How is the Polk TL2 Center - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-19-2012, 02:19 PM - Thread Starter
ddvette9's Avatar
Quoted: 202 Post(s)
Liked: 43
Currently running energy cf-50 towers and a pioneer center but want to switch to the Polk TL 2
http://www.bestbuy.com/site/Pioneer+...&skuId=1147943
But, the center pioneer center doesnt match well so I was thinking about going to the Polk TL2.
http://www.bestbuy.com/site/Polk+Aud...0tl2&cp=1&lp=1
The energy are super efficient at 96 db and the pioneer is only 87 db. I have to make a change. WIll I notice a difference in quality/ sound and db from the pioneer to the polk TL2....
any personal experience on the Polk TL 2 center? How is it?
ddvette9 is offline
post #2 of 7 Old 01-19-2012, 02:25 PM
Audiojan's Avatar
Quoted: 18 Post(s)
You'll be much better off looking for a matching Energy center... Mixing brands is usually a challenge.
"Suddenly the thought struck me, my floor is someone elses ceiling" - Nils Ferlin
Audiojan is offline
post #3 of 7 Old 01-19-2012, 02:46 PM - Thread Starter
ddvette9's Avatar
Quoted: 202 Post(s)
Liked: 43
Thats what I thought too until I also noticed the energy center has very very poor sensitivity compared to the towers (96 vs I think 88 for the center) and thats the problem I am having now with distortion in my center crappy pioneer center. The polk is in the 90's which is closer to my energys
ddvette9 is offline
post #4 of 7 Old 01-19-2012, 03:03 PM
crazyrob425's Avatar
Quoted: 445 Post(s)
Liked: 339
Yeah but its the matching center. Your receiver calibration will level match it to the Towers so no worry there
crazyrob425 is offline
post #5 of 7 Old 01-19-2012, 03:57 PM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
The Energy CC-10 center has a sensitivity of 92db, not quite sure where you are getting your info.
http://www.energy-speakers.com/na-en...pecifications/
It'll be fine with your CF-50's and once you calibrate the receiver will adjust the volume levels accordingly.
Afro GT
afrogt is offline
post #6 of 7 Old 01-19-2012, 04:16 PM - Thread Starter
ddvette9's Avatar
Quoted: 202 Post(s)
Liked: 43
Matching center aside, is the Polk tl2 a good center? Is it better than the pioneer I have now?
ddvette9 is offline
post #7 of 7 Old 01-19-2012, 04:55 PM
Quoted: 445 Post(s)
Liked: 339
If you are using a TL2 center with a TL1, TL2, or TL3 satellites then yes its a good center otherwise it is not as good as a matching CC-10
IF you didn't like the Pioneer center you will not like the TL2 center!!!!
Get a Energy CC-5 or CC-10!!!! That way you won't have to compromise again!!!!!!!
Reply Speakers
