, 0dBFS (0dB Full Scale (digital), is the maximum level the soundtracks can be recorded at for any given channel. It equates to SPL peak output for each five or seven channels of 105dB and 115dB for the LFE channel at the listening position
Greetings Eyleron, here in the US we use:
SMPTE RP 155 (-20dBFS = +4 dBu = 0 VU = 1.23 Volts rms)
Note the 20dB headroom above reference with a peak +24 dBU = 12.28Volts rms
Electrical interface calibrations can be measured with a true rms multimeter and sine wave peak amplitude of -20 dBFS.
Reference surround reproduction level (pink noise at -20 dBFS) currently targets 85 LKFS which is normalized via correctly setting the DD AC3 encoder metadata dialnorm to reflect the mixing dynamic. Long term measured average dialogue level target is (-31 dBFS)
i.e. A theatrical mix room calibrated (81 dBSPL) instead (85 dBSPL) puts the mixing engineer in an environment which will result him/her raising their long term average dBSPL and also compressing dynamic range slightly. Things are normalized:
31+ (dialnorm setting) = level shift
Still using the same example:
31 +(-27) = 4 db attenuation. Thus normalizing to the -31dBFS or (105dB - 31dB = 74 dBSPL) long term weighted average dialogue level
SAMSUNG LED | ROTEL | JBL | M&K | HAFLER | TECHNICS SP-25
Tomas2 is offline
post #974 of 976 Old 01-22-2017, 07:12 PM - Thread Starter
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
Behringer 212XL & 215XL
Behringer B212XL and B215XL added!
More talk about them here on AVS Forum.
post #975 of 976 Old 01-22-2017, 10:42 PM
Liked: 0
B215XL and B212XL looking good on that chart!
3 x B215XL, 4xB212XL
2 x B1200D Pro
2 x SVS PB13 Ultra, MiniDSP2x4 revB, UMIK-1
Sony HW40ES, Dreamscreen V5 Ultraframe D65 100"
nomjolnir is offline
post #976 of 976 Old 01-23-2017, 10:43 AM - Thread Starter
Eyleron's Avatar
Quoted: 250 Post(s)
Liked: 142
http://www.monitoraudiousa.com/products/gold/gold-300
I'd talk about them and list them not just if they're efficient but also high SPL. I guess I should have an OR in the thread instead of an AND.
Like, Dynaudios that aren't terribly efficient but can take gobs of power.
The Monitor Audio Gold 300 towers say they're 90dB sensitive but don't qualify that as full space, half-space, in-room.
They say they recommend 100-200w amp. We don't know if 200w is where distortion starts to get objectionable (where the drivers get non-linear, there are breakup modes, etc.), or it's where the speaker starts to break, and on 200w peaks, or do they mean 200w of long-term 3dB crest sine wave?
Since I'm really advocating for reference-capable speakers to be able to hit 105dB peaks at half their max power handling so at least there's a chance distortion might be lessened, it's debatable whether this speaker makes that "grade" such that it is.
It's disappointing that reviews don't show distortion components at increasing levels. Stereophile does 90dB at 6 feet, I think, but I wish they also did 100dB and 110dB!
It'd also be useful to find a review that shows impedance curve, because many supposedly "8 ohm compatible" speakers really have dips to 2.5 or 4 ohms in mid-bass frequency region (so should've been marked as a 4 ohm or 5 ohm speaker), and thus demand way more power than you're led to believe.
So when a speaker doesn't give an impedance curve, qualify what the sensitivity and power handling mean, and it's already on the fence spec-wise, I'd say it's not reference-capable.
Reply Speakers
