Small floorstanding speakers vs. standmount speakers & sub - AVS Forum | Home Theater Discussions And Reviews
Old 01-19-2012, 12:53 PM - Thread Starter
Darrenmc's Avatar
I`m just curious as to what your thoughts are on this topic. I know this has been debated before but I couldn`t find much out there on this. The reason I ask is I`m currently using PMC FB1i`s with an Esoteric AI-10 integrated amp and a Bryston BCD-1 cd player in a small to mid size room, 16x13x8 with an open staircase. The room is fully furnished and carpeted and the speakers must be place about a foot off the wall. I realize that standmounts will not go as low in the base extension but paired with a good sub could sound as good or better than some smaller floorstanding speakers. I`m looking for a wider soundstage /dispersion and a fuller sound . The bass and clarity is pretty good on the PMC`s. If you have any suggestions for good standmount & sub combos that may better the PMC FB1i`s or any other small floorstanders that may sound better with my situation please suggest some. Thanks in advance.
Darrenmc is offline
Old 01-19-2012, 01:02 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Budget?
Size or aesthetic constraints?
rick240 is offline
Old 01-19-2012, 01:07 PM - Thread Starter
Darrenmc's Avatar
Originally Posted by rick240 View Post
Budget?
Range of $3500 - $6000 CDN/US. Not looking for huge speakers but a small floorstander or standmount & smaller sub, aesthetics are not an issue.
Darrenmc is offline
Old 01-19-2012, 01:08 PM
toofarzong's Avatar
Your PMC's are very good speakers. I'm surprised to hear that you're having dispersion issues. Have you tried different speaker placements? I would definitely get a sub if I were you. I agree with you that it would take a mighty floodstander to compare with your PMC's. Have you though about a PMC sub? Are you not happy with your PMC's?
toofarzong is offline
Old 01-19-2012, 01:25 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
There are many, many options in that price range.
My personal bias would lead to considering Salk HT1 or SoundScape M7 (talk to Jim and see of front-ported that close to the wall would be best) paired with either a Rythmik F12 or the same components in a custom built Salk cabinet.
The rave reviews of the new Philharmonic PhilHarmonitors make them worth considering too.
rick240 is offline
Old 01-19-2012, 02:26 PM - Thread Starter
Darrenmc's Avatar
I can`t place the speakers anywhere else. I don`t have a dedicated listening room to move them around in. I`d love to get a small sub but my amp does not have a sub out. It`s not that I`m not happy, they are a great speaker but I`m always looking to improve.
Darrenmc is offline
Old 01-19-2012, 02:35 PM - Thread Starter
Darrenmc's Avatar
Thanks for the suggestion. The Salks sure have beautiful cabinets. Will check them all out.
Darrenmc is offline
