Energy Veritas 6.2? 6.3? RC70? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-16-2012, 07:38 AM - Thread Starter
arshishb's Avatar
Ok guys, what is the difference here? The RC70 & 6.2 can be had for $500 from Vanns & the 6.3 for $800. What is the key here?
I want to replace my Polk monitor 5.1 setup because frankly they don't do it for me. My listening is 50% music & HT at decent volume & very rarely when the upstairs neighbor is out, higher than decent volume
I am in lust with the rosewood finish & was set on the Veritas series but then I have read very good things about the RC70 as well.
So, I am not asking you to tell what I should buy, just want to the different opinions out there about these particular speakers & comparisons to identical speakers or whatever speaker you had before them.
What I didn't like about the monitors, they just seem flat if you know what I mean? Their stereo image is ok, mids are ok in the sense that vocals sound nasal? And even with my VSX 1121 I have to crank the volume quite a bit to get them to sound clear.
arshishb is offline
post #2 of 2 Old 01-16-2012, 07:48 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
This topic comparing the RC and Veritas line has been discussed at length in the Energy Owners Thread. As a result, I would suspect that you won't get much response here about the differences other than to tell you that the Veritas series is not a significant upgrade over the RCs--get the RC-70s for the difference in price. You'll have to read through and search, but one place to start in the thread could be CalgaryCowboy's description of his experience with the RC-70s and V6.3s.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
