Karaoke speakers: Polk Audio 70 or Bose 301v? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-19-2012, 06:26 PM - Thread Starter
rbfatality's Avatar
My first post please be gentle . I am thinking of getting a pair of speakers for karaoke.
How does Polk 70 compare to Bose 301V?
rbfatality is offline
post #2 of 10 Old 01-19-2012, 06:35 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
not really the best in my opinion for karaoke
Bose definitely not. Polk's aren't designed for it
Something this would be better set up
http://www.guitarcenter.com/Soundcra...81-i1850562.gc
crazyrob425 is offline
post #3 of 10 Old 01-19-2012, 06:45 PM
pokekevin's Avatar
Liked: 102
I use my RC-10s for some karaoke (well not me but the gf) and Im curious to what makes a speaker "good" for karaoke?
pokekevin is offline
post #4 of 10 Old 01-19-2012, 06:47 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
Neither of those would be good for karaoke IMO. The Bose is an awful speaker for ANYTHING; it is just terrible.
I suggest the Cerwin-Vega VE-12, which Amazon has for $279/pair.
They have a 12-inch woofer to give plenty of bass and are very powerful and efficient. They should be very good for karaoke.
commsysman is offline
post #5 of 10 Old 01-19-2012, 06:47 PM
gregzoll's Avatar
Liked: 33
What ever fits your budget. Here is a listing of some more http://www.pssl.com/Speakers JBL's are still one of the better choices for dj's, next is Peavey's. If it was me, I would be going with powered speakers, vs. passive for dj'ing or Karaoke. You want everything to fit in as small of a package, but not have to haul a ton of equipment.
You may be also able to find a decent used set that someone is getting out of the business, or has traded up. Check local music shops out.
gregzoll is offline
post #6 of 10 Old 01-20-2012, 08:06 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I've been using the Infinity P362 + BIC PL-200 sub for karaoke for a while. Everyone says they sound fantastic. The key is the $100 Yamaha mixer! Must have a mixer. Otherwise nothing sounds as good!
At first I thought the infinity speakers were not adequate. So I bought 2 yamaha professional speakers. They cost $1300/pr. They did not sound as good as the P362.
So then I bought the mixer. Wow. What a difference. Now the P362 sound great for karaoke. But you must also get a subwoofer. It doesn't have to cost a lot. But you need a sub and mixer for sure.
The P362 is an accurate speaker. Max SPL is probably around 110dB, which is fine with me since I'm not singing outdoors.
My room size is 18' x 20' x 10' ceiling, open to 3 sides.
AcuDefTechGuy is offline
post #7 of 10 Old 01-20-2012, 11:46 AM
pokekevin's Avatar
Liked: 102
How different would it be to use like a vocopro mixer?
post #8 of 10 Old 01-20-2012, 12:47 PM
Quoted: 175 Post(s)
Liked: 262
I'm not sure. I have 1 of those $600 hard drive karaoke machines. It has 3 microphone inputs. It does not sound very good. I also have a $500 Pioneer karaoke machine w/ 3 mic inputs. Doesn't sound very good either. Speakers would crackle. Sounded awful. That was when I tried those huge Yamaha cab pro speakers w/ dual 15" woofers & the horn w/ SPL rating of 135dB. Didn't help at all.
Then I got the $100 Yamaha mixer from Amazon and never looked back since. So now the $600 karaoke machine is hooked to the Yamaha mixer which is hooked to my Denon 3310.
But that is just my personal experience. Perhaps the Vocopro works wonders as well. I never tried the Vocopro.
post #9 of 10 Old 01-24-2012, 08:54 AM
greddy09sc's Avatar
What model Yamaha is it? I'm interested in getting one. I have a Vocopro too but want to hear the difference.
greddy09sc is offline
post #10 of 10 Old 01-24-2012, 08:59 AM
greddy09sc's Avatar
I think a good mixer for karaoke must have a 'echo' and 'reverb' knob.
Reply Speakers
Bose Stereo Loudspeakers 301 V
